Sony Xperia T3 - Forgotten Screen Lock Code Solution: Factory Reset & Sony Companion Issues
9009 12
How can I remove the screen lock code from a Sony Xperia T3 when Sony Companion gives an error?
Use Xperia Companion’s repair function to reinstall/reset the phone; in the thread, that solved the lock issue [#16286809] A factory reset will also remove the screen lock, but after reboot an FRP lock may appear [#16284775] Trying to force recovery mode with power + volume key combinations usually does not help on this Sony model, because most Sony phones do not have a recovery menu [#16285144]
  • #1 16284771
  • #2 16284775
    wlodiWNL
    Rate: 54
    Restoring the factory settings will solve the problem.
    Link to the guide
    It is possible that after the reboot, the frp lock will pop up but not necessarily.
  • #3 16284955
  • #5 16284982
  • #7 16285018
  • #8 16285053
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    TomekKrk94 wrote:
    colleague has sold me cheap Sony Xperie T3
    If you bought it cheaply, it is not better to remove this lock on the website, because if you start combining it yourself, later repair can be much more expensive.
  • #9 16285069
  • #10 16285114
    Przemek2011
    Help: 15
    Rate: 81
    On the phone off, hold:
    power button and volume down button
    or
    power button and volume button up
    or
    power button and volume button up and down.
    One of these combinations will allow you to start your phone in recovery mode and there you will be able to choose the factory reset or similar option. After selecting this option, the phone will be reset and the block will be removed.
  • #11 16285126
  • #12 16285144
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    This model and the majority of Sony does not have a recovery option, please let my colleague think about it before he writes something next time.
  • #13 16286809
The discussion revolves around unlocking a Sony Xperia T3 that is locked due to a forgotten screen lock code. Users suggest performing a factory reset as a potential solution, although there are concerns about the possibility of encountering a Factory Reset Protection (FRP) lock afterward. Some users attempted to use Sony Companion for repairs but faced errors. Various methods to enter recovery mode were discussed, including combinations of power and volume buttons, but it was noted that the Xperia T3 may lack a recovery option. Ultimately, the successful solution involved using Xperia Companion to repair the device.
