[Solved] Xiaomi Redmi 4A - Copy of data contacts, sms, photos, setting
fonexpl 7986 8
  • #1 17413118
    fonexpl
    Level 4  
    Rate: 68
    Hello, how is the easiest way to back up all data in this model? I need to restore factory settings, but I don't want to lose data. I see there are several options:
    - local backup
    - Xiaomi account
    - google account
    Which option should you use?
  • #2 17413166
    pietia86
    Help: 69
    Rate: 91
    I always use local copies. This has its drawback - if I don't copy something, I will simply lose it, or damage to the medium with a copy of the data will also result in data loss.
    It also makes sense to use a google account. Especially since usually no additional applications are needed for this and the whole process is automated
  • #3 17413177
    gieniapierda
    Help: 56
    Rate: 129
    I confirm Google rulez ;-)
    It only takes some time to upload and download.
  • #4 17413188
    fonexpl
    Level 4  
    Rate: 68
    And when it comes to local copy, where is it created? If in the phone's memory, after the format, I will also lose this copy and what it makes sense.
  • #5 17413196
    leonov
    Help: 1039
    Rate: 2246
    A copy is created locally on the memory card (if any).
  • #6 17413210
    pietia86
    Help: 69
    Rate: 91
    In addition, if you are afraid, you can always make a copy to some other card or the one you have to remove when you restore the factory settings.
  • #7 17413231
    fonexpl
    Level 4  
    Rate: 68
    I don't have a memory card in my phone, and the copy somehow formed, so where is it now? Can you copy it from your phone to your computer, format the phone, then copy it back to your phone and play it?
  • #8 17413246
    pietia86
    Help: 69
    Rate: 91
    In that case, it had to form in internal memory. You must therefore take this file from your phone.
  • #9 17438092
    fonexpl
    Level 4  
    Rate: 68
    I copied the Xiaomi backup files from the phone's memory, made the format, and then restored the copy. Thanks for the help
The discussion revolves around the best methods to back up data on the Xiaomi Redmi 4A before performing a factory reset. Users suggest three main options: local backup, Xiaomi account, and Google account. Local backups can be risky if not stored on an external medium, as they may be lost during formatting. Google account backups are favored for their automation and ease of use. Users confirm that local backups are stored in the phone's internal memory if no memory card is present. One user successfully backed up their data to internal memory, formatted the phone, and restored the data afterward.
