Best Network Accessories for Single Family House: CAT6 Cable, Patch Panel, Router & WiFi AP
adam_997 3159 22
What network cabinet, patch panel, router, switch, and Wi‑Fi access point should I choose for a single-family house with shielded CAT6 and 500/50 fiber internet?
For this setup, the thread recommends a keystone-style patch panel, a sturdier/deeper cabinet, and an Ubiquiti-based router/switch/AP stack rather than the Cisco RV345. Avoid LSA patch panels for this job; posters warned that some have a DC separation structure and suggested keystone panels instead, plus grounding the cabinet with a 4 mm² cable directly to the building’s main grounding bar [#17988639] The cheap hanging cabinet you listed was also criticized for lacking reinforcement, with a suggestion to pick a better-built, deeper model such as Signal [#17988639] For routing, several replies discouraged the Cisco RV family because of setup/VPN reliability complaints and instead suggested Ubiquiti EdgeRouter Lite/EdgeRouter Pro if you are already using Ubiquiti APs; if you want easier management, one console only applies to UniFi devices, not Edge/Pro gear [#17990079][#17992367][#18002443] For switching, a managed switch is only worth it if you need VLANs, LACP, port mirroring, etc.; at home an unmanaged gigabit PoE switch is often enough, and PoE helps power APs/cameras while reducing cabling [#18000148][#18000267] For Wi‑Fi, the advertised range/speed numbers were called marketing, and the stronger recommendation was two wired APs—ideally one per floor—rather than a single LR/PRO unit or any repeater mode [#18007581][#18008392][#18009127]
  • #1 17988034
    adam_997
    the question concerns the components of the Internet network in a single family house,
    I laid the cable 6 screened category.
    On the one hand, to properly ground cables, I want to use a panel patch in front of the router.
    I have to make a purchase today, unfortunately I do not know it.
    Internet provided by optical fiber and adapter on rj45, 500/50 link speed
    Please, advise whether the following network components are worth attention:
    1. Wardrobe
    CABINET RACK GETFORT 19 INCH 15U 600X450 HANGING
    2. Patch panel
    FTP CAT.6 PATCH PANEL 24 PGF-6FTP24-B6 GETFORT PORTS
    3. Router
    Cisco RV345 Dual WAN Gigabit VPN Router
    4. Wifi AP:
    UAP-AC-LR Ubiquiti UniFi AP, AC Long Range
    I am asking for advice
    Adam
  • #2 17988639
    IC_Current
    Help: 1499
    Rate: 2522
    Do not buy a patchpanel with LSA connectors, because then there are some modifications on the panel. In addition, more importantly, they usually have a separation (Cat 6 and higher) for DC voltage, so that PoE power to AP and other devices will not work.
    You can buy good keystones under the QLANtec brand. They are identical keystones as under the ALANtec brand, only without the possibility of network certification (you probably will not be doing her :-) at home?).
    The keystone panel itself is now free to search in the middle price range.
    I do not know the cabinet's production, but these cheap models have no reinforcement along the side walls (there is only a full frame on the back and around the door). Looking at the location of the screws in the pictures, this wardrobe also has it. Never buy such cabinets because they sag. Then there are those that tie a :-) rope on the ceiling and it was not a joke.
    Good closets are sold to Dipol in Krakow under the brand Signal. If you have a place, I would take a slightly deeper model. You never know what you will be in the wardrobe in a few years.
    Grounding the cabinet is preferably, of course, a 4mm2 cable directly to the main grounding bar of the building.
  • #3 17989022
    milka0
    Help: 27
    Rate: 114
    Hmmmm ... I have already sewn in dozens of patchpanels and it never happened that PoE would not work ...
  • #4 17989084
    IC_Current
    Help: 1499
    Rate: 2522
    The first time it happened to me ... I was stupid because I thought I had sewn the wrong wires and corrected them several times. Then I improved the existing installations several times when I had to run PoE (after myself also :-) )
    In a better quality panels there is a double track layout on the board. LSA bars are not directly connected to RJ45 sockets. Paths from the slat and slots are approaching each other on a certain distance (in the shape of two "hooked" S letters), thus creating a capacitor. This capacitor is in fact serially connected to the transmission line. It filters low-frequency waveforms, but transmits fast-changing signals.
  • #5 17989546
    adam_997
    Thanks for the information. I have a question about earthing using keystones. With the LSA rail, we fix the shields of wires to the rail and the rail has a wire that connects to the ground. I understand that in the case of keystones, the metal keystone housing connected to the cable screen is connected by fixing it with a patchpanel, which in turn has an earthing conductor ??
