Best 50-55 Inch TVs for Movies & Gaming Under 2,500 Zlotys (Excluding Samsung) – FullHD or 4K
6369 17
Which 50–55 inch TV should I buy for movies from a PC and occasional gaming under 2,500 PLN, excluding Samsung?
The thread’s safest recommendations are the LG 55UJ635V or the Sony Bravia KD-55XE7005, both described as popular, sensibly priced TVs; the Sony uses a VA panel and the LG an IPS panel, and both are in the 50/60 Hz class [#17276375][#17276435] If gaming matters, the replies caution against the cheaper TCL models because people repeatedly reported smudging and around 40 ms input lag, which was considered too high for dynamic games [#17276530][#17276471] So the discussion leans toward LG or Sony rather than TCL/Philips/Thomson for this budget and use case [#17276375][#17276530]
  • #1 17276112
  • #2 17276253
  • Questioning whether 2500 PLN is enough for a reliable 55-inch TV
    #3 17276341
  • #4 17276375
    Ludwik XVI
    Help: 1325
    Rate: 788
    How to be a proven manufacturer bypassing Samsung, then focus on LG 55UJ635V or Sony Bravia KD-55XE7005
    Popular and sensibly priced TVs.
    Sony on VA matrix, LG on IPS - both 60Hz.
  • Questioning Sony’s 50 Hz panel for gaming use
    #5 17276399
  • #6 17276435
    Ludwik XVI
    Help: 1325
    Rate: 788
    Yes, both models are 50 or 60Hz (depending on the nomenclature)
    The cheapest, good 120Hz TV is currently Samsung 55MU7002.
  • Positive TCL S7906 review for movies and gaming
    #7 17276471
    TCL S7906 has high input lag for gaming
    #8 17276530
  • Blind test challenge to prove TV differences
    #9 17276553
  • Input lag matters more than panel response time
    #10 17276627
  • Clarifying LG and Sony TV input lag and HDR
    #11 17276670
  • Input lag and smudging claims questioned
    #12 17277798
  • #13 17278466
  • #14 17279102
  • #15 17283540
  • #16 17338674
    lesmian45
    Level 19  
    Help: 19
    Rate: 17
    With this suspension of Philips, take a bit of distance and try it yourself. These models are very well prepared in terms of components. It used to be the case that Philips had a stability problem, but that's not the time either. you should just check it yourself (or watch movies on YT)
  • #17 17343895
    adse
    Help: 56
    Rate: 255
    Unfortunately, Philips broke down its reputation for poor quality and dubious durability. I would not risk buying a TV set for this brand, although I can see that it looks good in the store and in technical data. The previous Philips also looked good in the store, fortunately after three years it broke down and went to scrap, it was replaced even by a cheaper other brand - and only then it turned out what a bad television tormented eyes for 3 years. No more Philips.
  • #18 17351205
The discussion centers around finding a suitable 50-55 inch TV for movies and gaming under 2,500 Zlotys, explicitly excluding Samsung models. Users recommend several brands and models, including Philips 55 PUS6262, TCL 55S7906, Thomson 55UC64, TCL 55P6046, Hitachi 55HZT66, LG 55UJ635V, and Sony Bravia KD-55XE7005. Concerns are raised about input lag, image quality, and reliability, particularly with TCL models, which some users praise for their value but also report issues like smudging and input lag. The importance of matrix type (VA vs. IPS) and refresh rates (50Hz vs. 60Hz) is discussed, with a focus on performance for gaming. Users express skepticism about Philips due to past quality issues but acknowledge its improved components. Overall, the conversation emphasizes the need for thorough research and personal testing before purchase.
TL;DR: For non‑Samsung 50–55-inch picks, "Sony on VA, LG on IPS — both 60Hz." Shortlist LG 55UJ635V and Sony KD‑55XE7005. [Elektroda, Ludwik XVI, post #17276375]
Why it matters: This FAQ guides budget‑minded movie watchers and PC/console gamers to the right 50–55-inch TV without Samsung, minimizing input‑lag and stability headaches.
What are the best non‑Samsung 50–55-inch TVs for movies and gaming?
Focus on LG 55UJ635V and Sony KD‑55XE7005. Sony uses a VA panel; LG uses IPS. Both are 50/60Hz. These models were highlighted as popular and sensibly priced when avoiding Samsung. They form a solid shortlist for mixed movies and gaming. [Elektroda, Ludwik XVI, post #17276375]
Is ~40 ms input lag too high for PS4 racing or shooters?
