Best 50-inch TV under 2500 PLN for gaming & sports: Samsung UE50MU6172 worth it?
crycha6 4275 14
Is the Samsung UE50MU6172 worth buying as a 50-inch TV for gaming and sports at a 3–6 m viewing distance?
The UE50MU6172 is considered a decent cheap Samsung 4K model, but the thread’s main advice is to go bigger than 50 inches for your distance. At 3–4 m, 55 inches is recommended as the minimum, and at 5–6 m even 65 inches is suggested, so 50 inches is seen as too small [#17143331][#17143451] The strongest recommendation is the Samsung 55M5672: a very good Full HD TV with a VA panel and high contrast, and the posters say you won’t really notice much 4K benefit at those distances anyway [#17143767] They also say there is nothing cheaper worth recommending in 55 inches, and the 55M5672 was sometimes available for 1999 PLN [#17143767] Philips 55PUS6262 is discouraged because of IPS/poor contrast, and HDR is described as ineffective on cheaper TVs below about 5000 PLN [#17144302]
  • #1 17143182
    crycha6
    1. How far are you sitting from the TV screen? 3-4m
    2. Are you sitting in front of the screen or sideways to the screen? directly
    3. What TV do you currently have? Old corpse
    4. What brand do you prefer? Okay :D
    5. What size TV are you looking for? 50 inches around
    6. What signal and devices will be connected to the TV? In the future xbox
    7. What kind of programs do you watch most often? Sport, series
    8. Will you play games, and if so on a console or a PC? Console
    9. Will you be actively using the TV's SMART system? Yes
    10. Do you watch in the evenings or during the day? evenings
    11. How much money can you spend on buying a TV? Up to 2500
    I was thinking about Samsung UE50MU6172. Is it worth it
  • #2 17143331
    Ludwik XVI
    Help: 1325
    Rate: 788
    Good, cheapest 4k model from Samsung. In total after a year, you can safely say that the MU series are successful TVs.
    At 3-4 m, rather 55 inches is the minimum.
    I would bet on 55M5672
  • #3 17143387
    crycha6
    I was wondering if 50 inches would be too big for such a small room and you tell me about 55 inches :D
    The thing is that the room is 15m2 and I want to watch from the bed which will be about 5-6m away but also from smaller distances.
    Do you still think it's better 55?
  • #4 17143451
    Ludwik XVI
    Help: 1325
    Rate: 788
    As you say 5-6m is a minimum of 65 inches.
    I wouldn't really go below 55.
  • #5 17143607
    crycha6
    And this 55 inch 55M5672 is your shot do you know this TV and are you sure it's good?
    EDIT: Even if he is FullHD and what is my eye on 4K?
    EDIT2: And something cheaper 55 inches worth recommending?
  • #6 17143767
    Ludwik XVI
    Help: 1325
    Rate: 788
    I know very good FHD tv. Matrix VA, high contrast. I don't think anything better FHD (except OLED A7) came out in 2017.
    http://www.benchmark.pl/testy_i_recenzje/samsung-55m5672-test.html
    At these distances you won't get much at 4k anyway. The eye will not notice the difference from such a distance.
    There is nothing worth recommending, cheaper than 55M5672.
    On promotions it was available for 1999 PLN (Saturn, MM)
    For 2600 PLN was recently Panasonic 55EX633e - good tv but probably already returned to the price of 2999 PLN ...
  • #8 17143952
    crycha6
    And how much impact does the lack of HDR have?
    And if I had to choose between my Samsung and Philips 50PUS6262 which is better?
    EDIT: Oh, and this Philips is also 55 inches, what do you think?
  • #9 17144003
    barteksmrek
    Help: 89
    Rate: 224
    Don't take philips.
  • #10 17144009
    crycha6
    Why so ?
  • #11 17144015
    barteksmrek
    Help: 89
    Rate: 224
    Why
  • #12 17144041
    crycha6
    Don't take Phillips? Samsung better?
  • #13 17144302
    Ludwik XVI
    Help: 1325
    Rate: 788
    Philips 55Pus6262 is a chapel on IPS. I would certainly not buy.
    50pus6262 is better now, because on VA with good contrast.
    With that Philips has had a lot of mishaps, sells, shortages, so I have these TV on censored. I would not buy.
    HDR starts on TV from around 5,000 PLN. All cheaper brightness is too low to show the HDR effect. Art for art. Senselessness.
