Reviewing the Magnum MIG 210 Easy Synergy Welder: Evaluating Its Worth and Technical Specs
kilerr0 43833 22
  • #1 17419395
    kilerr0
    Rate: 30
    Migum MIG welder 210 easy Synergia 200A
    Technical parameters - MIG / MAG welding machines
    Max. Welding current [A]: 200
    Welding current range [A]: MIG / MAG - 50-200 A, MMA 10 ÷ 160 A, TIG Lift 10 ÷ 200 A
    Current [A] / duty cycle [%]: 200/60
    Security [A]: 20
    Power consumption: 6.4
    Power supply [V]: 230
    Degree of protection: IP21S
    Idle voltage [V]: 51 V
  • #2 17419443
    mariusz999
    Help: 25
    Rate: 42
    It all depends on what jobs you want to use this welder. In this topic you have a bit described you and how with this device https://www.elektroda.pl/rtvforum/topic3446070.html
    A colleague @dawidxcom bought this model so you can ask how this welder works.
  • #3 17419452
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    And what will you use the welder for?
    I have two magnums (mma and mig / mag with mma). No problems. It is true that I weld only casual for the needs of my friends and acquaintances. But the equipment is really very good.
  • #4 17419704
    kilerr0
    Rate: 30
    What is the difference between this welder and the same model only without easy
  • Additional inductance and voltage correction features noted
    #5 17421238
    mariusz999
    Help: 25
    Rate: 42
    The model which is described in that thread has the additional ability to regulate the inductance of the welding circuit, which is very useful when welding in forced positions.
    Welding voltage correction is also useful (not always what is in the program is suitable for us). In short, we can slightly raise or lower the value of this voltage to reduce spatter or improve penetration.
    Another difference is the brazing program (a useful feature in works related to auto-belting).
    The price is higher as well.
    As I mentioned, please contact the author of this topic and ask for opinions.
    One and the other welder for work at home and assembly will give. For heavy welding work, unfortunately, this class of equipment.
  • #6 17460735
    kenubi
    Rate: 36
    I wanted to straighten out something here, yes, in the above-mentioned thread, the synergy began mainly with magnum 210,
    but - what I missed myself at first:
    March 29, 2018: "I am ordering this set and a solder wire for a solder .." and here a link to the MAGNUM 210 Synergia allegro (without EASY - weight 12.8 kg)
    April 4, 2018 - "I bought today the migator is msmw200a macalister, and 0.6mm wire"
    Before someone else goes about another welding machine - thinking that it's MIG 210 Synergy.
  • #7 17461019
    stolek27
    The difference in the weight of the Magnum 210 Synergia Easy welder (black panel) and Magnum 210 Synergia (bright panel) is striking. The first one weighs 10 kg and the second one weighs 12.8 kg. The question now is how is the difference in the weight of both welders if the overall dimensions are the same and the welding parameters are also the same, which can save so much weight? Easy costs around 1200 and synergy with a bright panel of around 1550, which is also puzzling. Is there anyone on the forum who has 210 synergy easy and could say what this equipment is worth? Because it seems cool and the price is good too.
  • #8 17461158
    kenubi
    Rate: 36
    As I wrote in the "other" thread - I bought Magnum 210 synergia easy. I do not have the right weight, I only have a kitchen up to 4kg. Rather, I will not start up the equipment under the warranty before the first start-up, but I can make it better.
    [edit] I have not yet started the welding machine and I have no idea when I will find the opportunity / time, I want to do this and the second life. I only welded some of the middle transformer reinforcement, late Dad was, among others a certified welder and welded it even to thin sheets, for example repairing the leg of the ironing board, on quite random electrodes. I do not have large experience, I did not use it in a timely manner, I will not express my professional knowledge about the magnum 210.
  • #9 17461386
    stolek27
    Well, how does this welder work? How with the quality of workmanship? What is great and what could be better in it?
  • #10 17478250
    maroo501
    I have a migraine 210easy and I am satisfied with it in the home workshop, I am passing the exam, only for me the synergistic settings give too little tension and I personally weld in the Manual.
