Polo 9n 1.9 TDI 2002: Coolant Warning Lamp Persistent Illumination Post Gasket Replacement
marcin900 17985 9
Why does the coolant warning light and buzzer keep coming on in a 2002 Polo 9N 1.9 TDI after a head gasket replacement even though the coolant level, sensor, wiring, and temperature readings are normal?
The false coolant warning was most likely caused by bad solder joints on the instrument cluster connector pins, so re-soldering the clock/cluster plug sockets fixed it [#17481694] [#18507080] The OP confirmed that after soldering the plugs, the warning stopped and did not return during a full day of driving [#17481728]
  • Instrument cluster fault likely causing false coolant warnings
    #1 17481507
    marcin900
    Hello, the problem is Polo 9N 1.9 TDI engine code ATD year 2002
    Since I made a gasket under the head, the indicator light (engine overheating) burns too high or there is no fluid in the tank. (as in the picture). Polo 9n 1.9 TDI 2002: Coolant Warning Lamp Persistent Illumination Post Gasket Replacement
    The situation looks like this:
    After ignition of the engine on a cold at the beginning of the day, the indicator will light up more than once after driving a few kilometers. Later, every firing lights up immediately or after a while. It blinks and a one-time buzzer sounds.
    ----- Fluid in the tank is topped up even a little over ---
    What I did:
    1 - I cleaned the tank - Nothing helped
    2 - I replaced the tank with a new one - NOTHING HELPED -
    3- I measured on one cable from the plug to the tank is the weight with the engine the other goes directly to the meter cube on the right, I gave a jumper from the cable - NOTHING HELP
    4 - I gave weight from the engine directly to the meter - NOTHING HELPED
    5 - I cut off the cable right next to the clock plug, thinking that it might be damaged somewhere (I measured it with a meter and had a passage but I wanted to eliminate its possible defect) I connected a new cable to the plug at the tank - Nothing helped
    6 - I replaced the coolant temperature sensor in the head connector (gray) - NOTHING HELPED
    7 - no errors in the computer
    8 - I looked at the temperature on the indicator, the pointer stands correctly vertically, on a connected computer the temperature does not exceed 92 degrees.
    I HAVE NO CONCEPT WHAT IS GOING ON AND WHAT THIS CONTROL IS LIGHTING FOR. Can there be something with clocks? When I test the clocks on the computer, the indicator lights up and goes off correctly.
    ----------------- Have any ideas ? -----------------
    • Polo 9n 1.9 TDI 2002: Coolant Warning Lamp Persistent Illumination Post Gasket Replacement temperaturya-płynu.jpg (12.65 KB) You must be logged in to download this attachment.
  • #3 17481728
    marcin900
    Jarzabek666 wrote:
    The meter may be damaged, soldering plugs often loom in February.
    I just pulled down the counter. This is February from plugins. At first glance, it's ok. But for the sake of peace it translates. Polo 9n 1.9 TDI 2002: Coolant Warning Lamp Persistent Illumination Post Gasket Replacement Polo 9n 1.9 TDI 2002: Coolant Warning Lamp Persistent Illumination Post Gasket Replacement
    Added after 15 [hours] 31 [minutes]:
    Yesterday I sold the plugins and it is a success. Today I rode all day and nothing caught fire. Thanks and best regards
  • #4 17483066
  • #5 17495344
    marcin900
    It's been a few days and the problem has not returned.
  • #6 18506697
    gracus7
    Help: 37
    Rate: 201
    I read and do not understand the words "soldered plugins" too much, I would guess it is about February sockets on the meter board but what about these plugs ??
  • #7 18507080
    marcin900
    It's exactly February sockets, even more precisely the pins of the incoming plug sockets for clocks. Let's not take a word. Everyone knows what's going on, the more a photo is added.
  • #8 18509370
    gracus7
    Help: 37
    Rate: 201
    It is not about catching words, I have been struggling with this problem for a long time. the meter was soldered by someone before, but despite this, I improved the February on the plug socket, replaced the container with a new one and then the indicator lights up. Interestingly, after disconnecting the temperature sensor plug, the computer reports a G62 sensor error but the temperature on the meter is still shown. as if the meter would receive information about the temperature from some other sensor. Hands fall because the light still harasses the owner of the polo.
  • #9 18509459
    marcin900
    Did you improve February on one or both plugins? I corrected all the pins on both sockets. Try to fix the cable directly to the tank from the meter. I think I described what color because I don't remember anymore.
  • #10 18511255
    gracus7
    Help: 37
    Rate: 201
    February all corrected, wires also checked. The question is where the meter receives the signal about the liquid temperature, since the sensor is disconnected. What a car, someone once said that polo is not VW ;)
The discussion revolves around a persistent coolant warning lamp issue in a 2002 Polo 9N 1.9 TDI (engine code ATD) following a head gasket replacement. The user reports that the engine overheating indicator activates shortly after starting the engine, even with adequate coolant levels. Various troubleshooting steps were taken, including cleaning and replacing the coolant tank, checking wiring connections, and measuring electrical signals. A key suggestion involved inspecting the soldering of the meter's plug connections, which ultimately resolved the issue after the user replaced the faulty plugs. The problem did not recur after the repairs.
