[Solved] X96 Mini TV Box Android 7.1.2 (2GB 16GB) - Freezing Issues on YouTube & CDA, Solutions Needed
andken999 21120 4
  • #1 17580003
    andken999
    Help: 58
    Rate: 167
    X96 mini tv box Android 7.1.2 2GB 16GB andriod TV BOX freezes after about 30 minutes on YT and also on CDA. Has anyone had a problem with this or know what's going on?
    Please help.
    adversus
    Level 32  
    Help: 188
    Rate: 597
    Check two things to see if the device is getting hot, and second, look for updates sometimes. Perhaps this is a problem.
  • #3 17583040
    andken999
    Help: 58
    Rate: 167
    It warms up a bit, but I put a fan under it and tested it, the device was cool and, unfortunately, got stuck after 30 minutes. Updates did not help either.
  • #4 17639076
    andken999
    Help: 58
    Rate: 167
    I have found the solution is all right thanks to the Cheng Cheng movie download link in the movie description x96 mini Upgrade steps and firmware https://youtu.be/SwD_EXrJmoc Regards.
  • #5 17642014
    andken999
    Help: 58
    Rate: 167
    As above in the description.