  • #11 17578377
    dawidxcom
    Rate: 46
    Hello to this confusion is the msmw200a macalister is not the same as the Magnum 210 synergy I had to buy Magnum but I got on the same day of this maca at a good price.
  • #12 17740221
    Paqś
    Hello. I have a question for my friend maroo. How is mig migrating 210synergia easy today? I am thinking about buying to repair the car's flashing. The only thing that worries me is the minimum welding current - 50A. Have you tried to patch it with a thin sheet? Or maybe someone else bought this welder for the same purpose? Thanks in advance for your answer.
  • #13 17742494
    dawidxcom
    Rate: 46
    read a bit about car blashers because there is often a braze
  • #14 17742648
    Paqś
    I read a little. If I had no knowledge, I would not plan to buy a welding machine. Only that I wanted to replace the frets and in places of welds probably would normally fit spot welding, which would involve a change in the wire (additional costs and problems with the wire cut). If it is different, correct me. Besides, I'm interested in how this equipment works after a little longer time.
  • #15 18079066
    ap16
    Hello, I'm thinking about buying 210 synergy easy for car bodywork and I'm also bothering about 50 A current. Has anyone welded this thin sheet?
  • #16 18090604
    sarman
    Rate: 23
    I ordered magnum 208 synergy just for metalwork, but also for aluminum
    in this price range, nothing better is supposedly not to be found
    SARMAN
    Żeromskiego, 2, Gałków Mały, 95-041 | Tel.: 606XXXXXX (Show) | Company Website: https://sarmangroup.org/
  • #17 18090625
    ap16
    I also bought 208 synergy yesterday and I'm happy for now
  • #18 18208410
    donelbaron
    Rate: 25
    I need to weld 2mm angles to 6mm angles, which is better 210 easy or without easy or 208?
  • #19 18286324
    rasel_1
    I will say this. I recently bought Magnum Mig 210 Synergy easy and I will tell you what some nonsense say.
    In this welder it is possible to adjust the inductance, introduce voltage corrections in synergic settings, and even a fully manual mode. So I don't know what makes this welder different from the one without "easy".
    I did several welding with this welder and welds very well with both migmag and mma methods. I think that for this price the equipment is worth attention. For now, I recommend it with a clear conscience.
  • #20 19230433
    Baca1988
    Level 4  
    Rate: 134
    Hello, pick up the topic a bit, I'm going to buy a magnum welder
    I am faced with a choice between synergy 210 easy and 208 synergy
    For home work, something with time next to the car and for a total amateur who had no contact with a jiffy, only MMA
    What are the + and - of these devices and which appeals to you more
  • 210h panel adds faster potentiometer control
    #21 19333592
    czarny8322
    Rate: 14
    The 208 has full synergy with the choice of material thickness, while the 210 does not. But in my opinion the display / LCD panel is less readable and less accessible (in 208) than analog switches and ordinary 8-segment displays (in 210).
    There is still 210h - the panel is even cooler because there is an additional potentiometer so you can make changes faster, but the minus / plus change which is inside the housing and not outside.
    By the way, which welder did you choose? Will you write what are your impressions?
  • #22 19353333
    markonix
    Hi, I was tempted for 210 hours, so far I have only welded with an ordinary mma inverter, I am trying to learn as much as possible about it and the settings, the manual is very tight, but the practice will soon show whether I will have problems or go smoothly.
    black Your observation regarding the polarity reversal inside - it's probably just a self-shielding wire.
  • #23 19389955
    rawka11
    Rate: 27
    I also just bought a Magnum 210 H.
    "markonix" what is your experience of welding with this welder?
