Samsung Smart TV (UE40KU6400) Set-Top Box: Recommendations for Wizja.tv & WpPilot, Budget ≤300 PLN
Schaolin360 5004 2
  • #1 17372799
    Schaolin360
    I warmly welcome
    I am in possession of a Samsung Smart TV (UE40KU6400) and I would like to invest in a TV set-top box.
    My main interest is that Wizja.tv and WpPilot can be installed there
    Does anyone recommend something proven? I don't know if it's better for Android or Windows
    I would like to fit the maximum amount of PLN 300
    Thank you in advance for your help and best regards
    Android box with 4 GB RAM and 4K support recommended
    #2 17373205
    ramzes315
    Schaolin360 wrote:
    I warmly welcome
    More practical for remote operation and more energy-saving, e.g. the remote control will be an Android platform, a multitude of applications in google play, the possibility of quick and easy installation of applications, etc.
    Have a look here: https://allegro.pl/kategoria/tv-i-video-odtwarzacze-hdd-i-multimedialny-67191?order=m
    Good advice: Choose a device with an ARM processor of at least 8 cores, 4 GB of RAM and 4K support, the slower ones will be annoying with clipping etc.
    Windows will have greater freedom of action and versatility, but here you would have to use a mouse / touchpad and keyboard to control it, which will not necessarily be convenient during the screening away from the TV.
    here are some solutions, for example:
    1.small and economical terminal with good parameters as in this link: https://allegro.pl/terminal-dell-wyse-dx0q-4x...-16gb-ssd-zas-i7436377152.html?bi_s=ads&bi_m= listing% 3Adesktop% 3Aquery & bi_c = MjM1OTEzODQtZTZlMy00MjgyLWFkYjYtNjg0ZjJlNmQxMmEwAA & bi_t = ape & referrer = & proxy emission_unit_id = 18b826c9-5fa9-43e2-bd3f-b8cf292c1d87
    and drop the system (before you buy, call the seller and ask if they can sell it to you with a Windows license for refurbished devices low cost and genuine Windows :) )
    1a. You can also buy a cheaper terminal, install Linux and the Kodi overlay, but it's a lot of fun and it doesn't always work as it should, and I don't know if the platforms you mention (applications) will be available for Linux or Kodi.
    2. Compute Stick: https://allegro.pl/kategoria/kompnerzy?string...%20stick&order=m&bmatch=baseline-ele-1-2-0725
    3. a computer refurbished in a USFF casing, e.g. one of these: https://allegro.pl/kategoria/komputers?string=usff&order=p&bmatch=baseline-ele-1-2-0725
    is a slightly larger device than the others above.
    In addition, check if your TV does not have the Miracast (screen mirroring) function or a similar function that allows you to wirelessly send the image to the TV screen, e.g. from a laptop with Windows 8/10 or a phone with this function, maybe without buying additional adapters :)
  • Seeking a proven Android TV box recommendation
    #3 17373424
    Schaolin360
    Thank you so much for help!
    My TV probably has the Miracast function, but the phone's batteries are damn fast, so I think about the TV adapter.
    Edit: Although some of the applications work, I can not turn the WP remote on Tv, because it probably only works on ChromeCast and it also costs a bit, if I had to buy it separately ...
    I would probably try something with Android, I see only a few devices with 8 cores, someone may use and recommend a specific model? I can add a bit, but I would like something proven! Thanks!
