Firmware Update for Thomson 55UA6406W TV - V8-NT67F01-LF1V378
dsamian11 1302 3
  • Expired certificate blocks Disney app installation
    #1 21702361
    dsamian11
    Can someone help me find an update for the Thomson 32HB5426 I can't install the Disney apps plus the app store doesn't have a certificate that has expired.
    Thank you in advance.
    Moderated By ArturAVS:
    3.1.14. Posting inconsistent with the topic of a forum section or discussion thread.
    Separated from topic: Firmware update for Thomson 55UA6406W TV - V8-NT67F01-LF1V378
    by ArturAVS on 28 Sep 2025 11:35
  • #2 21730917
    123b86eucom
    Can someone help me find an update for the Thomson 32HB5426?
  • #4 21829060
    michaeljamesromt
    This issue is often linked to outdated system certificates on older smart TVs. If Thomson no longer provides official firmware updates, app compatibility becomes limited. You can try checking their support site or contacting customer service directly. In some cases, using an external streaming device is the easiest solution when built-in apps stop working properly.
