[Solved] What router / ap for a big house (maybe MESH?) Up to PLN 500?
Drukarz4C 6414 15
What wireless setup should I use for a large two-story house with wired network cabling if one router/AP does not give good Wi‑Fi coverage?
You should use two wired access points, not a mesh, and configure them with the same SSID; one AP will not reliably cover a large two-story house [#17408278][#17409034] Ubiquiti UniFi/UAP is the recommended direction here, with the UAP Lite usually enough for home use and the Pro only worth considering if you actually have 3x3 MIMO clients or need the extra LAN port [#17411683][#17411793] There is no point buying a TP-Link router model just for AP duty if you already have a router, because you would pay for router functionality you do not need [#17411683][#17411793] The OP later chose a Ubiquiti AC AP Lite and reported that it covered the whole house well, with near-100 Mbit in the farthest spot [#17439877]
  • #1 17407810
    Drukarz4C
    I have a large two-story single-family house and 1Gigabit network in it. Wanting to arm myself with some sensible wireless solution, I invested in the LINKSYS AC750 - I placed it on the ground floor in a central place ... and I'm satisfied on average. Despite the emptiness from the ground floor to the first floor, phones and laptops connect mainly via 2.4Ghz and the strength of the range varies.
    What would you recommend then? Some better (stronger) AP, e.g. TP-LINK AC2600? Or maybe something for the ceiling like TP-LINK CAP1750? Or maybe another approach to the topic and put up two "meshes", such as TOTOLINK T10 (ground floor / top)?
  • #2 17407852
    maly_13
    Help: 21
    Rate: 70
    when it comes to 5GHz, there may be no coverage through the ceiling, 5GHz does not pass through the walls, optical visibility is suggested
  • #3 17407861
    Drukarz4C
    Hmm ... despite the emptiness in the house above the dining room, I only have a slant of the roof so I won't get optical visibility :( But maybe one device should be hung on the forehead of the mezzanine?
    Only what ...
    Or maybe MESH from 2 TOTOLINKI?
  • #4 17408278
    IC_Current
    Help: 1499
    Rate: 2509
    You cannot cover a large house with one AP. You have a wired network, so don't even mess with any Mesh (it's a waste of stability, bandwidth, performance, latency, etc.). For my part, I recommend Ubiquiti Unifi (choose the model in terms of bandwidth / price that suits you). Two such devices will cover the entire home. Equipment of the ZZZ type (Install, Program, Forget).
    Regarding TP-Links - while they are unrivaled in "soapbox" routers, they still have to learn a lot in other equipment.
  • #5 17408913
    Drukarz4C
    IC_Current wrote:
    You cannot cover a large house with one AP. You have a wired network, so don't even mess with any mesh
    So I understand correctly that you suggest simply connect two APs to the cables and set them with the same SSID?
  • #8 17409785
    KOCUREK1970
    Help: 3835
    Rate: 5431
    @ Printer4C
    A colleague needs a router and local APs at the given location.
    And if Linksys is already there, then only the local AP with a wired connection to the root router.
    Of course, the colleague is aware that 1 Gb on wifi will never reach, not to mention the fact that network cards with sufficient performance are also needed here.
  • #9 17410998
    Drukarz4C
    @ KOCUREK1970
    Yes, I am aware that the numbers are very "theoretical". I have a 1Gbit cable everywhere in the rooms - but sometimes we work on laptops with my wife or we get something through the cells and it would be nice to cover the WIFI area. I want to transfer these linksys to the top of the house - and find some good AP downstairs.
    A friend of mine has already cured me from Mesha above.
    I found something like this
    https://www.x-kom.pl/p/281886-access-point-ub...-uap-ac-pro-abgn-ac-1750mb-s-24-5ghz-poe.html
    or that
    https://www.senetic.pl/product/UAP-AC-LITE
    Possibly something like this
    https://www.tp-link.com/pl/products/details/Archer-C2600.html
    What do you guys think about this?
  • #10 17411683
    IC_Current
    Help: 1499
    Rate: 2509
    Personally, I would take the Lite version of the UAP home. The price is lower, and I do not have any receiving device using MIMO 3x3 available in the PRO version. If you have such devices with MIMO 3x3, then you can think of a more expensive AP. The advantage of the PRO version is also the double LAN port, should you lack sockets on the wall. All UniFi series devices are managed centrally, so having more such APs, you configure once for all devices on the network. For you, of course, as you write: currently owned router + one UAP.
    There is no point in taking this TP-Link - why do you need router functionality (for which you pay a lot), if it works as an access point.
