Internet TV with Delta Media Player: Device Options for Samsung Smart TVs & Android TV Box
majkimajki1983 74073 12
Can I install Delta Media Player on an Android TV box or other device to watch it on a Samsung Smart TV?
Delta Media Player can be installed on Android TV / Android boxes and Android-based MAG decoders, so using a separate Android box is the practical solution for a Samsung TV [#18487320] Specific devices mentioned as working options were Ferguson F-BOX ATV-UHD 4K and WIWA DREAM PLAYER TV [#18268326] Another user reported it working on an MX Q PRO 4K, but warned to avoid cheap counterfeit boxes because some have a different chipset, cause a green screen on HD content, and overheat [#18487320] A low-cost Android TV box from Allegro was also reported to work, though some channels may take longer to load [#19137254] One user also suggested turning off hardware image support (SR) in the app/settings if playback is not smooth [#18494966]
  • #1 18255318
    majkimajki1983
    Rate: 33
    Ultimately, I would like to watch TV from the Delta Media Player application but on the TV.
    I am looking for a device that will definitely support this application.
    I have a Samsung smart TV but he cannot install this application.
    So I wonder if it is possible to install, for example, on an Android TV box or something else that I can install this application on and connect to the TV.
    I would be grateful for any advice!
    jurek849
    Help: 23
    Rate: 80
    See Ferguson F-BOX ATV-UHD 4K, or WIWA DREAM PLAYERTV
  • #3 18270333
    majkimajki1983
    Rate: 33
    They look good, but I can't check anywhere to see if Delta Media Player can be installed. But I think I'll be tempted and buy one of them. In total, android, for a smartphone, it should also be on such an F-BOX.
    I will give a few more examples of others what do you think about this?
    https://www.ebay.co.uk/itm/Superview-Q-Box-An...-Keyboard/263780392999?epid=27024275070&hash= item3d6a896027: g: u6kAAOSwZxlc3JSA
    Harnas4
    Rate: 13
    DMP can be installed on a smart Android TV or on an Android box or Android-based MAG decoders, I personally use it on the MX Q PRO 4K but beware of fakes, there are both on our website, I have 2 devices, one bought on Allegro for 130PLN version 2 / 16GB and works fine while the second on eBay (21 EUR ;) the same version, but there is a problem with displaying HD content - green screen; / the chipset on the boards is different, so on eBay it is a fake, which in addition heats up strongly and quickly. Livevoo is more expensive and unfortunately already "swept", while DMP has been working for over 4 years (that's what I use - the former name is TV) and so far it is doing quite well. DMP can be viewed on windows, android, apple core and linux.
    It works fine on my fiber-optic internet, but sometimes there is a failure and there is no access to the service for 2-3 hours, on average, once every 2 months.
  • #5 18487378
    majkimajki1983
    Rate: 33
    Thank you for the answer, I have already purchased a tv box for the trial
    https://www.ebay.co.uk/itm/183885211473
    I installed DMP and somehow it works there only I have never had contact with such a device. For example, I often have to restart the application to switch to another channel. When watching a football match, I notice the image clipping (it is not so smooth) because I also use DMP on the Pc that I have connected to another TV and everything flashes without a problem.
    I do not know if it is the fault of the tv box or is it normal on this type of device. Because I have seen much more expensive TV boxes, can it run without a problem?
  • #6 18494966
    ocelot77
    On the Box, somewhere in the program, there is a small stamp probably HR (? - it seems in the lower right corner). Or in options. This is from the hardware image display support.
    Turn it off (SR) and it should run smoothly - it helped me anyway.
  • #7 18502186
    majkimajki1983
    Rate: 33
    I did not find this button on the tv box, nor in the settings, unless it is under a different name. I have attached photos with the settings. Internet TV with Delta Media Player: Device Options for Samsung Smart TVs & Android TV Box Internet TV with Delta Media Player: Device Options for Samsung Smart TVs & Android TV Box
    Premium account advised against due to broken streams
    #8 19058922
    Kszyhoo12
    Currently, there are only a few TV channels from the entire list that load quickly, and the rest either don't work at all or load after waiting a few minutes. Tested on all operating systems, it is also not the fault of the Internet. Nobody replies to the e-mails, the money is thrown into the mud, the entire service fell to the dogs. I absolutely advise against buying a premium account with them.
  • #9 19085767
    majkimajki1983
    Rate: 33
    But you mean the tv Box? Because I am also using DMP on my desktop pc and each channel is working fine no problems. DMP can be logged on three devices at the same time. The only problem on android is that you need to turn off the apk and turn it on again when switching channels because it hangs.
    Kszyhoo12
    It is not only about the TV Box with Android, it is the same on each platform, even when using mobile internet, so it is also not the fault of wi-fi, and more specifically of the router settings.
  • #11 19086048
    majkimajki1983
    Rate: 33
    So it's all clear.