  • #14 17144447
    barteksmrek
    Help: 89
    Rate: 224
    Buy LG or Samsung. Samsung is more expensive.
  • #15 17145972
The discussion revolves around finding the best 50-inch TV under 2500 PLN suitable for gaming and sports, with a specific focus on the Samsung UE50MU6172. Users suggest that for a viewing distance of 3-4 meters, a 55-inch model may be more appropriate, with recommendations for the Samsung 55M5672 and alternatives like the LG 49LJ594V. Concerns about the lack of HDR in lower-priced models are raised, and Philips models are generally discouraged due to quality issues. The consensus is that while 4K is desirable, at the specified distance, the difference may not be noticeable. Other models mentioned include Thomson 55UC64 and TCla 55P6046, both priced at 2399 PLN.
TL;DR: At 3–4 m, 55 inches is the minimum; "At 3-4 m, rather 55 inches is the minimum." UE50MU6172 is a decent cheapest 4K Samsung, but 55M5672 FHD may fit better at that distance. [Elektroda, Ludwik XVI, post #17143331]
Is the Samsung UE50MU6172 worth it under 2500 PLN for gaming and sports?
Yes. It’s the cheapest 4K Samsung from the well‑regarded MU series. But at 3–4 m, 55 inches will suit you better. The advisor specifically recommends Samsung 55M5672 for that viewing distance. [Elektroda, Ludwik XVI, post #17143331]
What TV size should I choose if I sit 3–4 meters away?
Go 55 inches minimum. "At 3-4 m, rather 55 inches is the minimum." A 50-inch will feel small at that distance. [Elektroda, Ludwik XVI, post #17143331]
What size should I pick if I watch from 5–6 meters?
Choose at least 65 inches. "5–6 m is a minimum of 65 inches." The advisor also says not to go below 55 inches. [Elektroda, Ludwik XVI, post #17143451]
Does Full HD still make sense versus 4K at these distances?
Yes. From these distances, 4K brings little visible improvement. "The eye will not notice the difference from such a distance." Consider Samsung 55M5672 FHD. [Elektroda, Ludwik XVI, post #17143767]
Is Samsung 55M5672 a good model for this budget?
Yes. It’s a very good FHD TV with a VA panel and high contrast. The advisor ranks it top among 2017 FHD, aside from OLED A7. It dropped to 1,999 PLN during promotions. [Elektroda, Ludwik XVI, post #17143767]
Is there anything cheaper than 55M5672 worth recommending?
No. The advisor states there’s nothing worth recommending cheaper than the 55M5672. Watch for promotions on that specific model. [Elektroda, Ludwik XVI, post #17143767]
Which 55-inch 4K models around 2,399 PLN offer strong smart features?
Look at Thomson 55UC64 and TCL 55P6046, both around 2,399 PLN. Philips 55PUS6262 also sits there. These options add voice support, stronger multimedia, and more apps. [Elektroda, Anonymous, post #17145972]
Should I buy Philips 55PUS6262?
Skip it if you value deep contrast. It uses an IPS panel here, which the advisor criticizes. He would not buy that model. [Elektroda, Ludwik XVI, post #17144302]
Is Philips 50PUS6262 better than the 55-inch Philips?
The 50-inch version uses a VA panel with good contrast. However, the advisor flags Philips for mishaps, service issues, and shortages, and would avoid it. [Elektroda, Ludwik XVI, post #17144302]
How much does HDR matter under 2500 PLN?
Very little. Brightness in this class is too low to show HDR’s effect. "HDR starts on TV from around 5,000 PLN." Treat budget HDR as a checkbox feature. [Elektroda, Ludwik XVI, post #17144302]
Is LG 49LJ594V a viable alternative in this budget?
Yes. One member recommends LG alongside Samsung and points to the LG 49LJ594V. He even owns two units, indicating satisfaction. [Elektroda, barteksmrek, post #17143781]
Is Samsung generally pricier than LG in this segment?
Yes. The recommendation was to buy LG or Samsung, noting that Samsung costs more. Factor that into your deal hunting. [Elektroda, barteksmrek, post #17144447]
How do I quickly choose the right screen size?
  1. Measure your viewing distance.
  2. If it’s 5–6 m, choose at least 65 inches.
  3. Avoid going below 55 inches for comfortable viewing. [Elektroda, Ludwik XVI, post #17143451]