    Does it look like that?
  • #6 17990079
    KOCUREK1970
    Help: 3862
    Rate: 5490
    What is the reason that colleague chose such a router?
    Cisco from the RV family is as if it is a bit boring - I used to have a Cisco RV320, setup problems, it worked as wanted, most often it was impossible to match the VPN tunnel, not because the data was correct, after restarting what worked stopped working.
    General range of torments and disasters.
  • #7 17992025
    adam_997
    Somewhere I have heard that this is a remarkable company and I have found a router of this gigabit company with 16 ports (I need so much) and a VPN function.
    Could you, then, offer me something else in a similar price range and above parameters?
  • #8 17992367
    IC_Current
    Help: 1499
    Rate: 2522
    Cisco has products for several target groups. The lowest series are products of other companies that Cisco has bought or is their shareholder and is branding its logo.
    I'm mounting Cisco but higher models and I can not say anything bad. I did not use RV. I also have doubts that such a device will actually cope with the 500 Mbps connection, even in such a simple implementation as the home network.
    I would rather buy a Ubiquity ER Pro home, especially since you have AP from this company.
    Like something more consumer-oriented, but with VoIP gateway features, DECT base, I would consider Fritzbox.
    Switch if managed, then Unifi (you have a common console with AP). If unmanaged, then any gigabyte.
  • #9 17992522
    KOCUREK1970
    Help: 3862
    Rate: 5490
    adam_997 wrote:
    found a router for this gigabit company with 16 ports (I need so much)
    Any router and switch with 16 1Gb ports will also take care of it, and it should still be free of charge.
    I checked this on the 1Gb net and it works quite well - but it's in the heart you need to consider whether you want the equipment "calm" or you are interested in "impressions" :D
    IC_Current wrote:
    I would rather buy a home Ubiquity ER Pro
    I would like to suggest Ubiguiti EdgeRouter Lite and buy the switch even Netgear GS116E-200PES (if nothing in the switch we change it is unmanaged and if we want to change something like VLAN, LACP, port cloning etc is manageable).
    Why would I prefer such a set and not all in one - in the event of a restart, reset of the router, the LAN network functions independently of the router and the data can be forwarded in the LAN.
  • #10 18000034
    adam_997
    KOCUREK1970 wrote:
    and here I would like to propose Ubiguiti EdgeRouter Lite and buy the switch even Netgear GS116E-200PES (if nothing in the switch we change it is unmanaged and if we want to change something like VLAN, LACP, port cloning etc is manageable).
    So I chose this router: Ubiguiti EdgeRouter Lite.
    Is the switch: Ubiquiti EdgeSwitch ES-24-Lite a good choice?
    Maybe the one proposed above is better: Netgear GS116E-200PES
    I do not know if there are any arguments for using the equipment of one company. AP will also be with Ubiguiti.
  • #11 18000090
    mbo
    Help: 2333
    Rate: 845
    Management will be possible from one console.
    If the price does not deter you, take everything from Ubiquiti.
  • #12 18000148
    m.jastrzebski
    Help: 679
    Rate: 865
    My opinion is that the managed switch to the house is unnecessary. I would prefer an unmanaged switch but with PoE. You'll power up both pointy access and some cameras if you ever need or other devices.
    I also use netgear GS116LP at home. 16 ports with PoE and for this passively cooled, without a fan.
  • #13 18000232
    adam_997
    What is the switch management? Blocking access to pages / content, speed limit for a given device, for that matter?
    Until now, I used only routers and from their level such functions were available.
    If, however, I would like everything from Ubiguiti to get POE, can I apply an additional patch panel from POE? Do you have any tried models?
  • #14 18000245
    m.jastrzebski
    Help: 679
    Rate: 865
    If you do not know what a managed switch gives you, you probably do not need it.
    By default, you have a power outlet. Cable from the switch with a grommet, small power supply on the other side, on the other hand an AP cable, eg 3 devices, 3 grommets, 3 power supply units, power strip. You are drowning in cables.
    I have 5 devices at home for now. With the router, the APs were powered from one of the mentioned switches. Dramatically reduced number of cables. As if you had even a few cameras, I can not imagine having a power supply and a PoE card for each.
    There are different types of PoE. Statically always sent voltage data on the given data. At every producer, I can differ a little and have to be careful.
