Combining Amica DAW 8143/7123 Steam Touch Washer & Candy Slim CS4 H7A1DE-S Dryer: Setup Tips
Thaiphoon 14511 7
  • #1 17459850
    Thaiphoon
    Welcome
    I have a problem because I do not know how to connect the washing machine Amica DAW 8143 DSiBTO Steam Touch 8kg depth 47cm or alternatively Amica DAW 7123 DCiBT Steam Touch 7kg depth 49.5cm with the Candy Slim CS4 H7A1DE-S dryer depth 46cm. Both devices are 59.5 cm wide. Has anyone of you set up such devices?
    There are connectors for slim devices, but dedicated to specific models, e.g .: https://www.euro.com.pl/wyposazenie-do-pralek-i-suszarek/hoover-łącznik-35100023-bialy.bhtml " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://www.euro.com.pl/wyposazenie-do-pralek-i-suszarek/hoover-łącznik-35100023-bialy.bhtml or https://mediamarkt.pl/agd-do-zabudowy/łącznik-do-pralki-suszarki-candy-stkg-kit-td-slim " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://mediamarkt.pl/agd-do-zabudowy/łącznik-do-pralki-suszarki-candy-stkg-kit-td-slim .
    The manufacturer cannot comment if the devices are from different companies.
    Maybe some of you have experience with connecting slim devices? The washing machine must be at least 7-8kg and the dryer at least 7kg.
    Thanks in advance for your help
  • #2 17459904
    PanAGD
    Help: 65
    Rate: 112
    I think that no one in the forum will know the answer to this question. There is no problem with equipment from the same company with connection. In the above-mentioned case, the case can be settled only by trying on yourself.
  • #3 17459921
    Thaiphoon
    He would just like to avoid checking it on his own equipment. Do you even know any universal connector for slim devices?
  • #4 17460278
    PanAGD
    Help: 65
    Rate: 112
    Unfortunately not. I have not yet had the opportunity to solve such a problem with the client. I only know cases where customers above a washing machine gave a furniture board cut to size, attached it to the wall, and put a dryer on it. I didn't know how it turned out. After the spare parts do not go, as I pass them in the city they do not have a sewn head, so it probably works ;)
  • #6 17470379
    Thaiphoon
    gdw wrote:
    Why do you want this connector? Set up without him. I've been like this for a year and it's ok.
    I had a slightly different problem: https://www.elektroda.pl/rtvforum/topic3383073.html#16764269
    I know your post. Why, then, produce these connectors? I admit that I would be afraid to put the dryer on the washing machine without a connector and zero space for the dryer during its operation. The idea that I like the reinforced shelf the most.
  • #7 17472088
    gdw
    Rate: 38
    But what space are you talking about? And what is it needed for? You might as well lift the dryer on its feet, for what?
    These connectors somehow position the dryer on the washing machine. From what I know, they are attached to the countertop of the washing machine, so it is not a super reliable solution. And they mask the legs and the gap between the washing machine and the dryer, although it depends on the type of connector. In addition, we know why - money.
  • #8 19129600
    przemopg
    Rate: 17
    Hello Forum members,
    Did you manage to solve this problem. I have a similar question regarding the equipment: the Amica DAW 7123 DCiBT washing machine and the Candy GrandoVita GVS4 H7A1TCEX-S dryer.
    What fastener to use?
    Thank you in advance for all your help and hints.
    Best wishes,
The discussion revolves around connecting the Amica DAW 8143/7123 Steam Touch washing machines with the Candy Slim CS4 H7A1DE-S dryer. Users express uncertainty about using connectors designed for slim devices, particularly when the appliances are from different manufacturers. Some participants suggest that while dedicated connectors exist, they may not be necessary, as one user has successfully operated their dryer on top of the washing machine without a connector. Concerns about stability and space during dryer operation are raised, with suggestions for alternative setups, such as using a reinforced shelf. Another user inquires about a similar setup with the Amica DAW 7123 and Candy GrandoVita GVS4 H7A1TCEX-S dryer, seeking advice on suitable fasteners.
