[Solved] Citroen Berlingo II 2010 - Where can I find the lakieu number?
fonexpl 20484 2
  • #1 17291924
    fonexpl
    Level 4  
    Rate: 68
    Hello, I need information about my varnish number in my Berlingo. Where can I find a sign on which I can find it? There is no door, there is no on the flap.
    Added after 17 [minutes]:
    I only found something like this in the engine compartment.
    • Citroen Berlingo II 2010 - Where can I find the lakieu number? IMG_20180623_123226[1].jpg (2.75 MB) You must be logged in to download this attachment.
    Krzys55
    Help: 89
    Rate: 303
    Create an account here http://service.citroen.com/socle/?start=true, log in, enter VIN and you will see all information about the car.
    Added after 4 [hours] 6 [minutes]:
    If you can't create an account, send VIN to PW. I can check you out.
  • #3 17336388
    fonexpl
    Level 4  
    Rate: 68
    It turns out that the varnish number is on the post, and I looked on the inside of the door. Topic is closed.
