Xiaomi Note 4X Mediatek: Factory Reset Leading to Unknown Xiaomi Account Login Issue
Yakers 18675 14
How can I remove the Xiaomi account lock on a Redmi Note 4X after a factory reset if I do not know the Mi account login or password?
Flashing CM, MiFlash, or another ROM will not remove the Xiaomi account lock on this phone; when it connects to the network, it checks Xiaomi’s servers and locks again [#16839416][#16770658] The normal way to fix it is to log in to the Mi account and remove the device on i.mi.com, or recover the password through Xiaomi’s password reset page if you know the registered phone number or email [#16839416] If the service caused the problem, the practical advice in the thread is to complain and ask them to unlock the phone or replace it [#16770286][#16770675] Some replies mention paid service tools or memory-sector resetting methods, but those are not presented as a simple software flash solution [#16770658][#16770744]
  • #1 16770154
    Yakers
    Rate: 43
    I have a problem with Xiaomi Note 4x. My friend sent him back for a guarantee and the gentlemen gave him the factory settings and sent him back. When he received it, he had to enter the password for the xiaomi account he does not know, @ neither does he know, and the account was not assigned to the phone number. And the question is whether I can only download CM software, if something could be done with it, attempts to reset the password did not give because I do not remember @ and password, it has a guarantee but probably not including so we do not care about the warranty. What's in this situation?
  • #2 16770286
    mastereg
    Help: 7
    Rate: 16
    In this case, only flashing by the tool on the computer or CM.Ja I would complain about the service if they blocked, let them unlock or give a new device.
  • #3 16770359
    Yakers
    Rate: 43
    I mean, a colleague set up an account and can not remember the data, and they restored the factory settings and to use the phone you have to log in to this account. So only CM?
  • #4 16770369
    mastereg
    Help: 7
    Rate: 16
    The flashing tool is probably Miflash if you have not mistaken the name. You have to definitely flip the phone but you do not have to do CM
  • #5 16770658
    Glemark1
    GSM specialist
    Help: 190
    Rate: 111
    Flash will not give you anything here. You just have to delete your account. From paid devices like BST Dongle, MRT dongle and others.
  • #6 16770675
    mastereg
    Help: 7
    Rate: 16
    Buddy glemark has not yet met the method of deleting the account xiaomi or MiFRP somewhat kind of saying otherwise like flash xiaomi tool in the case when the account is assigned to the phone and we do not have access. The phone will not even get us into recovery and we will not do a hard-touch. As you can see the phone was probably in the hands of a trainee who probably did not know about it and the best option still think that there will be a complaint of the service and ordering a lock or exchange. However, if you have a thorough method that will help 100%, write priv, maybe you will be able to learn something a colleague ;)
  • #7 16770744
    Glemark1
    GSM specialist
    Help: 190
    Rate: 111
    MiFlash is used to flash phones on Qualcomm processors, not MTK. You can use Flashtool for example.
    The website is not obliged to delete the account created by the client. This is the client's problem that he does not remember the login details. You can do this on this phone by resetting the corresponding memory sectors.
  • #8 16771088
    mobista
    Help: 257
    Rate: 365
    Who told you that the website is not obligated?
    Question to the buyer - where did you buy the phone? In the official distribution, or on Allegro from Sebix and friends?
    Btw. in MTK it's not so easy to delete Xiaomi account.
  • #9 16772421
    Yakers
    Rate: 43
    As for now I managed to do it only prosaically, i.e. the phone will normally turn on, you can use but you can not connect to the network because it will automatically block. Can you do something, unlock the bootloader or something else to avoid it?
  • #10 16839416
    rumax
    In Xiaomi, you will not remove the lock, if the phone is connected to the account without a password to the account, it is not possible to properly start the phone, flashing, uploading another Miui can not do anything. The phone connects to the net and connects to the Xiaomi server and locks the phone. The only way is to enter the password and enter on i.mi.com there, disconnect the phone from the account and you can use it. After reconnecting to the account, you must remember the account password. The password can be recovered here https://account.xiaomi.com/pass/forgetPassword?_locale=pl_PL you just need to know the phone number or email address you have registered.
  • #11 16874174
    januszjh
    Rate: 57
    How to upload CM with locked bootloader and Xiaomi account? Through EDL in MiFlash, I uploaded MIUI with replaced recovery.img (TWRP), but the recovery does not start (for a moment, the MI logo and the screen goes out). And after turning on miui, the original recovery returns.
  • #12 16875277
    blahfff
    Help: 1036
    Rate: 1301
    This is very much dependent on the model. Generally, it would be necessary to look for the oldest firmware and check because often the first firmware version does not verify the account when connected to the net, which gives the opportunity to add a new account and assign the phone to it. Later, you can already disconnect the phone from the new account and nothing is happening after the updates. The alternative is to remove Xiaomi services but this sometimes ends with the phone's reboots on the logo.
    I do not know how it is in the case of Note 4x, because I did not get it, but usually 4xy (snapdragon) it was possible to move.
  • #13 16877583
    januszjh
    Rate: 57
    Can you reveal a recipe for unlocking 4xy? I have to unlock Redmi Note 4X (snapdragon). Where to get the old soft to the new phon? I do not think so. My colleague unlocked RN 2. It was enough to upload old soft miuipolska. But it was an old phon with unlocked bootloader.
  • #14 16878200
    blahfff
    Help: 1036
    Rate: 1301
    I'm sorry, now I looked at the old posts and it was 4A, more described here . Note 4X is also older softs, you can even use the software for Chinese versions, see here and try. I was having a good few hours of testing and mistakes but I finally managed to do it.
