FunBox 2.0 as Bridge LAN Access Point: Connect, Static IP, Disable DHCP & Compatibility
User24H 8115 2
  • #1 17348800
    User24H
    Hello. I have a question. Namely, I want to know if Funbox 2.0 can work as an access point? I would like to connect it to my router. And here another question arises, if Funbox 2.0 can work in Bridge Lan mode (I guess it's the same as access point?), Is it enough to set a static ip in FunBox and turn off DHCP?
  • #2 17356909
    kk.2000
    Help: 91
    Rate: 90
    Yes, funbox 2.0 can work as an AP and actually only that way.
    Answer to another question: funbox 2.0 does not have Bridge mode. By the way, Bridge mode is not the same what Access Point. Bridge mode would bridge an external network with an Ethernet port, using funbox as a modem, but unfortunately no fbox does not.
    But he is always a weak APek, giving no choice.
  • #3 20300995
    bruner
    Rate: 51
    I will refresh the topic. How to configure FB 2.0 to connect another router to it? What port in FB and switch it to bridge or modem mode? Or maybe just disable dhcp. FB 2.0 has a destination of 192.168.1.x where 1 is a gateway.