    Thanks to everyone for the hints.
    best regards
  • Budget Android TV box works well with Delta Media Player
    #12 19137254
    kriso222
    I watch tv in delta media player on tv box with allegro for PLN 100. It is true that sometimes some channels take longer to load, but there is no tragedy (there is plenty to choose from). For PLN 20 / month, we will not find access to so many such channels anywhere. I have 20 mb / sa tv box like this: https://allegro.pl/oferta/smart-tv-box-8gb-mx...oid-7-1-9775039787?reco_id=f487560d-475e-11eb -a6e8-000af7f61b5096499e13bc806f55bd0c404f69ac7020
  • #13 19139373
    Kszyhoo12
    Channel loading problem, resolved after switching ISP. It turned out that the previous company started blocking media streaming after a few months (despite the fact that the package was unlimited), and everything else flashed without problems. As DMP was the only platform of this kind that I used, I thought it was only the fault of DMP. So I pay DMP honor.
The discussion revolves around the Delta Media Player (DMP) application and its compatibility with various devices for streaming on TVs. Users express interest in using DMP on Samsung Smart TVs but face installation issues. Recommendations include using Android TV boxes such as Ferguson F-BOX ATV-UHD 4K, WIWA DREAM PLAYER, and MX Q PRO 4K. Users report mixed experiences with DMP, noting issues like slow channel loading and the need to restart the application when switching channels. Some users suggest that performance may vary based on the device and internet service provider. Overall, DMP is confirmed to work on Android-based devices, but users should be cautious of counterfeit products.
TL;DR: Want DMP on a Samsung TV? Use an Android TV box; outages average 2–3 hours every ~2 months. "DMP has been working for over 4 years." This FAQ shows which boxes work and how to fix stutter. [Elektroda, Harnas4, post #18487320]
Why it matters: It helps Samsung Smart TV owners and Android TV box users get DMP running smoothly and avoid common pitfalls.
What devices can run Delta Media Player on a TV?
DMP runs on smart Android TV, Android TV boxes, and Android-based MAG decoders. It also works on Windows, Apple, and Linux. Pick the platform you already own or plan to connect to your TV. [Elektroda, Harnas4, post #18487320]
Which Android TV boxes do users recommend for DMP?
Community suggestions include Ferguson F-BOX ATV-UHD 4K and WIWA DREAM PLAYERTV. These Android-based devices are suitable for installing DMP. Choose reputable retailers for better support and updates. [Elektroda, jurek849, post #18268326]
Will an MXQ Pro 4K work, and how do I avoid fakes?
Yes, one user runs DMP on an MXQ PRO 4K successfully. A cheap eBay unit showed HD green screen and overheating due to a different chipset. A 2/16 GB Allegro unit for 130 PLN worked fine. Buy from verified sellers to avoid clones. [Elektroda, Harnas4, post #18487320]
How do I disable HR/SR hardware rendering in DMP on a TV box?
  1. Open DMP on your Android box and start any channel.
  2. Look for a small HR/SR badge or a toggle in player options.
  3. Turn it off, then restart playback to apply the change. [Elektroda, ocelot77, post #18494966]
DMP stutters during football how can I make motion smoother?
Disable the HR/SR hardware rendering switch shown as a small badge in the player. After turning it off, playback ran smoothly for a user. Reopen the stream after changing the setting. [Elektroda, ocelot77, post #18494966]
Why does DMP freeze when switching channels on Android?
Users report the Android app can hang when changing channels. The common workaround is to close the app and reopen it. After restarting, channels play normally again. [Elektroda, majkimajki1983, post #19085767]
Is DMP reliable? What downtime should I expect?
A long-term user reports solid performance with rare outages. Expect 23 hour interruptions roughly once every two months. "DMP has been working for over 4 years." Budget for occasional brief downtime. [Elektroda, Harnas4, post #18487320]
Some channels take minutes to load or fail whats going on?
One user saw only a few channels load quickly, with many failing across platforms. They viewed the service as unusable during that period. Treat this as a signal to investigate your setup and provider. [Elektroda, Kszyhoo12, post #19058922]
Could my ISP be throttling DMP? How do I confirm?
Yes. A user fixed slow loading by switching ISPs after streaming was blocked. "It turned out that the previous company started blocking media streaming." Test with mobile data or another network. [Elektroda, Kszyhoo12, post #19139373]
How many devices can I use at once with DMP?
You can log in on three devices simultaneously. Run DMP on a PC and an Android TV box at the same time. Use this to compare behavior across devices. [Elektroda, majkimajki1983, post #19085767]
What internet speed is enough for DMP on a budget TV box?
A 20 Mb/s connection proved sufficient for smooth viewing on a low-cost box. Some channels may take longer to load, but playback is acceptable. Ensure consistent throughput during busy hours. [Elektroda, kriso222, post #19137254]
How much does DMP cost?
A user reported about PLN 20 per month for extensive channel access. Compare that value against your alternatives. Confirm current pricing before purchase. [Elektroda, kriso222, post #19137254]
Is a cheap PLN 100 MXQ Pro 4K enough for DMP?
Yes, one user watches DMP on a ~PLN 100 MXQ Pro 4K. They noted occasional longer channel loading, but no major issues. It offers strong price-to-performance. [Elektroda, kriso222, post #19137254]
Why do HD channels show a green screen on my MXQ Pro 4K?
This often signals a cloned unit with a different chipset. The fake overheated and failed to display HD video correctly. A genuine 2/16 GB Allegro unit worked properly. [Elektroda, Harnas4, post #18487320]
Can I use DMP on Windows, Apple, Linux, or MAG decoders?
Yes. DMP works on Windows, Android, Apple, and Linux. It also runs on Android-based MAG decoders for set-top use. [Elektroda, Harnas4, post #18487320]
