Does the 2005 Mercedes W203 C180 have an additional backup battery, and where is it located?
No, the W203 has only one battery, located under the hood on the passenger side under the cabin air filter housing. [#17416550][#17416396] If you are seeing a battery warning or service visit message, the problem may be the charging system rather than a second battery; one user solved it by finding a collapsed alternator that charged only 13.3 V, when it should have at least 14 V. [#17418458]
I dug into the pit from the inside but there is only a blower. I have a problem with the battery displayed and the service visit message, Charging at 14.1V, the battery is not new but it burns to the touch.
The discussion centers around the existence and location of an additional backup battery in the 2005 Mercedes W203 C180. Users clarify that this model does not have a secondary battery; it only features the main battery located on the passenger side, under the cabin air filter housing. One user initially inquired about the backup battery but later identified the issue as a failing alternator, which was not charging adequately, leading to battery problems. The alternator was found to be charging at 13.3V instead of the expected 14V. AI summary based on the discussion. May contain errors.
