Samsung Galaxy A5 SM-A500FU: Charging Issues, Emergency Start, Hard Reset, and Power/Home/Button
tomasz90p 10026 7
  • #1 16451511
    tomasz90p
    Hello, The patient is a Samsung Galaxy A5 SM-A500FU, the phone some time ago stopped working, did not respond to the charger, etc. managed to start by emergency start and resetting Hard reset, regained its life, but again, something went crazy and fell. Once I succeeded in switching it on to the reset option via Power / - / home and turned it off again. I suspect that this is something with charging / feeding because after a while lying down and fires again as if the current is cut off somewhere, it does not heat up when it is plugged into the charger. On the site, like on the "plate for replacement" service, I've been looking for damaged phones with a disc, but I want to save my battery from some phone.
    I will add that; I have a charger + usb cable separately and when it is hooked only to the network it sounds bzzzzz, and when we plug in the phone stops, I do not know if someone once pointed to this but I eg rozkminiłem slightly slightly picked up the USB charging port on the tablet, I was pulling the plug and once buzzed and once charged. And when connecting to Samsung, the sound is like nothing was connected.
  • #2 16451561
    jackq
    Rate: 26
    You tried on another charger or connect a cable to your computer and check if it loads then and whether the PC will detect this phone at all.
    You can still try to improve the February charging slot.
  • #3 16451568
    tomasz90p
    jackq, hooked under everything :)
  • #4 16451572
    nutergsm
    Help: 1034
    Rate: 1665
    If the service stated a damaged disc, what can we help here? Check on a different battery you can always but I suspect that the service has already done so.
  • #5 16451596
    tomasz90p
    Well okay, but when he came back from the site with papers about the record, at home he was started by me using power / - / home and he worked for some time, they have not checked it, the easiest way to replace the most: /
  • #6 16451610
    jackq
    Rate: 26
    I would try to recharge it as much as I can, or as I wrote, correct the February at the nest. If it is possible to enter the download mode, then add a new soft odinem.
    The services often do this, exchange half a phone and preferably beyond the warranty at your expense.
  • Intermittent motherboard damage can cause sporadic startup
    #7 16461432
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Your colleague, the Nuter has already answered you. And you insist. "Damaged motherboard is also one that can work for 1 day and not work for 6 days and vice versa.
  • Boot recovery via Power/Volume Down/Home and board replacement caution
    #8 16461624
    bogdan2491
    Help: 52
    Rate: 97
    In this model, the most expensive thing is the display, an efficient board should be easily bought from a phone with a damaged display less than 100 PLN. Only the issue of exchange, which I would not experiment with in my home, because access to the phone is possible only after pasting the display, which is very easy to damage and as I mentioned is the most expensive of the whole phone.
The discussion revolves around charging issues with the Samsung Galaxy A5 SM-A500FU, where the device intermittently fails to respond to charging and has experienced power cycling. The user successfully performed an emergency start and hard reset, temporarily reviving the phone, but the problem recurred. Suggestions include testing with different chargers and cables, checking the USB charging port, and considering a battery replacement. There are concerns about a potentially damaged motherboard, which could lead to erratic behavior. The cost of repairs is highlighted, particularly the expensive display component, which complicates DIY fixes.
