Renault Clio IV - The symbol of the paintwork in the selection of parts.
kazo.m 11319 5
  • #1 17287467
    kazo.m
    Help: 16
    Rate: 96
    I have to replace a door on a 2015 Renault Clio IV.
    Searching for the VIN number, I found the TED69 paint code.
    And here's my question, is this paint code enough to buy a part of the same color?
  • #2 17287543
    tomek4
    Help: 57
    Rate: 100
    If the paint code is correct, it is enough
  • #3 17287639
    kazo.m
    Help: 16
    Rate: 96
    I checked the car with a varnish meter and it was definitely not painted, but the question is, is the paint code missing several shades?
  • #5 17290629
    kazo.m
    Help: 16
    Rate: 96
    Thank you very much for your answer. Subject to be closed.
  • #6 17293896
    genek1000
    Help: 289
    Rate: 1057
    tomek4 wrote:
    If you buy in the original it will be ok. There were no shades of this and each shade has a different code
    Well, unless the car is used in Poland and the door comes from Southern Italy or France, and you can already see a different shade of discoloration from the sun :cry:
