[Solved] Kiano SlimNote 14.1 + - an error pops up during system reset, and no d
Robert Stasiak 5760 7
  • #1 16791378
    Robert Stasiak
    Rate: 14
    Resetting the settings to the initial system state on the Kiano laptop flash drive. An error pops up during the reset. I cannot enter cmd as an administrator because I do not have the confirmation button Yes, only No is visible, so I wanted to restore to the initial settings.
    dawidgrud
    Hello, I recommend to visit any electronic service and ask for formatting it will not be expensive or try to enter the bios and restore the system there
    Best wishes :)
  • #3 16792375
    Robert Stasiak
    Rate: 14
    Hello thank you for your reply, I have UEFI I don't know where recovery is?
  • #4 16795478
    dawidgrud
    It depends on the system you have. I would recommend seeing in the search engine how to restore the system (e.g. win 7 depending on your system). :)
  • #5 16796893
    Robert Stasiak
    Rate: 14
    Hello!
    I already know how to restore the system in Windows 10.
    I enter the control panel later in system recovery, or from UEFI in the Windows Recovery tab.
    I tried different ways: factory reset, recovery from recovery partition.
    In any case, the attempts will fail. Most likely, the partition will be damaged.
    Best regards, thank you for the answer, every route that leads to solving the problem is good.
    safbot1st
    Help: 2719
    Rate: 1583
    What?
    Assuming that recovery is not possible due to a flash data error you have to @_robert_ Stasiak obtain the W10 USB installation medium, and assuming physical flash damage give this low-quality device a guarantee.
  • #7 16808131
    Robert Stasiak
    Rate: 14
    Hello!
    Problem solved. Chinese defeated. After entering the control panel from Windows, then system recovery, advanced options, then the UEFI tab.
    After restart in the control panel, system recovery, advanced and cmd console, there I managed to enter with administrator privileges Kiano X: \, then after restart, I activated the system administrator account entered in the system with subsequent commands and assigned my account to the administrators group. After restart, I gained access to the system and it appeared
    Yes button. I have recovered the system.
    PS.Partition Recovery is still damaged, but I have it somewhere, I made an image and a copy of the system.
    Greetings to all those helping to solve Robert Stasiak!
  • #8 17022936
    Robert Stasiak
    Rate: 14
    Hello!
✨ The discussion revolves around a user experiencing an error while attempting to reset their Kiano SlimNote 14.1 laptop to its initial system state. The user is unable to access the command prompt as an administrator due to the absence of a confirmation button. Various suggestions are provided, including visiting an electronic service for formatting and exploring BIOS options. The user later discovers how to access system recovery through UEFI and successfully resolves the issue by activating the system administrator account and gaining access to the system. Although the recovery partition remains damaged, the user has created a system image for backup.
