[Solved] Sony Xperia XA F3111: Remove FRP Lock Using Setool - Step-by-Step Guide
Rekin1970 7899 3
  • #1 16965785
    Rekin1970
    Rate: 58
    As in topic m, it can be removed with setool.
    marcin7904
    Help: 138
    Rate: 257
    You will not do Setool and there is probably no FRP equipment from Sony, unless I'm wrong.
    Here you have some video, but the question is will it work.
    zolwik1985
    Help: 23
    Rate: 22
    Hello. I did it this way and with the equipment Link
  • #4 17161613
    Rekin1970
    Rate: 58
    I gave the phone back not done. No way worked.