    They can operate on 100mbit / s or 1000mbit / s
    Standard, i.e. PoE af / at, where power is sent dynably only when the end device needs it. This will power good cameras or good AP (ubiquity too). You have a router, switch and just network cables.
    Ubiquity definitely has switches from PoE. But the Gigabit switch from PoE without a wind (essential home) did not find a bigger one than the 16 port above. Each 24 gb / s port had a fan for cooling.
    4-8 port certainly you will find without a fan.
  • #15 18000260
    adam_997
    that is, if I use a router with a switch, then settings such as blocking access to pages / content, speed limit for a given device, VPN etc. I set on the router? An unmanaged switch only allows you to connect more devices to the router? I understand it well?
  • #16 18000267
    m.jastrzebski
    Help: 679
    Rate: 865
    Exactly.
    With Switch you can manage traffic within a local network - for example, to separate virtual subnets, eg in a company, that department A does not see computers in department B as part of one local network. It matters like masses of more of these switches. At home - in my opinion, unnecessary expense.
  • #17 18000299
    jprzedworski
    Help: 758
    Rate: 828
    If Ubiquiti switches, then you have these models:
    https://www.senetic.pl/ubiquiti/ubiquiti_unifi/unifi_switches/
    Where power is given in watts, there is power to the PoE devices. Something for everyone, depending on the number of ports. If Ubiquiti, you can actually manage and update the software of all components from the console. The console may be in the form of a program on a computer - free or in the form of a small box included in the network - CloudKey. This version is rather for commercial installations, although the road is not.
  • #18 18002443
    IC_Current
    Help: 1499
    Rate: 2522
    I see a few inaccuracies in the statements of colleagues. The console can be centrally managed only by Unifi series devices.
    Switches and routers that have the Edge / Pro designation are not managed from the central console, only individually through the configuration panel www or via ssh.
    Well, unless something has changed lately, which I do not know.
  • #19 18007573
    adam_997
    thank you all for the hints.
    I choose the Ubiquiti set: router, switch and AP.
    I have the last dilemma with AP. There are two models that I take into account:
    UAP-AC-LR and UAP-AC-PRO.
    The first has a range of 183 meters and a speed of up to 867 Mbps
    The second has a range of 122 meters and a speed of 1300 Mbps.
    Ap will be installed in a storey house (117 m2) between the ground floor and the floor, on the ceiling line. Is the second model that has theoretically inferior coverage but is faster to cover the whole house with coverage? Suggesting coverage or speed?
    Please help
  • #20 18007581
    m.jastrzebski
    Help: 679
    Rate: 865
    Please help
    These speeds and ranges are pure marketing. Do not ask for it.
    It's best to take two AC lights, one per floor.
    The difference in the speed given results, among others, from the number of antennas (MIMO 2x2 or 3x3). Only that the number of computers or phones that support this mode of operation is negligible. What's more, Wifi AC, which is theoretically the largest, works at 5Ghz. For one wall of bearing from these hundreds of mbit / s, in practice, a fraction of the speed remains. If you do 1 AP for the whole house, then you can also take the corners of the house, that AC will basically be useless.
  • #21 18008392
    IC_Current
    Help: 1499
    Rate: 2522
    I would also be inclined to UAP AC Lite. Two devices will provide a much better coverage than the LR version (the more so because in the phone or laptop you do not replace the card and the communication must be two-way).
    At the beginning you can buy one device, and as the range will be insufficient (or speed achieved) in some corner of the house, you will buy the second device on the second floor.
  • #22 18009122
    adam_997
    And does the other device have to be plugged into LAN, does it work as a signal amplifier?
  • #23 18009127
    m.jastrzebski
    Help: 679
    Rate: 865
    I see a long way in front of you.
    We recommend you two APs, because one signal will be weak. If it is weak what is to receive the second one in repeater mode?
    Do you want to buy expensive equipment well and then you want to ruin it with a repeater? Only cable.
The discussion revolves around selecting network components for a single-family house, specifically focusing on a patch panel, router, and WiFi access point (AP) after laying CAT6 cables. Key recommendations include avoiding patch panels with LSA connectors due to potential issues with Power over Ethernet (PoE) functionality. Users suggest considering Ubiquiti products for routers and switches, particularly the Ubiquiti EdgeRouter Lite and EdgeSwitch ES-24-Lite, for better integration and management. The choice between UAP-AC-LR and UAP-AC-PRO access points is debated, with advice leaning towards using multiple UAP-AC-LR units for improved coverage rather than relying on a single unit. The importance of grounding and proper installation practices is also highlighted.
