How to Program SP-URC-81-ME AI SupportPlus Universal Remote Control for TVs & Devices
markus-wielki 151120 4
  • #1 1013114
    markus-wielki
    Rate: 175
    hey I bought a universal remote control for various devices for tv so as not to have a pile of pilots only that I did not get instructions for it and now I do not know what to press to start working on the remote control I write sp-urc-81-me ai SupportPlus. thanks
  • #2 1013143
    arnoldk_20
    Help: 290
    Rate: 114
    It was discussed several times.
    You press the set and Tv buttons (or other depending on which device you are programming the remote control) at once the diode should light up then you press the Tv button (or another depending on which device you are programming the remote to) the diode should blink and press the "power" button on the remote control as many times until the TV (or other device) turns off, then wait until the LED on the remote control stops flashing.
  • #3 1013163
    renard m.
    Help: 43
    Rate: 27
    Hello ... without the manual, you can do the trick, but without the list of codes for individual devices (which should be attached to the remote control) you can throw it away or give it back to where you bought it. The situation is completely different if your remote control has a learning function ... normally it is a sign like "learn", "set", "save" etc. but it can also be a combination like yours: "me". Try to press this button for more than 2 seconds, which should put your remote control into "learn" mode and you will be signaled by the LED ... then you press the button on your universal that you want to program, and then the button on the original remote from which this function is to be taken over (eg play in a VCR) and remember that the distance between the pilots does not exceed 30-40cm, and besides, they must "see" each other, i.e. be turned to each other with IR LEDs .... good luck in your tests !! R:
  • #4 1013226
    markus-wielki
    Rate: 175
    as for the list with codes, I got a card there and what next? what to press around the circle ... thanks
  • #5 1013293
    renard m.
    Help: 43
    Rate: 27
    Hey ..... you are looking in the list of codes for the brand of your device, e.g. Sony and assuming that it is a TV set, press the TV symbol in the universal and wait for the LED status to change (it will light up, or it will start blinking ...) then you enter it using the numeric keypad only the code in the remote control ... normally after this procedure it should automatically switch to the normal mode. Oh, and one more thing, for each manufacturer, there are several codes, so you have to try until successful .... entering the code and then trying, etc., etc. I think you can do it :)
