[title] Best Sports Camera under PLN 300: EKEN H9R, Xiaomi Yi, GoClever Extreme, Orllo Xpro & More
AlienWarez 5862 8
  • Need advice on budget sports camera for motorcycle use
    #1 17372555
    AlienWarez
    Rate: 8
    Hello all,
    I need a sports camera for a moto. It will be mounted on a helmet or on a motorcycle. Budget up to PLN 300 (I'm just starting, if I am drawn into making "professional" films, I will think about something better).
    I know I care about the best recording quality (FULL HD is enough) and stabilization (road bike - not a cross bike).
    It doesn't need 4k etc.
    I think about:
    EKEN H9R (here the most important is the recording quality and PRICE - you can buy ali for PLN 180, allegro from PLN 230)
    Xiaomi Yi Action
    Goclever extreme pro 4k
    Iconntechs
    Orllo Xpro Touch
    Please advise - maybe SJCAM will be better in this amount? Xblitz?
    I have already looked through a lot of comparisons on YT and read, but the more I watch, the more chaos I have in my head.
    Thanks!
    best regards
  • #2 17372646
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    Generally, for two-wheelers, good image stabilization is useful. Preferably optical ("mechanical") and digital ("matrix"). It's even better to go down from 4K to FHD just to have stabilization.
  • #3 17372651
    AlienWarez
    Rate: 8
    Therefore, as I wrote above, I do not want 4K because at this price, 4K will most often be distorted.
    FHD is fine for me.
  • #4 17372669
    Level 37  
    Help: 211
    Rate: 1014
    In this price range, it's probably Xiaomi Yi Action.
  • #5 17372682
    AlienWarez
    Rate: 8
    You can watch on YT the comparison of this camera to the EKEN H9 (or add-on R - has a remote control :P )
    And give your feedback?
  • #6 17372691
    Level 37  
    Help: 211
    Rate: 1014
    Xiaomi for me a smoother image.
  • #7 17382841
    beatamycha
    Help: 32
    Rate: 55
    Personally, I have had Eken without a remote control for 2 years. Somehow, in terms of price, the most adequate. Lots of accessories available, such as: chest, belt, hand and many more to be replaced. Accessories from GO PRO to Eken are also suitable.
    As for the beginning of the adventure, it seems to be a good choice.
  • #8 17383339
    AlienWarez
    Rate: 8
    I thought so too, that's why I ordered EKEN :)
    if it annoys me, I will most likely aim for a higher shelf (GOPRO hero 2018 or higher ...)
  • #9 17383900
    beatamycha
    Help: 32
    Rate: 55
    You can always change something to a higher shelf. If I can still advise something. Because it is also important when it comes to Eken. If you buy a card, you have to be careful, some of it is incompatible. I bought a 32GB SD card from one brand, then another and there were various problems, and finally I read somewhere that if cards with high capacity SanDisk Ultra are checked. Personally, I have 32 GB. Since then, there have been no more such problems and errors with the reading or even the recording itself.
The discussion centers around selecting a sports camera for motorcycle use within a budget of PLN 300, emphasizing the need for good recording quality (preferably Full HD) and effective stabilization. The EKEN H9R and Xiaomi Yi Action are highlighted as strong contenders, with users noting the importance of image stabilization over 4K resolution due to potential distortion at this price point. The EKEN H9R is praised for its affordability and compatibility with various accessories, while the Xiaomi Yi is recommended for smoother image quality. Users also caution about SD card compatibility issues with the EKEN model, suggesting the use of SanDisk Ultra cards for optimal performance.
