Samsung Galaxy A5 2017: How to Turn On Phone with Non-Working Power Button? Alternative Solutions
niktwazny. 15048 6
  • #1 17292699
    niktwazny.
    Hello, the question is short, is there a way to turn on the phone when the power button is not working? some people write that you press the volume buttons at once but it doesn't work, please help :(
  • #2 17292739
    dr.master
    Help: 518
    Rate: 927
    You can try the + volume button and the key at the bottom of the screen and insert the charger.
    Then select reboot from the menu and it should boot normally.
  • #3 17292815
    niktwazny.
    unfortunately I don't see the menu when I do
  • #4 17292858
    adam5525
    Try to press vol- and vol + at the same time and connect to the charger. I'm not sure if it will work with this model.
    You can definitely boot via adb by typing reboot. You will need a computer and minimal adb and fastboot drivers.
  • #5 17292933
    niktwazny.
    You can definitely boot via adb by typing fastboot reboot. You'll need a computer and minimal adb and fastboot drivers.
    Well, unfortunately, I tried the volume buttons a few times at a time, but nothing of it .. And as for this method with the computer, I will try it, but I have to first see what and how, i.e. these drivers because I'm green in it
  • #7 17293852
    blahfff
    Help: 1036
    Rate: 1301
    adam5525 wrote:
    A strange way, but it works, I checked, you just need to quickly remove and insert the batteries.
    This model does not have a removable battery, so without disassembling the phone (and this could help fix the switch) it cannot be done.
    It is certainly not possible to start the phone in this way because neither ADB nor fastboot (this mode is not available at all in Samsung) does not work on a turned off phone.
    The first advice was generally good, but you should hold down vol- + home + power (if power does not work the same vol- + home and plug in the charger) and on the first screen again vol- to restart instead of launching the download mode. Not every play will enter download mode if the switch does not work.
    You can try a "plug" which will force the download mode after connecting (you can buy "unbrick jig samsung" for pennies or do it yourself), but then the phone will immediately enter the download and you have to figure out how to force restart from this level.
The discussion revolves around methods to power on a Samsung Galaxy A5 2017 when the power button is non-functional. Suggested solutions include pressing the volume up and home buttons while connecting the charger, although success may vary. Some users mentioned using ADB commands via a computer, but this requires prior setup of drivers. Another unconventional method involves quickly removing and reinserting the battery, but this is not applicable as the A5 2017 has a non-removable battery. The conversation highlights the limitations of the device's recovery options, including the inability to access download mode without a functioning power button.
