xiaomi redmi 5 plus doesn't fully charge and turns off for no reason
pawel2066 6174 7
  • #1 17292957
    pawel2066
    Hello, I have a problem with a xiaomi redmi 5 plus 4/64 phone, the phone does not charge until the end usually stops at 97% but this number can change although it does not fall below 90%. The second problem is that the phone can turn off for no reason (usually with a lower battery percentage) and cannot be turned on until it is connected to charging.
  • #2 17293028
    makosuu
    Help: 369
    Rate: 370
    The second symptom suggests a battery.
  • #3 17308126
    pawel2066
    I was able to charge the phone to 100% by method
    after charging to the max, disconnect the phone from charging and turn it on
    plug it in again for charging
    charge to the max
    disconnect
    turn off and recharge to the max
    and up to 100%
    As for turning it off, I discovered that it does it with 30% battery and after turning it on 0%, besides, the phone withstands less as much battery as it should, so the full battery cycle closed between 30 and 100%
  • #4 17308132
    makosuu
    Help: 369
    Rate: 370
    Do you want to suggest that the phone with which you need to make such circuses can be considered functional?
  • #5 17309251
    pawel2066
    And what does this add to the topic that you had to write it?
  • #6 17309724
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    As for self-deactivation, remove the clapper at the back and press the battery connector. Recently, I had several pieces of this model where such circuses happened to clients. It was enough to plug in and unfasten.
  • #7 17309999
    pawel2066
    The problem of spontaneous shutdown is solved, there is also a problem with the fact that the device turns off at 30% ...
  • #8 17821122
    lukasz921
    Rate: 35
    How did you solve this problem?
✨ The user reports issues with their Xiaomi Redmi 5 Plus (4/64) not charging fully, typically stopping at around 97% and turning off unexpectedly, often at around 30% battery. Responses suggest that the battery may be faulty, and one user describes a method to charge the phone to 100% by repeatedly disconnecting and reconnecting the charger. Another response recommends checking the battery connector by removing the back cover, as similar issues have been resolved by reseating the connection. The problem of the phone shutting down at 30% is acknowledged, indicating a potential battery calibration issue.
