JVC LT-40V750 LED TV: No Image, Sound & Backlight OK - Need Firmware for 17MB97 Mainboard
sorinede 3876 1
  • #1 17419813
    sorinede
    Hello, this TV has sound, has backlight, but no image..I have tried some firmware from the net on USB method, but not the good one, because it was not working..
    Fuse on t-con is good, not seen some problem on it.
    So I need firmware for USB stick method for this TV....I thanks anticipated
    Mainboard is 17MB97, Display is VES400UNDS-20-N11
    any idea from someone ??
    nobody ??
  • #2 17423650
    sorinede
    Hello good morning everyone, I see nobody could help me... I have connected to TV and PC (s.o UBUNTU) a USB to TTL adapter via euoscart, and when I power on the TV I got a file on PC display.... I see some bad blocks on NAND.. if someone can interpret them.. I am not so advanced on this.. thank you in advance.
    • USB READINGS .txt (6.08 KB) You must be logged in to download this attachment.
