Citroen Berlingo II 1.6 - Citroen Berlingo 1.6 key programming
magik25 10677 4
  • #1 17004576
    magik25
    Hello. I lost the 2nd and the last key for Citroen Berlingo II from 2009. In Dealership they will make such a key for me, but to program it I have to provide them with a car. Can you do it in some other way, e.g. by removing a control unit?
  • #2 17004739
    adamus202
    Rate: 24
    Theoretically, the key can be programmed by removing the engine control unit and the central module (BSI).
    But I doubt you will easily find such a person prepared for it. And removing such a BSI module is also not that simple and pleasant. In your place, the easiest and fastest way would be to tow the car to an authorized service station or look for a person to program a new key on the spot.
  • #3 17005085
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    adamus202 wrote:
    you can program the key by removing the engine control unit and the central module (BSI)
    There is no problem with adding the key to this car "on the table".
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #4 17005106
    magik25
    However, it will tow away because programming the key in the ASO is PLN 130, so I doubt if someone will do it cheaper
  • #5 20937014
    pawlo2242
    Rate: 8
    Good morning, I have a request, I only have 1 key for Berlingo 2010 and I would like to code the second one. What do I need to code because I don't have this pin, I have a second-hand car and I would like to take it to a good mechanic, it's a long way to go to the dealership or Lexia will figure it out. Thank you for your advice.
