Transferring Space from D to C Drive for Windows 10 MediaCreationTool Usage
Filozofero 4260 7
  • #1 16511852
    Filozofero
    I have windows 10. I have two partitions in the flap. C - system, where I have 3 GB free of 24 and D practically all free. I wanted to download windows 10 and boot it to pendrive / board. When starting MediaCreationTool, "No space on C drive (8GB)" pops up. How can I "fix" this with drive D? Virtually all space on the C drive is taken up by the system.
  • #2 16511871
    sosarek
    Help: 9320
    Rate: 15532
    After all, in Creation Tool, after selecting the disc option (.iso), you can choose the location where the file should be saved - you choose D.
    Z
    Pka, Poznań, 60-850
  • #3 16511879
    Filozofero
    Well, after choosing whether to make updates or save, it immediately pops up that there is no space ..
  • #4 16511888
    mikomaaz
    Help: 18
    Rate: 33
    What kind of disk is it? Upload your hardware specification.
    If everything is on one disk (both partitions), it is enough to remove the larger partition and extend the system one.
    If it is some kind of hybrid drive it will be a problem.
  • #5 16511891
    sosarek
    Help: 9320
    Rate: 15532
    Great idea ... no what ...
    @Filozofero
    All you have to do is free up some space on the system drive (Windows 10 x64 installation is about 3.5GB) and then try.
    Z
    Pka, Poznań, 60-850
  • #6 16511899
    Filozofero
    256 GB SSD. I tried, but with the C partition I cannot extend - with D I can extend.
  • #7 16511936
    E8600
    Help: 529
    Rate: 2520
    I suspect that the place you have free is devouring the pagefile, how many frames do you have? I reserve the system as well.
    As for changing partitions, I recommend the EaseUS Partition Master program - I used it to change the size of the partition on the clogged disk without losing data (though the disk one).
  • #8 16511939
    sosarek
    Help: 9320
    Rate: 15532
    Do not mess with this extension, but remove unnecessary garbage from the system partition.
    Z
    Pka, Poznań, 60-850
The discussion revolves around the issue of insufficient space on the C drive when using the Windows 10 MediaCreationTool. The user has a 256 GB SSD with limited space on the C drive (3 GB free) and ample space on the D drive. Suggestions include selecting the D drive for saving the ISO file, freeing up space on the C drive, and using partition management software like EaseUS Partition Master to adjust partition sizes without data loss. Some participants recommend cleaning up unnecessary files on the C drive instead of resizing partitions.
