How to install the Smart IPTV application on a Thomson 42UZ7766 TV?
pacak24 31245 12
How can I install Smart IPTV on a Thomson 42UZ7766 TV to watch channels, if there is no app store on the TV?
Smart IPTV itself is probably not available on this Thomson TV and may never be, because it is dedicated to LG and Samsung, but you can use SS-IPTV or OTTPlayer instead [#17958550] For SS-IPTV, open the TV browser, go to app.ss-iptv.com, accept the terms, skip configuration, open settings, and note the connection code [#17958550] Then enter that code on the SS-IPTV management page at http://ss-iptv.com/en/users/playlist/url to add the TV and manage your m3u playlist there [#17958550] For OTTPlayer, open widget.ottplayer.es in the TV browser, then enter your login details in the app settings, upload the m3u file on the website, and refresh the TV app so the playlist appears [#17958550] The same reply notes that SS-IPTV has better graphics and EPG can also be configured on the website [#17958550]
  • #1 17312464
    pacak24
    Rate: 52
    I live in Germany and I have a Thomson 42UZ7766 TV. I would like to install the Smart IPTV application on it to watch Polish channels. The TV has Smart TV support, has applications like Facebook or YouTube, but I can't find a program anywhere to download the Smart IPTV application. There is nothing similar to the Play Store. Maybe someone has encountered such a problem or has such a TV and managed to install Smart IPTV and is able to help me.
  • #2 17867833
    ziom309
    Rate: 28
    I can help.
  • #3 17958360
    lasiek
    Could I also ask for help?
  • #4 17958550
    ziom309
    Rate: 28
    probably so much that smart iptv is not on this TV and probably will not be because it is dedicated to LG and Samsung TV
    but you can run SS-IPTV and ottplayer on thomasson
    to ss-iptv you have to enter the browser on tv and enter app.ss-iptv.com
    and it should start after a while
    - you must accept the regulations
    - then skip on configuration
    - enter the settings
    - language change (depending on your needs)
    -and in the box connection code get the code
    - rewrite the code on the page [url=http://ss-iptv.com/en/users/playlist/url] to add tv
    on the abovementioned website, the m3u list is managed
    with ott player it is similar
    enter from the tv browser on the widget.ottplayer.es website and click ok
    only to manage the list you have to log in to [url=www.ottplayer.es/url]
    login details must be entered in the settings when ottplayer starts
    upload a m3u file on the page and refresh it on tv and it should appear
    Ss-iptv Management Website
  • #5 17958781
    lasiek
    I have grasped running you are great. Some pruning but overall it's ok. Thank you
  • #6 17958815
    ziom309
    Rate: 28
    the fact that it is cut may affect the internet connection of the tv to the router and the provider itself
    I use ss-iptv looks graphically better and epg you can do it on the website as you write something when I get up I will help you
  • #7 18274273
  • #8 18274283
    ziom309
    Rate: 28
    Hello how can I help ??
  • #9 18274400
  • #10 18274406
    ziom309
    Rate: 28
    maybe something is wrong with the list
    ie linikja has a mistake I would have to see it, and preferably download about file and upload file
  • #11 18274411
  • #12 18274413
    ziom309
    Rate: 28
    and vlc is on the computer
    please write to pw
  • #13 18282344
    Marta2704
    Rate: 10
    Hi, I have a tv Thomson 55UD6696 and I can't deal with ss iptv. I can ask for help. I watch on the laptop wp remote control and I would like to on tv. My search engine doesn't search for anything except ss iptv, which I wouldn't enter. I am asking for a hint.
The discussion revolves around installing the Smart IPTV application on a Thomson 42UZ7766 TV. Users express difficulty in finding the app, as it is primarily available for LG and Samsung TVs. Alternative solutions include using SS IPTV and OTT Player. Instructions for SS IPTV involve accessing the app via the TV's browser, accepting regulations, and entering a connection code from the SS IPTV website to manage M3U playlists. Users also report issues with loading remote content and seek assistance with activating Polish television channels on SS IPTV. The conversation highlights the need for proper playlist links and troubleshooting steps for successful installation and operation.
