[Solved] KIANO Slimnote 14.1: Unresponsive Keyboard & BIOS/UEFI Reset Attempt with Battery Removal
tracer111 13902 9
How can I reset or recover a Kiano Slimnote 14.1 when the keyboard stops responding in UEFI and disconnecting the battery does not restore the settings?
Disconnecting the battery does not seem to reset this model; the likely issue is a bad BIOS/CMOS setting, such as USB support being turned off, which can leave only the power button and display working [#17467732] The practical recovery is to reprogram the BIOS flash chip with a programmer [#17467862] The chip is reportedly a 1.8 V flash, but you can desolder it and program it with a 3.3 V programmer [#17468266][#17473234] Use the correct 8 MB dump, not the 1 MB file, because the 1 MB image was identified as wrong [#17468634][#17473234] After flashing the proper image, the laptop reportedly returned to normal operation [#17474419]
  • #1 17467708
    tracer111
    After the laptop earlier I could move in uefi / shell, when after a while the keyboard stopped responding to buttons, the keyboard has a button on / off so the keyboard detects, I wanted to remove the battery to restore factory settings, but there is no such in this model, also the main battery was disconnected for about 30 minutes and then nothing.
  • #2 17467732
    zjo
    Help: 144
    Rate: 276
    I had a similar problem in this model after playing with CMOS settings, I turned off USB support. Unfortunately, the device is so funny that after USB everything is supported and after saving the settings only the switch and the display worked. Even the flash, used as a disk in this equipment, ended cooperation, only the EFI console was loading. I ended up replacing the disc under warranty. It's basically a tablet that looks like a laptop, it's an idea, but a dear manufacturer could cut the option to disable USB support from the settings.
  • #3 17467862
    tracer111
    : / does anyone have a batch in this laptop? I have a programmer so I'd like to try to reprogram the bios bone
  • #4 17468266
    zjo
    Help: 144
    Rate: 276
    Take into account that bios sits there, if I remember correctly, 1.8v flash. I was also thinking about throwing the batch, but I have a programmer only for 3.3v memory. I probably didn't find the charge, but maybe since then it has appeared somewhere.
  • #5 17468634
    tracer111
    I tried to upload the batch which I found here on the forum for kiano slimnote 14.1, the backup I did was 8mb, the bios I downloaded 1mb, I tried to get it up, the laptop tries to stand up, i.e. the diode lights up, but it doesn't give me any image, I'd like to try some more ripples but it's hard to find anything for this ... Disposable kiano laptop tablets
  • #6 17468929
    zjo
    Help: 144
    Rate: 276
    Exactly. They were cheap and one-time.
  • #7 17470834
    Borygo123
    Help: 122
    Rate: 196
    I have this invention (slimnote 14.1), but I don't have a programmer. If someone found in Bialystok with the programmer I could give him a chance to rip it to be a technical wonder.
    grzewoj
    Help: 115
    Rate: 133
    It doesn't matter, you need to desolder it and throw it on the 3.3V programmer, it will work
    I put the batch found on the network, it should have 8MB, that 1MB is incorrect
    • Slimnote 14.1 54524_EM_I8316_v3.0.zip (2.81 MB) You must be logged in to download this attachment.
  • #9 17473266
    zjo
    Help: 144
    Rate: 276
    For me, it's too late, as I wrote, Kiano replaced the disc. But the author will probably be happy.
  • #10 17474419
    tracer111
    Thanks so much for the batch! Everything's back to normal
The discussion revolves around issues with the KIANO Slimnote 14.1, specifically an unresponsive keyboard and attempts to reset the BIOS/UEFI. Users shared experiences of similar problems, often linked to changes in CMOS settings, particularly disabling USB support. Some attempted to reprogram the BIOS using a programmer, but faced challenges due to voltage compatibility and incorrect BIOS file sizes. A user successfully restored functionality after obtaining the correct BIOS batch file. The conversation highlights the device's limitations and the need for specific technical solutions to address firmware issues.
