[Solved] Unlocking Sony Xperia E5 With Forgotten PIN - Available Methods and Issues Encountered
rumcajs2003 5853 4
  • #1 17283557
    rumcajs2003
    Rate: 15
    Sony Xperia E5 - the child has forgotten the phone pin password.
    I have already studied some internet, among others this subject:
    https://www.elektroda.pl/rtvforum/topic2989158.html
    * # * # 7378423 # * # * - doesn't work
    Xperia Companion - message:
    Flashtool - message:
    I started the phone in safe mode, but it did nothing for the above mentioned programs.
    I don't care about files.
    Any ideas?
    nutergsm
    Help: 1034
    Rate: 1665
    Upload the firmware with flashtol by connecting the phone in flash mode.
  • #3 17283662
    rumcajs2003
    Rate: 15
    I will ask for instructions on how to connect this model in flash mode. Because I search on the web, he combines, but I get a message about a blocked phone OR to connect the phone.
    sagem90
    Help: 22
    Rate: 85
    The phone is switched off, you connect the computer with the volume down key.
  • #5 17283821
    rumcajs2003
    Rate: 15
    And that's what I do.
    Earlier I downloaded "Xperia_Flash_Tool_Setup", which after installation is called "Emma" version 2.18.7.201805171612.
    I am currently downloading "flashtool-0.9.25.0-windows.exe" 120.87 MB. Maybe it's a completely different program ...
    Added after 51 [minutes]:
    Thank you for your help.
    If this does not break the rules, then this link is a good instruction on what and how:
    https://www.xperiasite.pl/forum-94/announceme...wgrywanie-oprogramowania-programem-flashtool/
    Everything works.
