MEDION 40023399 Universal Remote: How to Program for LG 32LC52 LCD TV using LG Codes
Padrettini 10524 10
How can I program a MEDION 40023399 universal remote to control an LG 32LC52 LCD TV using LG device codes?
Use the MEDION manual’s code-entry procedure, but if the TV key does not accept the LG code, try assigning the TV as AUX or SAT instead. The remote’s instructions are in the manual on page 50, which shows how to enter a device code from the list [#16448268] One reply notes that the TV function may be tied to a specific model (LCD-TV MD 20015), so the same code entry may not work on the TV button; they suggest trying it under AUX [#16448416] The original poster later reported success by adding the TV under SAT, which gave working volume, source, and power on/off control [#16448438]
  • #1 16448018
    Padrettini
    Help: 98
    Rate: 557
    I have a universal remote control MEDION 40023399.
    and LG 32LC52 LCD TV.
    I have the LG remote control codes, but I can't find the coding instructions.
    Can anyone encode this remote control to the TV?
    Thank you in advance.
  • #2 16448080
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    link
    Can't find at home or online?
  • #3 16448092
    Padrettini
    Help: 98
    Rate: 557
    I was on this site and nothing helped. Even the general instructions for the universal remote control gave nothing because it does not coincide with what is happening on my remote control.
  • #4 16448098
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    You were looking for answers here: link
    What do you think:
    • bda_md83709_pl.pdf (725.08 KB) You must be logged in to download this attachment.
  • #5 16448134
    Padrettini
    Help: 98
    Rate: 557
    Entering device codes
    by list
    The codes of the respective devices are given in the list of
    accompanying the operating instructions.
    ? Turn on the device to be controlled by the remote control.
    ? Hold down the Setup button for approx. 3
    seconds until SETTINGS appears. SYST.
    ? Press OK. The text LIST KO- first appears
    DOW.
    ? Select the ENTER CODE menu with the arrow ?
    ? Press OK. The word DEVICE BUTTON appears.
    (source button).
    ? Press the desired source button (TV, VCR, DVD, CD,
    SAT, AUX1, AUX2, AUX3, AUDIO, SAT).
    The name of the source button appears on the display
    feel with the currently set code.
    27? Use the digital buttons to select the desired code from the list.
    After entering the fourth digit, a message appears
    confirming OK.
    The remote control switches to normal operation mode.
    If an incorrect code has been entered, a
    MESSAGE ERROR message. CODE.
    The remote control returns to normal operation mode.
    Just for example.
    My remote has no display.
    Added after 49 [seconds]:
    I searched, but I can't find the device after the MSN.
  • #6 16448235
    krzysiozak
    Level 40  
    Help: 510
    Rate: 1154
    Pilot, if the purchased one can always be returned to the store or exchanged for another, so use the stores with remote controls in my area.
  • #7 16448263
    Padrettini
    Help: 98
    Rate: 557
    I just have it. I bought it a long time ago and it would be useful now. For sure there is someone who knows what keys to code the remote control.
    sosarek
    Help: 9320
    Rate: 15533
    The first link on Google after entering
    Padrettini wrote:
    MEDION 40023399
    is the user manual for tv with this remote control - page 50 for instructions on entering device codes ...
    http://download2.medion.com/downloads/anleitungen/bda20115de.pdf
    Z
    Pka, Poznań, 60-850
  • #9 16448393
    Padrettini
    Help: 98
    Rate: 557
    Thank you very much. I've seen it before, but I didn't load it because I don't know German.
    However, I saw this:
    TV: LCD-TV MD 20015;
    STB, DVD, VCR, AUX: Andere Geräte.
    Coding works as described only on the VCR, DVD, SAT, AUX functions.
    It does not work as described on the TV function.
    I have to understand that the remote control is assigned only to this TV model?
    I'm just wondering at the code list that also includes TV.
    sosarek
    Help: 9320
    Rate: 15533
    Probably - yes, try adding TV under AUX.
    Z
    Pka, Poznań, 60-850
  • #11 16448438
    Padrettini
    Help: 98
    Rate: 557
    I added a TV under SAT and volume, SOURCE on and off. I take care of the rest with the set top box remote control. Thank you for your help. Problem solved.
The discussion revolves around programming the MEDION 40023399 universal remote control for an LG 32LC52 LCD TV. The user initially struggles to find coding instructions despite having the necessary LG remote control codes. Responses include suggestions to check online resources and user manuals, with one helpful response providing a link to the user manual that contains relevant instructions. The user later discovers that the coding works only for certain functions and successfully programs the TV under the SAT function, using the set-top box remote for other controls.