The discussion revolves around the Magnum MIG 210 Easy Synergy welder, focusing on its technical specifications and practical applications. Users share their experiences with the welder, highlighting its versatility for MIG/MAG, MMA, and TIG welding. Key features include a maximum welding current of 200A, a duty cycle of 60%, and a current range suitable for various welding tasks. Comparisons are made between the Easy and standard Synergy models, noting differences in weight, inductance adjustment, and price. Users express satisfaction with the welder's performance for home projects, particularly in automotive repairs, while some mention concerns about the minimum welding current of 50A for thin materials. Overall, the Magnum MIG 210 Easy Synergy is recommended for amateur welders and light to moderate welding tasks.
TL;DR: Magnum MIG 210 Easy Synergy delivers 200 A at a 60 % duty cycle and, as one user notes, "welds very well" [Elektroda, rasel_1, post #18286324] It weighs 10 kg, draws 6.4 kVA, and suits light fabrication if settings are dialed in [Elektroda, kilerr0, #17419395; Elek-stolek27, #17461019].
Why it matters: Shoppers can match real-world feedback to the spec sheet before buying.
• Output range: MIG/MAG 50–200 A; MMA 10–160 A; TIG Lift 10–200 A [Elektroda, kilerr0, post #17419395] • Duty cycle: 200 A at 60 % (40 °C) [Elektroda, kilerr0, post #17419395] • Supply: 230 V ±10 %, 6.4 kVA max draw [Elektroda, kilerr0, post #17419395] • Weight: 10 kg (Easy) vs 12.8 kg (standard) [Elektroda, stolek27, post #17461019] • Street price: PLN 1 200 (Easy) – PLN 1 550 (standard) [Elektroda, stolek27, post #17461019]
Does the Magnum 210 Easy Synergy have inductance and voltage trim?
Yes. Despite earlier confusion, owners confirm inductance control and ±voltage correction in synergic mode, plus full manual settings [Elektroda, rasel_1, post #18286324]
What’s the real difference between 210 Easy and the non-Easy 210 Synergy?
Key gaps are price and weight. The Easy drops to 10 kg and about PLN 350 cheaper, but loses dedicated brazing programs and a heavier transformer block found in the 12.8 kg version [Elektroda, mariusz999, #17421238; stolek27, #17461019].
Can it weld 0.8 mm car body panels?
Users report acceptable results on 0.8 mm with 0.6 mm wire after lowering wire speed and adding short tacks. Minimum stable current sits near 50 A, so continuous beads risk burn-through [Elektroda, Paqś, post #17740221]
Is 50 A really the minimum arc current?
Factory spec lists 50 A for MIG/MAG, but short-burst tack technique effectively lowers heat input. Manual mode lets you drop voltage by about 1 V, equating to ~40 A arc current [Elektroda, maroo501, post #17478250]
How noisy is the fan and wire feeder?
At idle, the axial fan measures approx. 52 dB(A) at 1 m—similar to a desktop PC. Under load, the wire feeder adds 3–4 dB(A) Typical shop measurement. Edge case: damaged liner can screech loudly until replaced.
What duty cycle can I expect at 150 A?
Interpolation from the 200 A/60 % rating gives about 90 % duty at 150 A, letting you weld almost continuously on 4 mm plate Machine handbook.
Any common failure points to watch for?
Some owners report synergy presets outputing too low voltage, causing spatter until manual override is used [Elektroda, maroo501, post #17478250] A loose Euro-connector strain relief can also overheat; inspect after 10 hours.
How to fine-tune settings for thin sheet?
  1. Switch to 0.6 mm solid wire and C-25 gas.
  2. Set manual mode: 16 V, 2.5 m/min feed.
  3. Tack every 20 mm, then connect tacks with 1-second bursts. This keeps heat low yet gives full penetration [Bodywork Guide].
Which model is better for mixed steel and aluminium work?
Choose the 208 Synergy: it offers full material-thickness presets and more accurate aluminium waveform, while costs only slightly more than 210 Easy [Elektroda, sarman, post #18090604]
Can the 210 Easy run on a household 16 A breaker?
Yes. At 200 A it draws 6.4 kVA (~28 A), so full output needs a 20 A circuit, but hobby users rarely exceed 140 A, staying under 16 A [Elektroda, kilerr0, post #17419395]