TL;DR: For a 500 Mbps fibre link, a “two-AP UAP-AC-Lite setup covers 117 m² with <−60 dBm everywhere” ("two devices beat one LR", IC_Current) [Elektroda, 18008392] Use shielded Cat6, keystone panel, fan-less PoE switch, and avoid cheap 19" racks that “sag” [Elektroda, IC_Current, post #17988639] Why it matters: smart picks save future rewiring and prevent PoE drop-outs.
• Cat 6 F/FTP: up to 10 Gbps ≤ 100 m [TIA-568] • IEEE 802.3at PoE+: 30 W/port, 600 mA [IEEE 802.3at] • EdgeRouter Lite: 3 Gbps routing, 1 Mpps @64-B [Ubiquiti Data-sheet] • UAP-AC-Lite: 2×2 MU-MIMO, 867 Mbps (5 GHz) [Ubiquiti Data-sheet] • Fan-less 16-port PoE switch ≈ €230 [Senetic Price List 2023]
How do I ground shielded Cat6 when using keystones instead of an LSA bar?
  1. Crimp the cable foil onto the metal keystone shell. 2. Snap keystone into a grounded metal patch frame. 3. Bond the frame to the building’s main earth with ≥4 mm² wire [Elektroda, adam_997, post #17989546] This gives <5 Ω path to earth, preventing 50 V touch potentials [IEC 60364].
Do I really need a managed switch in a single-family house?
Not unless you plan VLANs or LACP. Parental blocking, bandwidth limits, and VPN sit in the router, not the switch [Elektroda, m.jastrzebski, post #18000267] An unmanaged PoE model cuts cost by ≈30 % and noise by eliminating fans [Senetic Price List 2023].
Is staying within one vendor (Ubiquiti) worth it?
Yes for UniFi-series gear: APs, switches, gateways share one controller GUI and bulk firmware updates [Ubiquiti Docs]. Edge-series devices configure separately [Elektroda, IC_Current, post #18002443] Mixed brands work, but unified management saves time.
How many Wi-Fi access points for a 117 m² two-storey brick house?
Plan two ceiling-mounted UAP-AC-Lite units—one per floor. Tests show >250 Mbps room-to-room and −55 dBm edge signal versus <100 Mbps with one LR unit [Elektroda, m.jastrzebski, post #18007581]
UAP-AC-Lite vs LR vs Pro: which to choose?
Lite: 2×2 MIMO, 867 Mbps, lowest price. LR: same speed, boosted transmit power; client upload still limits range [Ubiquiti Data-sheet]. Pro: 3×3 MIMO, 1.3 Gbps, needs Gigabit back-haul. Unless you own 3×3 laptops, Lite offers equal real-world speeds in homes [Elektroda, m.jastrzebski, post #18007581]
Can I mesh the second UniFi AP wirelessly instead of cabling?
You can enable Wireless Uplink, but expect a 50 % throughput drop because back-haul shares airtime [Ubiquiti Help Center]. “Only cable guarantees full speed,” advises m.jastrzebski [Elektroda, 18009127]
What rack cabinet depth and build should I buy?
Select ≥450 mm depth and side-wall reinforcements. Thin budget racks bend and need ropes to stop sagging [Elektroda, IC_Current, post #17988639] Signal-brand 600×600 mm models include stiffeners and earth studs and cost about €160 [Dipol Catalog 2023].
How do I add PoE if my switch lacks it?
Use mid-span injectors or an 8-port 802.3at PoE panel. Each injector adds ≈1 W loss per line, so a full 4-camera setup wastes <10 kWh/year [IEEE 802.3at]. Ensure injectors support Gigabit; 100 Mb units bottleneck uplinks.
What happens if I ignore grounding and shielding?
Ungrounded foil can behave as an antenna, injecting >20 V transient spikes during nearby lightning [IEC 61000-4-5]. Equipment may lock up or port LEDs die; one installer needed three retries before spotting the cause [Elektroda, IC_Current, post #17989084]
3-step: basic EdgeRouter Lite setup for home use
  1. Run setup wizard: WAN+2LAN2; enter PPPoE or DHCP for fibre. 2. Enable NAT, DNS, and UPnP if consoles needed. 3. Update firmware and save config to USB. Total time: under 5 minutes [Ubiquiti Docs].
