Bosch WAN2416EPL vs Amica DAW 7123 DCiBT: Compare Washing Machines, Features & Budget Choice
barteklbn 6468 3
  • #1 16946888
    barteklbn
    Hi.
    My washing machine has fallen, and due to the fact that it is essential equipment, I have to make a decision quickly. In the current Hoover VHDS 6143ZD-86S washing machine, the bearings have seized so much that the belt keeps coming off the pulley. The rest of the washing machine works fine, it's a curiosity that you can't just replace these bearings and you have to throw away working equipment.
    The budget is PLN 1500 (or more if it's worth it).
    I want the bearings to be replaceable, and flexible programming - the ability to choose the temperature / spin speed. (It's probably the standard today?)
    During a quick search, I chose two favorites, which choice will be better? What would you personally choose? What are the pros / cons?
    1. Bosch WAN2416EPL
    2. Amica DAW 7123 DCiBT
    Or maybe there are other manufacturers in this class that are worth a closer look?
    While viewing a similar Amica washing machine, I did not notice a water drain hose in the place of the filter. It is possible that this washing machine does not have it? In the previous washing machine, I used it several times during the filter clogging and pump failure.
    Felini
    Moderator
    Help: 124
    Rate: 433
    I have had a Bosch WOH 4210 washing machine for about 20 years, it works to this day. The only thing I mentioned are the carbon brushes in the motor. There is a drain hose, I used it 2-3 times.
    Today, hardware models change frequently. The old ones - like mine - are no longer produced, not much can be said about the new ones from the perspective of a longer period of use, because they are too short on the market. This is how the circle closes.
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    I opt for one of the types of LG washing machines, which is supported by the possibility of replacing the bearings, a brushless motor with a 10-year warranty, mounted directly without a drive belt, adjustment of the spin speed and several other functions. At the moment, in my circle of friends and at my place, four copies of this manufacturer are working without any problems. Due to the small bathroom space, I recommend the LG F10C3LD type with a load of 5 kg, besides, I must admit that the washing machine works relatively quietly.
  • Amica lacks drain hose by filter; Bosch uses belt drive
    #4 16949721
    barteklbn
    I got a response from Amica regarding the drain hose:
    In response to your e-mail, we would like to inform you that our washing machines do not have a drain hose next to the filter.
    The Bosh washing machine I replaced (WAN2416EPL) also has a brushless motor with a 10-year warranty, but it probably comes with a belt as standard.
    Both washing machines have the option of easily replacing the bearings.
    I am thinking about choosing between these two models because they are at a very similar price, Amica is the latest model in the series and has some "gimmicks", Bosh is rather a standard, so basically the question is about the differences in the quality of workmanship, whether BOSH washing machines beat on the head in this regard those of Amici?
