Nbox ITI-5800SX Enigma 2 (v8.6.0) Channel List Update: Editing & Adding TTV, HB13E HSWG Settings
jeremiw1 12393 4
  • #1 16810092
    jeremiw1
    Help: 24
    Rate: 19
    I have an Nbox ITI-5800SX with Enigma 2 uploaded (release: 2013-03-31 version: 8.6.0 2014.06.25) and I would like to ask for help in changing the channel list. I have not been on the TTV list for a long time so today I have uploaded a new channel list called E2_HD_settings_HB13E_HSWG_06102017.
    There are many channels but TTV still doesn't have one :) Could I edit any unnecessary channels to change its parameters to TTV parameters?
    I know that I can scan a single transponder but I am afraid that I am removing something. Are my fears unnecessary?
  • #2 16810314
    KIEROWCA_VW
    Help: 273
    Rate: 676
    Enigma has a so-called plug-in for updating lists in the scope of channels of Polish operators - this is called fast search. You can also search the transponder and add the found channel to your list. Another thing is that this channel (TTV HD) has not changed broadcasting parameters for a long time. What offer are you using?
  • #3 16810342
    tompaw
    Help: 9
    Rate: 13
    Attached is a fragment of my list from TTV (item 20), I use the nc mix card. What is the symptom of TTV missing (message "Tuning failed ..." or just a black screen). A black screen will probably be a problem with permissions, and "Tuning ..." will be associated with incorrect channel parameters. If I change the broadcasting parameters of one of the channels, I will scan the satellite and update my list by replacing the inactive channel with the newly found one.
    • ttv.rar (55.21 KB) You must be logged in to download this attachment.
  • #4 16810632
    romeok01
    Help: 357
    Rate: 589
    To edit channels and to load lists, use the Dremboxedit program, for download below.
    • dreamboxEDIT_setup_7.2.0.0.zip (8.69 MB) You must be logged in to download this attachment.
  • #5 16810959
    jeremiw1
    Help: 24
    Rate: 19
    Gentlemen, thank you so much for your help. Especially my tompaw colleague for uploading his channel list. I have NC Mix and the message at TTV was "NID / PID not found" or something.
    I uploaded the list twice, which I gave in the first post (the first time there was an error) and TTV HD appeared.
