[Solved] Best Digital Cameras Under PLN 800 for Amateurs: Recommendations for Capturing Baby's Moments
draniu_pawc 3861 7
  • #1 16729708
    draniu_pawc
    Please help. I am looking for a digital camera (I probably will not get a DSLR at this price) for an amateur. Main purchase due to the birth of a child. I would like to spend about PLN 800 for this purpose (more less than more). What is cool at this price could you recommend?
    Thanks in advance for your help.
    best regards
  • #3 16729750
    mariuszp19
    Help: 311
    Rate: 410
    I have a CANON EOS 350D DSLR with a grip, an extra battery and an 18-55 USM lens. You can easily fit this price. The camera, although it has its age, is used occasionally. I will add CF cards. Give me something on piva.
  • #4 16729788
    draniu_pawc
    I found, for example, 3 types, what do you think about them?
    1. CANON PowerShot SX620HS (about 700 PLN)
    2. SONY Cyber-shot DSC W830 (550)
    3. KODAK PIXPRO AZ421 (700)
    I do not hide that if there are no great differences between them, then I would rather take the cheaper one ...
    marcode
    Help: 88
    Rate: 76
    Currently, you will buy Samsung NX1100 or maybe even NX3000, great cameras with matrices as in the current modern SLRs, I would not bother with monkeys because the quality, even under the cloud, is average.
  • #7 16732930
    Marcin85K
    Panasonic Lumix DMC-TZ58
  • #8 21406876
    draniu_pawc
    topic to be closed
The discussion focuses on recommending digital cameras under PLN 800 suitable for amateur photographers aiming to capture baby moments. Suggested compact cameras include the Panasonic Lumix DMC-TZ58, Canon PowerShot SX610 HS, Canon PowerShot SX620 HS, Sony Cyber-shot DSC W830, and Kodak PIXPRO AZ421, with price considerations influencing choice among similar models. Additional advice highlights Samsung NX1100 and NX3000 mirrorless cameras as alternatives offering advanced sensor quality comparable to modern DSLRs, though potentially above the budget. The conversation also references older DSLR options like the Canon EOS 350D with an 18-55mm USM lens, noting availability in the used market. Links to detailed reviews for Canon PowerShot SX620 HS and Sony DSC W830 provide further technical insights. Emphasis is placed on sensor quality, price-performance balance, and suitability for amateur use in family photography contexts.