TL;DR: Thomson 42UZ7766 lacks Smart IPTV; use 2 alternatives (SS IPTV, OttPlayer). "smart iptv is not on this TV". Install via the TV browser, get a connection code, then add your M3U online to stream Polish channels. [Elektroda, ziom309, post #17958550]
Why it matters: It helps Thomson owners watch IPTV despite missing app stores, using browser-based setup and web playlist management.
Can I install the Smart IPTV app on a Thomson 42UZ7766?
No. Smart IPTV isn’t supported on this model. As one expert noted, "smart iptv is not on this TV". Use SS IPTV or OttPlayer instead. Both run through the TV’s web browser rather than a native app store. [Elektroda, ziom309, post #17958550]
How do I install SS IPTV on my Thomson without an app store?
Use the TV’s browser with the SS IPTV web app.
  1. Open the TV browser and go to app.ss-iptv.com, then accept the terms.
  2. In SS IPTV settings, select Get Code and note the connection code.
  3. On a computer, open ss-iptv.com/en/users/playlist, add your TV with the code, then add your M3U. Open SS IPTV on the TV to see your playlists. [Elektroda, ziom309, post #17958550]
How do I add and manage an M3U playlist in SS IPTV?
Pair the TV using the connection code, then manage playlists on ss-iptv.com/en/users/playlist. Add your M3U link there, save, and reopen SS IPTV on the TV. The list should appear after a refresh. You maintain the playlist from the website, not the TV. [Elektroda, ziom309, post #17958550]
OttPlayer on Thomson: how do I set it up?
Open widget.ottplayer.es in the TV browser and press OK. In OttPlayer settings on the TV, enter your account login. Then, on a computer, log into ottplayer.es and upload your M3U file. Refresh OttPlayer on the TV and your playlist should load. [Elektroda, ziom309, post #17958550]
Why do I get "remote content could not be loaded" in SS IPTV?
It indicates the IPTV list link is wrong. Fix the URL in the SS IPTV website or upload a clean M3U file instead. Then refresh the app on the TV to retry loading. This error commonly points to a malformed or incorrect playlist link. [Elektroda, ziom309, post #18274406]
How can I test my playlist link before using the TV?
Open the M3U link or file in VLC on a computer. If channels play, the list is valid. If they fail, the list or URL is broken and needs correction before adding it to SS IPTV or OttPlayer. Testing on a PC is fast and isolates TV issues. [Elektroda, ziom309, post #18274413]
Video stutters or buffers—how do I fix it?
This usually comes from the TV–router link or your ISP. "may affect the internet connection of the tv to the router and the provider itself". Power-cycle your router and TV, verify signal strength or cabling, and test streams again. If other apps lag too, contact your ISP. [Elektroda, ziom309, post #17958815]
Can I configure EPG with SS IPTV on this TV?
Yes. After pairing the TV, configure EPG on the SS IPTV website tied to your playlist. The user who tested it confirmed the EPG can be set online. Save changes and reopen the app on the TV for the guide to populate. [Elektroda, ziom309, post #17958815]
SS IPTV vs OttPlayer—what should I pick?
Try both with the same playlist. One experienced user prefers SS IPTV for its look and EPG options: "I use ss-iptv looks graphically better". Keep whichever feels smoother on your network and easier to manage. [Elektroda, ziom309, post #17958815]
My Thomson 55UD6696 can’t find SS IPTV—what should I do?
Skip search. Manually enter app.ss-iptv.com in the TV browser to launch SS IPTV. Then use the connection code to pair and manage playlists from the website. This avoids relying on an app catalog. [Elektroda, ziom309, post #17958550]
Does the Thomson 42UZ7766 have Google Play Store?
No. The owner reported no Play Store or similar catalog on this model. Instead, use the built-in web browser method to run SS IPTV or OttPlayer and manage content from their websites. [Elektroda, pacak24, post #17312464]
What internet speed do I need for IPTV streams?
Typical streaming guidance: about 3 Mbps for SD, 5 Mbps for HD, and 25 Mbps for 4K UHD. If multiple devices stream at once, add headroom. These targets help prevent buffering during live IPTV playback. [Netflix, 2024]
How do I refresh or update my playlist on the TV?
Upload or update your M3U on the service website (SS IPTV or OttPlayer). Then refresh the app on the TV; the updated list should appear. If it doesn’t, re-open the app or re-pair using a fresh connection code. [Elektroda, ziom309, post #17958550]