A buyer measured about 40 ms in Game mode on TCL U55S7906 and found racers unplayable. They also reported smudging and returned the TV after three days. They noted smaller displays can hit 10–15 ms. If you play twitch games, target lower input lag. “You can forget about PS4 races… input lag, smudging.” [Elektroda, Anonymous, post #17276530]
Are 50/60Hz panels fine, or do I need 120Hz here?
Expect 50/60Hz panels in the named non‑Samsung picks at this budget. One reply noted, “The cheapest, good 120Hz TV is currently Samsung 55MU7002.” If you exclude Samsung, plan around 50/60Hz and choose based on responsiveness. [Elektroda, Ludwik XVI, post #17276435]
What did “first class input lag” mean in this thread?
Quote: “In the first class of Input Lag, the differences are not important.” The poster referred to a low‑latency group where small gaps felt negligible during demos. Treat it as a practical threshold for acceptable responsiveness. [Elektroda, Anonymous, post #17279102]
Do Philips 55PUS6262 or Android TVs still freeze or hang?
One participant saw repeated reports that the 55PUS6262 “often hangs,” especially with frequent setting or app changes. They expressed concern that active use could trigger more frequent lockups than ratings imply. Verify stability if you multitask on TV apps. [Elektroda, Anonymous, post #17276341]
Has Philips stability improved according to owners?
A later reply pushed back on old complaints. “These models are very well prepared in terms of components.” They advised taking distance from past issues and checking current units yourself or via recent videos. [Elektroda, lesmian45, post #17338674]
How about Philips durability and long‑term quality?
Another user reported their Philips failed after three years and went to scrap. They replaced it with a cheaper brand and felt the new set was easier on the eyes. Their verdict was blunt: “No more Philips.” [Elektroda, adse, post #17343895]
Which budget models and prices were suggested early on?
Suggested options included Philips 55PUS6262 (~2,199 PLN), TCL 55S7906 (~1,999 PLN), Thomson 55UC64 (~2,399 PLN), TCL 55P6046 (~2,399 PLN), and Hitachi 55HZT66 (~2,399 PLN). Use these as price anchors when comparing. [Elektroda, Anonymous, post #17276253]
Is HDR worth chasing on these sets?
One experienced poster downplayed it: “HDR is an artificial creation like 3D,” adding that few films were available. Their advice was to focus on overall picture quality and features you will use over time. [Elektroda, Anonymous, post #17277798]
How do I test input lag and motion quickly at home?
  1. Connect a PC via HDMI and display the desktop.
  2. Move the mouse and compare cursor delay against a monitor.
  3. Launch a fast, dynamic game and assess control feel and motion.
    “Move your mouse… then turn on some dynamic game” to feel latency differences. [Elektroda, Anonymous, post #17278466]
Should I trust online reviews?
A seller cautioned that many online opinions come from “paid haters.” They suggested prioritizing verified‑purchase reviews and brief hands‑on checks. Quote: “The easiest way [is] the TV bought, confirmed by purchase.” Use this to filter noise when shortlisting. [Elektroda, Anonymous, post #17276553]
Can a budget TCL beat a pricey Samsung in perceived picture?
One buyer compared a 65‑inch Samsung (~10,000 PLN) to a TCL U55S7906 in their bedroom and preferred the TCL image. They added, “The Witcher game is pure pleasure with such a matrix.” Perceived quality can exceed price tiers for some viewers. [Elektroda, Anonymous, post #17276471]
Any app‑setting limitations on TCL to know?
Yes. A TCL owner reported you cannot change picture settings inside Netflix. You must exit the app to access image and sound options. They called this the “only drawback” in daily streaming use. [Elektroda, Anonymous, post #17276471]
Is Hitachi 55HZT66 easy to find?
The thread author could not find the 55HZT66 in stores and found almost no user opinions. That suggests limited availability at the time and minimal community feedback. [Elektroda, Anonymous, post #17276341]
Any later TCL deals worth noting from the thread?
A later post flagged TCL 55P60 at 2,299 PLN and TCL 55DP660 at 2,499 PLN, with a free full package mentioned. Keep these figures in mind when price‑matching. [Elektroda, Anonymous, post #17351205]
How long should I plan to keep the TV?
One contributor advised focusing on image quality and features you will use for about eight years. They framed TV upgrades on that cadence rather than chasing transient features. [Elektroda, Anonymous, post #17277798]
