W204 - Replacing Mercedes W204 Pyrotechnic Fuse: Exploring Alternatives and Safety
drdrug 8718 1
  • #1 16364997
    drdrug
    Help: 25
    Rate: 178
    Hey. I have a question, maybe someone was studying a similar topic. patient is C-class 2.2 CDI W204 bargain !, the car stopped firing, no power supply from the starter. Under the bonnet on the right side there is no power supply to the thick +, when pulling out the box I already knew that it would be thick, the resistor wire from the fuse plugged in so the history of the vehicle can already be imagined. I dismantled the box, I pulled out this fuse no passage. The housing is dismantled and what inside? inserted piece of metal sheet twisted with two screws.
    Then I got a 60A plate fuse but after 2 firings it blown, I put 200A on the test and it works. My findings show that this fuse should have 400A, and my question is, has anyone done something like this? Can any other pyrotechnic fuse be used? Eg from vaga (4F0915519) (but I can't find any data about it), can I insert a regular plate type 400? I know that for reasons of fire safety you can insert a new one but a new original costs a few thousand (the whole box), for scams about a thousand, they sell in full with a box and a transmitter of candles. In addition, there is a terminal on the battery Cushions, sensors, belts functional Jasiek does not shine, after this discovery everything checked, I count on you ;-)
    ps tomorrow I will put a photo of this art over the arts.
  • #2 16365329
    autoas
    Help: 571
    Rate: 3924
    If the resistor "worked" and there is no error, then each pyrotechnic fuse will work ...
