Samsung A5 2017 Not Charging or Turning On - Battery & Connection Issues Solutions
Golimek 10218 8
  • #1 16635257
    Golimek
    Hello, I bought a Samsung phone before yesterday, 2017 when the battery went out, I connected it, but nothing happens, does not land or turn on, does anyone know what to do?
  • #2 16635279
    badboy84
    Help: 1198
    Rate: 1487
    Check on another cable / charger and advertise.
  • #3 16635314
    Golimek
    Exactly the worst thing that I do not have because input 3.0 is
  • #4 16635355
    badboy84
    Help: 1198
    Rate: 1487
    Then connect the cable to the laptop or computer and check if it will charge. If it means that the charger is damaged, the cable itself would be new and damaged it is unlikely. Check also on another contact. If the phone is new, the complaint is one way or another. In general, the batteries do not like them being too discharged. It's best to charge around 15%.
  • #5 16635394
    slavio...
    Rate: 22
    Plug in and leave for 5 hours for the battery to take up its capacity. The phone is probably discharged and the battery has too little voltage to turn on the phone. Connect and leave it simply.
  • #7 16635504
    beo
    Level 37  
    Help: 298
    Rate: 238
    Why do you think so? It seemed to me that this type of cell can not be discharged +/- less than 3V, but that less than 15% would have anything to do? Let's stop duplicating nonsense and calculating about cycles. Load up to 100% and use up to 0% as needed and that's it.
  • #8 16635518
    Golimek
    I plugged in the laptop, nothing is displayed so it probably guilty of the cable because the charger works when I take a different cable.
  • #9 16635708
    rozales
    Help: 43
    Rate: 160
    Either cable or telephone.
    Go to some point GSM will check you for free.
The discussion revolves around a Samsung A5 2017 that is not charging or turning on after the battery was depleted. Users suggest troubleshooting steps including testing with different cables and chargers, connecting to a laptop or computer to check for charging, and allowing the device to charge for an extended period to recover from deep discharge. There are recommendations to purchase an adapter and check the power supply, as well as advice to visit a GSM service point for a free check-up. The conversation also touches on battery discharge limits and the importance of not letting the battery drop below certain voltage levels.
