[Solved] Needed: Vestel 17MB211 Dump for Telefunken TE32269B38Y2D, Chassis 17MB211, VES315WNDA-2D-N12
Acca85 16212 14
How can I get a working dump or firmware for a Telefunken TE32269B38Y2D with Vestel 17MB211 when the TV won’t turn on and has no standby LED?
Flash a working firmware dump into the SPI flash; in this case the TV’s Winbond 25Q16JVSIQ memory was completely empty, and after programming it with the firmware from the linked topic the TV started working [#17570113] A dump was also offered from a similar setup using a CROWN 32289T2SM with a 17MB110P board and VES315WNDA-2D-N12 panel, but it was considered too different from the 17MB211 board and was not used [#17558098][#17561795][#17562473]
  • #1 17556784
    Acca85
    Rate: 19
    Mark: Telefunken
    Model: TE32269B38Y2D
    Chassis (main board, components): 17MB211
    LCD Screen/Panel (if exist): Ves315WNDA-2D-N12
    More informations: Smart tv, double tuner.
  • #2 17557167
    billobirillo
    Help: 338
    Rate: 797
    what's the fault?
  • #3 17557190
    Acca85
    Rate: 19
    Won't turn on, no standby led, PSU is working just fine, I do find some voltages on the motherboard so I wanted to try flashing.
  • #4 17557710
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Insert your friend photo of the TV model sticker .
  • #5 17557764
    Acca85
    Rate: 19
    Sure, I've uploaded the panel sticker too.
    Needed: Vestel 17MB211 Dump for Telefunken TE32269B38Y2D, Chassis 17MB211, VES315WNDA-2D-N12 Needed: Vestel 17MB211 Dump for Telefunken TE32269B38Y2D, Chassis 17MB211, VES315WNDA-2D-N12
  • #6 17557934
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    I have dump but under the matrix ves315wnds-2d-n14, ves315wnds-2d-n15 with the same main
    I mistyped VES315WNDA ...-VES315WNDS...
  • #7 17557996
    Acca85
    Rate: 19
    elmo071 wrote:
    I have dump but under the matrix Ves315WNDA-2D-N14, Ves315WNDA-2D-N15 with the same main
    I don't know what the differences are between the panels..caould you post it anyway? I'll search for infos about the panels, if I can't find nothing I'll just save a backup of its firmware and try yours.
  • #8 17558098
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Mainboard similar and matrix
    MODEL : CROWN 32289T2SM
    PŁYTA: 17MB110P
    PAMIĘĆ : MX25L1605
    MATRYCA: VES315WNDA-2D-N12
    Dump to check
    • CROWN_32289T2SM.rar (5.55 MB) You must be logged in to download this attachment.
  • #9 17561795
    Acca85
    Rate: 19
    Thanks for posting but I decided not to flash this dump as the board is too different, I think nothing good could come from flashing it's dump.
    So my requests still stands, I need another dump.
  • #10 17562382
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Mainboard they are similar
  • #11 17562473
    Acca85
    Rate: 19
    Yeah I can see that but the board I have on this tv has a sat tuner, wifi support, there could be a different processor under that heatsink.
    It has a completely different model code 17mb211 vs 17mb110p, I thank you for your effort, sometimes you listen to your gut and now mine is telling me this is too different even if the general layout is VERY similiar.
    Again, thank you tho.
    Edit:
    I found this
  • #12 17562588
    artur0089
    Help: 64
    Rate: 163
    Acca85 , let me see your software?
  • #13 17562726
    Acca85
    Rate: 19
    I still haven't tried to read it since I have to desolder the IC from the board 'couse the clip won't fit between the heatsink and the SAT module.
    I'll post it as soon as possible tho.
  • #14 17570113
    Acca85
    Rate: 19
    So this morning I desoldered the memory from my board (winbond 25q16jvsiq) and tried to read it but it was completely empty, and I mean it, no data at all.
    So I flashed the firmware from the the topic I linked earlier and the tv now works.
  • #15 18103382
    khalid XD
    Rate: 10
    PŁYTA: 17MB110P
    PAMIĘĆ : MX25L1605
    Dump to check
The discussion revolves around the need for a firmware dump for the Telefunken TE32269B38Y2D TV, which utilizes the 17MB211 chassis and the VES315WNDA-2D-N12 LCD panel. The user reports that the TV won't turn on and has no standby LED, despite the power supply unit (PSU) functioning correctly. Various users contribute by sharing similar firmware dumps and discussing the differences between the mainboards and panels. One user successfully flashed a firmware dump from a different model, which resolved the issue, while others express caution about flashing incompatible firmware due to potential differences in hardware components.
