Polo 6n2 1.4 TDI (2000) Undercharged Turbine: Error 17964, Replaced Sensor, N75 Valve & Vacuum
nazarr1 10941 15
  • #1 16482213
    nazarr1
    Rate: 8
    I have a small problem with the turbine in the 1.4 tdi from 2000. From the dynamic logs it looks like an undercharged turbine to around 2500.
    Polo catches the note, after restarting it is ok. Vag crashes error 17964 - i.e. undercharging.
    I replaced the boost pressure sensor, checked the vacuum to make sure I replaced them all.
    I also checked the N75 valve and it works fine.
    I also checked that the barbells do not cut and it also looks ok (pumping air with a syringe works throughout the entire range)
    Logs from group 11 look like this http://vaglog.pl/log-011_x4osf9.html
    Or maybe a clogged catalyst can show such symptoms?
    When looking for the reasons, it turned out that the flexible connector is slightly leaky, I will replace it and I wonder if I should cut the catalyst immediately.
    Maybe someone had similar problems or will be able to tell me something that can still be checked to find out the cause of the problem.
  • #2 16482455
    Popielaty
    Help: 15
    Rate: 11
    First of all, I would detach the lung from the blade bar on the turbine and check whether it can be moved in the entire range, without any cuts, and whether the blades do not cut. Second, a flexible joint, if it is leaky, the exhaust gases will run out, but it is behind the turbine and should not have much of an impact. I am puzzled by this undercharging at lower revs, only at the revolutions of 2079 is the first reaction of the N75 valve. Write how you made the logs.
  • #3 16482557
    nazarr1
    Rate: 8
    I checked the barbells in such a way that I connected the syringe and pressed the plunger. The barbells walked in full range without cuts.
    I made the logs in such a way that I spread out on three and somewhere from 1500 gas to the floor and to the end. The car was definitely warm because I chased it away on the bypass.
  • #4 16482594
    Popielaty
    Help: 15
    Rate: 11
    Write down how you checked the correct operation of the N75 valve. Did you check the 011 group with VAG in Basic Settings where the computer controls the N75 valve to periodically open and close the turbine geometry?
  • #5 16482654
    nazarr1
    Rate: 8
    I wrote it wrong, there is no n75 but n21 as in the attached diagram. I took it out and checked that it closes and opens while energizing.
    • Polo 6n2 1.4 TDI (2000) Undercharged Turbine: Error 17964, Replaced Sensor, N75 Valve & Vacuum 2e50add4cbaacaef.jpg (36.58 KB) You must be logged in to download this attachment.
  • #6 16482767
    Popielaty
    Help: 15
    Rate: 11
    If you can, do the static logo 011 in BS and we will see how this valve is actuated.
    like here in this video:
    link
  • #7 16488196
    nazarr1
    Rate: 8
    Only today I managed to make logs, see the link below
    http://vaglog.pl/log-011_xqec3l.html
    I would like to add that I always catch a note when it is cold in the morning, right after starting off. Later in the day it is already driving normally.
  • #8 16488344
    Popielaty
    Help: 15
    Rate: 11
    The logo shows that something is wrong. Whether the valve is actuated to 100% or 0%, the boost pressure does not change. This is how I look at this drawing and photos of turbines on the net and it turns out that you have no geometry in the turbine, only a wastegate valve controlled by an overpressure-controlled coo. If you have the option of connecting a pressure gauge to the hose that comes to the coo, check if there is excess pressure there by making the 11 BS static logo.
  • #9 16498514
    nazarr1
    Rate: 8
    Unfortunately, I was unable to get a vacuum gauge, but I checked if there was negative pressure by connecting a syringe to the turbine bulb. I fired up the BS and group 11 again and it turned out that there was no vacuum. It is also not present before n21. What could be responsible for this
  • #10 16498822
    żałosna udręka
    Help: 191
    Rate: 1019
    The pear is controlled by pressure from the collector, not by vacuum. Check that the valve is not letting the wastgate close.
  • #11 16503529
    nazarr1
    Rate: 8
    I checked again and my pear is controlled by negative pressure, drawing air from the pear, the barbells move. In the first post I wrote wrong it should be pulling the air out.
    In that case, what creates a vacuum for me that controls the pear. Unless I think wrong
  • #12 16505596
    żałosna udręka
    Help: 191
    Rate: 1019
    Follow the thread to the ball. Check where the hose is led from. If you're lucky, you'll find a wipe. If not, replace the valve. Normally the vacuum gauge is connected in several places to find the cause.
  • #13 16613849
    nazarr1
    Rate: 8
    I am still fighting the note, I replaced the n21 and unfortunately it did not help.
    I replaced the boost pressure sensor, n21, all hoses and the error continues.
    Could it be a pear that opens the valve not fully or too late, i.e. n21 gives pressure to the pear but it opens only at a higher pressure than it should
  • #14 16613953
    żałosna udręka
    Help: 191
    Rate: 1019
    Have you checked the flow meter? What error throws?
  • #15 16614064
    nazarr1
    Rate: 8
    Crashes error 17964 - low pressure regulation doladowania
    I have not checked the fish pass, as it can affect it, I will check it.
    The strange thing is that it always strangles it in the morning after firing the first time, then after turning it off and restarting it, it already runs normally.
  • #16 16614551
    marfur30
    Help: 136
    Rate: 380
    Check the vacuum hoses going to the EGR solenoid valve and the EGR itself.
✨ The discussion revolves around a 2000 Polo 6N2 1.4 TDI experiencing an undercharged turbine issue, indicated by error code 17964. The user has replaced the boost pressure sensor and checked the N75 valve, but the problem persists, particularly noticeable when the engine is cold. Various troubleshooting steps are suggested, including checking the turbine's blade movement, verifying the operation of the N21 valve, and ensuring proper vacuum pressure. The user also considers the possibility of a clogged catalyst and a leaky flexible connector contributing to the issue. Despite replacing several components, the error continues, prompting further investigation into the EGR system and flow meter.
