Nbox BSLA Enigma2: Missing Channels (TVP2HD, HBO HD, TNT HD) - Capacitors Replaced & Latest List
Rafikosss123 10275 7
  • #1 17411285
    Rafikosss123
    Hello everyone. I have a Nbox BSLA ENIGMA 2 and such a problem, a few channels do not work for me, e.g. TVP2HD, HBO HD, TNT HD and a few others. Capacitors were replaced and the problem remained. If I give it on TVP2HD, for example, the tuning pops up failed up, and in a moment SID was not found in PAT. Antenna is ok because the second decoder is flashing. Latest list
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    Swap heads in the decoder and see.
  • #3 17412888
    charlee
    Help: 30
    Rate: 135
    Update the channel list.
  • #4 17413149
    Rafikosss123
    Replacement of the head helped, all channels work. After replacing the capacitors, the problem is still the same, these channels do not work anymore
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    Rafikosss123 wrote:
    After replacing the capacitors, the problem is still the same, these channels do not work further
    I understand that you replaced the capacitors in the old head (the one that did not work well)? Post a photo of this head.
  • #6 17415719
    Rafikosss123
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    Check the output voltage for TVP1 HD and TVP2 HD. It looks like horizontal polarization is not working.
  • #8 17418113
    Rafikosss123
    TVP 1 HD 16:54 TVP 2 HD 11:45
The discussion revolves around issues with the Nbox BSLA Enigma2 decoder, specifically the inability to access channels such as TVP2HD, HBO HD, and TNT HD, despite replacing capacitors. Initial troubleshooting included swapping heads in the decoder and updating the channel list, but the problem persisted. A follow-up indicated that replacing the head resolved the issue for other channels, but the specific channels remained non-functional. Further investigation suggested checking the output voltage for TVP1 HD and TVP2 HD, indicating a potential problem with horizontal polarization.