  • #15 17492751
    Yakers
    Rate: 43
    It could not be repaired
The discussion revolves around a Xiaomi Note 4X that was returned for warranty service, resulting in a factory reset that requires a Xiaomi account login, which the user does not have access to. Various solutions are proposed, including flashing the device using tools like MiFlash or Flashtool, but the consensus is that without the account credentials, the phone remains locked. Users suggest that the service center should assist in unlocking the device or provide a replacement. Some mention that older firmware versions might allow bypassing the account verification, while others highlight the difficulty of deleting the Xiaomi account associated with the device. Ultimately, the inability to access the account renders the phone unusable, and recovery options are limited without the original login information.
TL;DR: 3 paid tools were named, and one expert warned: "Flash will not give you anything here." If a Redmi Note 4X (MTK) was factory‑reset and asks for an unknown Mi Account, standard flashing won’t bypass the lock. [Elektroda, Glemark1, post #16770658]
Why it matters: This FAQ helps owners and repairers fix or triage a Note 4X that re‑locks after network connect due to Mi Account protection.
How do I fix a Redmi Note 4X (MTK) that asks for an unknown Mi Account after factory reset?
You must recover the original Mi Account, then unlink the phone at i.mi.com. Flashing or updating MIUI does not help because the device re‑locks when it contacts Xiaomi servers. Use the password recovery flow for the registered email or phone, then remove the device from the account. “The only way is to enter the password.” [Elektroda, rumax, post #16839416]
Will flashing a ROM remove the Mi Account lock on Note 4X MTK?
No. After flashing, the phone connects to Xiaomi servers and locks again. This happens even if you load a different MIUI build. The only reliable unlock is signing into the bound Mi Account and unlinking the device online. Plan your repair around account recovery first. [Elektroda, rumax, post #16839416]
Which flashing tool applies: MiFlash or SP Flash Tool?
There are 2 chipset lines. MiFlash is for Qualcomm‑based Xiaomi phones, not MTK. For Redmi Note 4X with MediaTek, use SP Flash Tool (or comparable MTK flash utilities). Quoting an expert: “MiFlash is used to flash phones on Qualcomm processors, not MTK.” [Elektroda, Glemark1, post #16770744]
My phone works until Wi‑Fi/mobile data is on, then it locks. Why?
That behavior indicates server‑side Mi Account verification. Offline use may seem normal, but once the phone reaches Xiaomi servers, it enforces the bound account and re‑locks. Do not rely on offline setup as a fix; focus on reclaiming the account or official removal. [Elektroda, Yakers, post #16772421]
Can a service center remove the Mi Account if I forgot the credentials?
One viewpoint says service isn’t obligated because the customer created the account. Technicians may mention low‑level memory operations, but these require specialized tools and carry risk. Always try official account recovery first to avoid data or device issues. [Elektroda, Glemark1, post #16770744]
Do paid boxes like BST or MRT remove the Mi Account on MTK Note 4X?
Some techs use paid dongles (BST, MRT, others) that target security partitions. Success is not guaranteed, and methods change with firmware. These tools are for professionals and may affect warranty or legality. Proceed only if you own the device and data. [Elektroda, Glemark1, post #16770658]
Is there a firmware trick to bypass the lock?
Sometimes the very first firmware build does not verify the account when online, letting you add a new Mi Account and later unlink. Results depend on model and build. Quote: “Often the first firmware version does not verify the account.” Test carefully and expect mixed outcomes. [Elektroda, blahfff, post #16875277]
How do I try the early‑firmware method safely?
  1. Flash the oldest available Note 4X ROM (even Chinese variant if compatible).
  2. Boot, connect network, and try adding your own Mi Account.
  3. If accepted, unlink the device from your account, then update MIUI. Results vary and may fail; keep full backups. [Elektroda, blahfff, post #16878200]
EDL flashed TWRP, but stock recovery keeps returning. What’s happening?
With a locked bootloader, MIUI restores stock recovery on boot. EDL flashing a recovery.img may momentarily show the Mi logo, then power off, and MIUI reinstates the original recovery after boot. Unlocking the bootloader typically requires verified Mi Account access. [Elektroda, januszjh, post #16874174]
Why can’t I enter recovery or perform a hard reset when Mi‑locked?
When a Mi Account is bound and you lack access, the phone may block recovery modes and hard reset paths. That prevents bypass attempts from local menus. Focus on account recovery or official unlock routes instead of button‑combo resets. [Elektroda, mastereg, post #16770675]
What should I ask the repair shop if they returned it locked?
Request that they unlock the unit or replace it. Document their factory reset and the subsequent account requirement. This sets clear expectations and may expedite escalation or replacement if they changed the device state. [Elektroda, mastereg, post #16770286]
Where do I recover the Mi Account password or unlink the device?
Use Xiaomi’s password recovery for the registered email or phone number, log in, and remove the device from your account. After unlinking, the phone should activate normally and stay unlocked after updates. Keep the password safe for future service. [Elektroda, rumax, post #16839416]
Is the Snapdragon Note 4X handled differently from the MTK version?
Yes. Snapdragon models use MiFlash, and some users report success with very early firmware to add a new account. One expert succeeded after hours of testing by using older or Chinese ROMs. Expect trial and error with that approach. [Elektroda, blahfff, post #16878200]
What’s the realistic outcome if I can’t recover the account?
One case report concluded “It could not be repaired.” Without the original account, the device may remain unusable on network. Consider proof‑of‑purchase and official support to explore ownership verification options. [Elektroda, Yakers, post #17492751]
