New Venus Programmable Remote Control: Codes for Enox AIL-1519S2 & SEG Rio LCD TVs
sdfy62 8952 5
  • #1 17250018
    sdfy62
    Rate: 11
    I am looking for the codes for the above-mentioned pilot
    TV ENOX AIL-1519S2
    LCD TV SEG RIO.
  • #2 17250395
  • #3 17250539
    noak
    Help: 26
    Rate: 88
    mihal2002, do you know what a New Venus remote control is, that you tell him about a manual with a device operation list. The New Venus remote control is computer programmed.
    sdfy62-do you have a programmer and a base in your computer for it?
    If so, you can search for the code from the attached TV set.
    You can try to ENOXA code: 90895.
    For SEGA code: 99905.
    Good luck.
  • #4 17253842
    sdfy62
    Rate: 11
    the ENOX code does not match.
    the code 99905 is Vestel, but that SEG inside is something Chinese.
  • #5 17255399
    noak
    Help: 26
    Rate: 88
    sdfy62-I think you have a programmer, search for the code from the TVs and the problem will be over.
  • #6 17256267
    sdfy62
    Rate: 11
    Thank you, I'll try