  • #11 17411793
    KOCUREK1970
    Help: 3835
    Rate: 5431
    Since the router is already there, the last option with TP Link is also out of the question for me.
    AP Ubiquiti PRO - if you can afford it.
    Although in my opinion the Ubiquiti Lite version will be enough here.
  • #12 17415022
    Drukarz4C
    Thank you colleagues. I'm looking for some used UAP.
    In the meantime, I also found two such exotic devices
    https://en.aliexpress.com/store/product/Engli...-WiFi-Repeater-11AC/1953533_32719753136.html? spm = a2g17.12010612.8148356.1.93611af92JhghL
    and this (you can attach a disk to him, which is a nice option)
    https://www.gearbest.com/wireless-routers/pp_605932.html?wid=1433363¤cy=EUR&lkid=15129619
    do you have any associations with such equipment?
    My IT friend persuades me to this solution
    https://www.olx.pl/oferta/cisco-meraki-mr-33-nowy-w-kartonie-CID99-IDwFRXt.html#22eb962ef5
    I'm not very advanced when it comes to administration - I'm looking for something to cover the house with a signal and that's it. If you manage to connect the drive, it adds value - but without pressure. I will not die for this device ;)
    Many thanks for all suggestions and your comments.
  • #13 17415204
    Darom
    Electrician specialist
    Help: 231
    Rate: 586
    MERAKI MR - very nice equipment. I installed them in a company where they had high requirements for high bandwidth WiFi.
    However, I would pay attention to what my colleague IC_Current wrote (post # 4). Even if you have a SuperDuper device ... you won't get anything done with one.
    kisses
    - GIFT-
  • #14 17415317
    KOCUREK1970
    Help: 3835
    Rate: 5431
    @ Printer4C
    Maybe I'm wrong (somebody correct me), but for Meraki to work, we need to have a purchased and active license for this device.
    That's why people are selling, because the cost of the license is in PLN thousand.
    The problem is that the power radiated from the wifi radio in accordance with the regulations cannot exceed 100mW for the 2.4 GHz band and 200mW (although some sources say 1W) for the 5 GHz band.
    You can think of Ubiquiti LR (Long Range) here
  • #15 17415841
    IC_Current
    Help: 1499
    Rate: 2509
    Tenda - there are those who praise, I have never had contact myself, you continue to pay without the need for router functionality and marketing look.
    Xiaomi - great phones (that's what I'm writing from :) ). Are SOHO devices too? I'd love to know. I do not trust all-in-one devices in general.
    Cisco - top shelf, super stable. I have a network where over 100 clients can log into a single AP, and a few more megabits of transmission are used on the client. However, the price for the devices was at five zeros :-) . If you really want Cisco, then not Meraki, but the SAP 1607I series, but at home, on a few devices, you will not notice the difference to UniFi, and the purchase price times 4.
  • #16 17439877
    Drukarz4C
    In the word of the solution used ... the choice fell on UBIQUITY AC AP LITE. Everything works flawlessly after a bit of a painstaking setup. Compared to the LINKSYS, the AC750 is heaven and earth. I have the signal all over the house - the walls are not a significant obstacle - in the farthest place I have connections close to 100Mbit.
    Overall, I am very pleased. If I ever need to, I can buy a second device and "mix" it - but now I can see that it was a good step. Overall, I can recommend UBIQUITY (although you can see that it is intended rather for large facilities where more devices are required).
    Thanks for helping me guys and see you next time.
✨ The discussion revolves around finding a suitable wireless solution for a large two-story house with a 1 Gigabit network. The user initially invested in a LINKSYS AC750 but experienced inconsistent connectivity, particularly with 2.4GHz devices. Recommendations included using multiple access points (APs) instead of a single unit or a mesh system, with suggestions for Ubiquiti UniFi models, specifically the UAP Lite and UAP Pro, which are noted for their stability and performance. The user also considered other options like TP-Link devices and TOTOLINK T10 but was advised against using routers with unnecessary features. Ultimately, the user opted for the Ubiquiti AC AP Lite, reporting significant improvement in coverage and performance.
TL;DR: Big two‑story homes need 2 APs—"You cannot cover a large house with one AP." Skip Mesh; wire UniFi AC Lite/Pro with the same SSID. [Elektroda, IC_Current, post #17408278]
Why it matters: This helps homeowners with multi‑floor houses and Ethernet wiring get stable, whole‑home Wi‑Fi without wasted speed or budget.
Can one router or AP cover a big two‑story house?