TL;DR: 1 successful SPI-flash fix: the user desoldered a Winbond 25Q16JV and "the tv now works." For Telefunken TE32269B38Y2D with Vestel 17MB211 no-power, check the SPI dump and reflash a known-good 17MB211 firmware. [Elektroda, Acca85, post #17570113]
Why it matters: It guides 17MB211 owners and bench techs to a proven no-standby recovery path.
How do I fix a Telefunken TE32269B38Y2D (17MB211) that won’t power on?
Verify your PSU. If stable, focus on the mainboard SPI flash. In the documented case, the Winbond 25Q16JVSQ read empty. Flash a known-good 17MB211 firmware and retest. The set booted immediately after programming. "the tv now works." [Elektroda, Acca85, post #17570113]
What symptoms suggest corrupted firmware on a 17MB211 board?
Typical signs are no standby LED with a good PSU. The user also measured some voltages on the mainboard. That combination points to logic or SPI firmware issues, not the power supply. "Won't turn on, no standby led." [Elektroda, Acca85, post #17557190]
Which SPI flash chip is on this 17MB211 board?
The repaired unit carried a Winbond 25Q16JVSQ SPI flash. The chip was removed to be read and programmed off-board. That identification came from the successful repair report. [Elektroda, Acca85, post #17570113]
Do I need to remove the SPI chip to program it on 17MB211?
Plan for removal. The clip had no clearance beneath the heatsink and SAT tuner can. The user desoldered the SPI IC to access it safely. "the clip won't fit between the heatsink and the SAT module." [Elektroda, Acca85, post #17562726]
How big is a 25Q16JV dump?
A W25Q16JV is 16 Mbit, which equals 2 MB. That is the full-size binary you will read or write during service. Ensure your programmer is set for 2,097,152 bytes. [W25Q16JV Datasheet]
Can I flash a 17MB110P dump onto a 17MB211 mainboard?
Avoid cross-flashing. The 17MB211 set here had SAT tuner and Wi‑Fi, and the owner rejected a 17MB110P dump. Hardware options and SoC can differ. "this is too different" despite similar layouts. [Elektroda, Acca85, post #17562473]
Are VES315WNDA-2D-N12, N14, and N15 panel dumps interchangeable?
Match panel codes exactly. A helper offered dumps for VES315WNDS-2D-N14 and N15, not N12. Suffix differences matter for timing and configuration. Use a dump that matches your exact matrix ID. [Elektroda, elmo071, post #17557934]
What if my SPI reads as empty?
Treat it as erased or corrupted firmware. Program a verified 17MB211 image and test. In this case, the SPI read "completely empty" and the set recovered after flashing. That sequence confirmed a firmware-rooted failure. [Elektroda, Acca85, post #17570113]
Where can I get a working 17MB211 firmware for this case?
The repair used firmware from the forum thread previously referenced by the user (topic3498680). After flashing that image, the TV powered up normally. Search the forum for the 17MB211 package. [Elektroda, Acca85, post #17570113]
Should I back up the original firmware before flashing?
Yes—always save a backup if the chip is readable. The poster planned a backup before testing another dump. Preserving the original image gives you a recovery path if needed. "I'll just save a backup of its firmware." [Elektroda, Acca85, post #17557996]
Does SAT tuner and Wi‑Fi presence affect firmware compatibility?
Yes. The discussed 17MB211 had SAT tuner and Wi‑Fi, which influence firmware build options. Pick a dump that matches those hardware features to ensure proper operation. The owner flagged this as a key difference. [Elektroda, Acca85, post #17562473]
What alternative dump was proposed in this thread?
A dump was offered for a different set: CROWN 32289T2SM with mainboard 17MB110P, SPI MX25L1605, and VES315WNDA-2D-N12 panel. It was presented as "Dump to check." Evaluate hardware differences before use. [Elektroda, elmo071, post #17558098]
Is the power supply at fault here?
Unlikely in this scenario. The PSU was reported as working fine, yet there was no standby LED. That shifts focus to the mainboard and SPI firmware. "PSU is working just fine." [Elektroda, Acca85, post #17557190]
How do I reflash the SPI on 17MB211 safely? (3 steps)
  1. Desolder the SPI flash (Winbond 25Q16JVSQ) for reliable access.
  2. Read and check the dump; if empty or corrupt, prepare a known-good 17MB211 image.
  3. Program the chip, verify, resolder, and power-test the TV. [Elektroda, Acca85, post #17570113]
