New Partition Post Windows 10 Update: Transfer F Partition Data (35MB/449) to C Drive (50GB SSD)
matjajko 2376 7
  • #1 17222503
    matjajko
    Hello, today I updated Windows 10 with 50GB of free space on the C drive (SSD). After installing it, I noticed a new F partition (35MB free out of 449) so there was probably not enough space on C and the rest was done on F if I'm not mistaken. I deleted the old update files on C and it's back 50GB. Now the question is, how to move this from F partition to C so as not to break the system?
  • #2 17222524
    Yansen
    Help: 44
    A little bit of data, take a screenshot of the disk manager and show the root directories on C and F.
  • #3 17222555
    matjajko
    When I enter F, it says that it is empty.
    Here the SS drives:
  • #4 17222586
    Yansen
    Help: 44
    The letter F is for the picture. Show what's on C: \
  • #5 17222599
    matjajko
    In what sense "to the photo"?
  • #6 17222990
    Yansen
    Help: 44
    1. The letter F is to be removed. Disk manager> select drive F, right click> change drive letter> delete.
    2. From the C drive you can remove the Intel, Perflogs, Temp folders.
    3. Run the program: Disk Cleanup> select: clean up system files > after scanning, select whatever you will have there and click> OK.
  • #7 17225714
    matjajko
    I deleted F, left unallocated space i can't move, be it Partition Wizard or EaseUs. It does not merge, nothing.
  • #8 17226166
    Yansen
    Help: 44
    This is the system partition, leave it as is.
After a Windows 10 update, a user discovered a new F partition with limited space and sought to transfer data from it to the C drive (50GB SSD) without compromising the system. Initial suggestions included checking the disk manager for details and removing unnecessary folders from the C drive. However, the user faced challenges in merging partitions using tools like Partition Wizard and EaseUS, ultimately being advised to leave the F partition as it is, as it may be a system partition.