No. Expect to use at least two access points connected by Ethernet. “You cannot cover a large house with one AP.” Two UniFi units were recommended to cover an entire home. This keeps speeds and roaming consistent across floors and rooms. [Elektroda, IC_Current, post #17408278]
Should I use Mesh if my house has Ethernet in the walls?
No. If you have wired backhaul, avoid Mesh. It adds overhead and hurts stability, bandwidth, performance, and latency. As one expert wrote, “don’t even mess with any Mesh.” Wired APs are simpler to manage and deliver better results. [Elektroda, IC_Current, post #17408278]
Will 5 GHz Wi‑Fi pass through ceilings and walls?
5 GHz struggles through solid barriers, especially floors and ceilings. Users observed weak or no upstairs coverage without line‑of‑sight. As noted, “optical visibility is suggested” for reliable 5 GHz links. Plan one AP per floor for consistent speed. [Elektroda, maly_13, post #17407852]
How do I set up two APs so roaming feels seamless?
Use the same SSID and security on both APs, then set non‑overlapping channels and moderate transmit power. Wire each AP to your router or switch. How‑To:
  1. Connect each AP to Ethernet and power.
  2. Configure identical SSID, encryption, and password on both.
  3. Set different channels per band to reduce interference. This same‑SSID approach was confirmed in the thread. [Elektroda, IC_Current, post #17409034]
Ubiquiti UniFi: AC Lite or AC Pro for home?
Choose UAP‑AC‑Lite for most homes. “Personally, I would take the Lite version of the UAP home.” The Pro adds 3x3 MIMO and a second LAN port, useful only if your clients support 3x3. UniFi also offers centralized management. [Elektroda, IC_Current, post #17411683]
When should I consider the UniFi Long Range (LR) model?
Use LR if you need more reach per AP while respecting legal power limits. The expert highlighted approx. 100 mW at 2.4 GHz and 200 mW at 5 GHz. “You can think of Ubiquiti LR (Long Range) here.” [Elektroda, KOCUREK1970, post #17415317]
Is it worth buying a TP‑Link router like Archer C2600 just to use as an AP?
No. You pay for routing features you will not use. “There is no point in taking this TP‑Link” if it will act only as an access point. A dedicated AP gives better value for coverage and performance. [Elektroda, IC_Current, post #17411683]
Are budget brands like Tenda or Xiaomi OK if I only need Wi‑Fi?
Be cautious. One expert noted Tenda often means paying for unneeded router features. They added, “I do not trust all‑in‑one devices.” Xiaomi phones are great, but their SOHO routers are less proven here. Prefer a dedicated AP solution. [Elektroda, IC_Current, post #17415841]
Will Cisco Meraki MR33 work at home without a license?
It requires an active license. “We need to have a purchased and active license,” which is why many units get resold. For home, UniFi gives solid Wi‑Fi without recurring fees or licensing hurdles. [Elektroda, KOCUREK1970, post #17415317]
Can Wi‑Fi deliver 1 Gbit like my wired network?
No. “1 Gb on wifi will never reach.” Achieving very high throughput also requires top‑tier client adapters. Keep Ethernet for maximum speed and use Wi‑Fi for mobility and everyday tasks. [Elektroda, KOCUREK1970, post #17409785]
How many APs do I need for a big house?
Plan on two access points. The expert stated, “Two such devices will cover the entire home.” Wire both to your main router to minimize latency and maximize stability while roaming. [Elektroda, IC_Current, post #17408278]
What speed can I expect in the farthest room with UniFi AC Lite?
A user reported “connections close to 100Mbit” at the edge of the house using UAP‑AC‑Lite. It was a major upgrade over a Linksys AC750. Your exact speed depends on layout and client radios. [Elektroda, Drukarz4C, post #17439877]
Do UniFi APs need constant tweaking, or can I set and forget?
They are stable once configured. The series was described as “Install, Program, Forget.” That fits homes that want reliable Wi‑Fi without ongoing micromanagement. [Elektroda, IC_Current, post #17408278]
Where should I place APs in a two‑story house?
Place one AP per floor near open areas for clearer paths. 5 GHz benefits from line‑of‑sight; “optical visibility is suggested.” Avoid tucking APs behind thick walls or metal obstructions. [Elektroda, maly_13, post #17407852]
How many clients can an enterprise AP handle?
Enterprise APs handle heavy loads gracefully. One engineer saw over 100 clients on a single Cisco AP, each moving several megabits. That’s beyond typical home needs. UniFi covers home scenarios at a lower cost. [Elektroda, IC_Current, post #17415841]
