[Solved] ACER Aspire 5 A515-51G - Keypad Backlight Customization: Constant Light / Extended Time
m4xon 29364 13
  • #1 17709879
    m4xon
    Rate: 73
    I have an ACER Aspire 5 A515-51G laptop. I wonder if it is possible to change the backlight of the keyboard so that it is lit constantly or extend the time of the backlight?
    Thanks
  • #2 17710077
    DriverMSG
    Help: 3984
    Rate: 4833
    m4xon wrote:
    Is it possible to change the backlight of the keyboard so that it is lit continuously or extends the backlight time?
    What's wrong with him?
    FN and F9 keys not working?
  • #3 17715426
    m4xon
    Rate: 73
    they work, but they only turn the backlight on or off, and I would like to extend the backlight, after 2 seconds it goes out and for me it's not enough
  • #4 17715456
    DriverMSG
    Help: 3984
    Rate: 4833
    With the power supply connected, it goes out? Power options set correctly?
    Well, I do not know if there is no sensor in it that turns off the keyboard when it is bright?
  • #5 17715471
    m4xon
    Rate: 73
    as a rule, I work without a power supply on the pen, I looked in the power settings, but I did not find anything that could be strictly responsible for the keyboard backlight
  • #6 17715475
    DriverMSG
    Help: 3984
    Rate: 4833
    On the battery itself, it will turn off the backlight - it's normal. Check operation with power supply.
  • #7 17715482
    m4xon
    Rate: 73
    that's why I'm looking for a solution to get around it to extend the time, it has to be written somewhere
  • #9 17715568
    m4xon
    Rate: 73
    How to get to the ME driver? there is no info in QA
  • #10 18028472
    m4xon
    Rate: 73
    I want to set the backlight to continuous? Anyone suggest something?
  • #11 18077127
    Narcoser
    Hell let me tell you I have the same thing with Acer Swift 3. I didn't think it could be so annoying. I did not take it into account when buying. Everything was fine on my previous Lenovo Y50-70. It shone as much as I wanted and until I turned off .. and now; / Did you find any solution from this trash?
  • #12 18109952
    kwakx30
    I have the same at my place and I flew every page and nothing. I am waiting for a solution too.
  • #13 18128536
    Narcoser
    Hey, I wrote with the Acer team in the chat and they told me to update the bios to the latest version and look for the glowing keyboard option in its settings. Unfortunately it wasn't. The guy said that these bios are being updated successively and that probably the next update will contain the option to change this snag.
  • #14 18843402
    m4xon
    Rate: 73
    Unfortunately, I did not find a solution.
✨ The discussion revolves around the ACER Aspire 5 A515-51G laptop's keyboard backlight functionality. The user seeks a way to keep the keyboard backlight on continuously or to extend its duration beyond the default 2 seconds. Responses indicate that the backlight behavior may vary when the laptop is connected to a power supply versus running on battery. Suggestions include checking power settings and the Management Engine (ME) driver for options, as well as updating the BIOS to potentially unlock additional settings. Other users express similar frustrations with backlight limitations on their Acer devices, indicating a broader issue with Acer's keyboard backlight customization.
TL;DR: Backlight timeout on Acer Aspire 5 A515-51G was reported as 2 seconds; “after 2 seconds it goes out.” FN+F9 only toggles on/off, with no user‑found timer control. This FAQ explains checks and realistic options. [Elektroda, m4xon, post #17715426]
Why it matters: It helps Acer Aspire owners who ask how to keep their keyboard backlight on or extend its timeout.
How do I keep the Acer Aspire 5 A515-51G keyboard backlight on constantly?
There is no confirmed built‑in way in this thread to keep it always on. The author later reported no solution found. Consider checking AC power and BIOS, but expectations should remain modest. [Elektroda, m4xon, post #18843402]
What is the default keyboard backlight timeout on this model?
One owner reported approximately 2 seconds before it turns off. They wanted a longer duration but did not find a setting. This is a user‑observed value, not an Acer spec. [Elektroda, m4xon, post #17715426]
Does the backlight timeout change on battery versus when plugged in?
Yes. On battery, the keyboard backlight turns off automatically. The advice in the thread was to test with the power supply connected. This helps isolate power‑saving behavior. [Elektroda, DriverMSG, post #17715475]
Can Windows power options change the keyboard backlight timeout?
No participant found a keyboard backlight timeout in Windows power plans for this model. The OP checked power settings and found nothing relevant. Windows did not expose that control here. [Elektroda, m4xon, post #17715471]
Is there a BIOS setting to adjust the keyboard backlight duration?
Support advised updating the BIOS and checking its menus. After updating, a user still found no keyboard backlight option. “Unfortunately it wasn’t.” That reflects the edge case where updates delivered no fix. [Elektroda, Narcoser, post #18128536]
Can Acer Quick Access or Intel ME settings change the backlight timer?
A participant asked about Intel ME and Acer Quick Access. The OP replied there was no information about the backlight in Quick Access. No timer control was confirmed there. [Elektroda, m4xon, post #17715568]
How do I toggle the A515-51G keyboard backlight?
Use FN+F9 to toggle the keyboard backlight. A responder highlighted these keys during troubleshooting, confirming this is the shortcut. Ensure the function row is active. [Elektroda, DriverMSG, post #17710077]
How do I test if AC power changes the backlight behavior? (3 steps)
  1. Connect the AC adapter to the laptop.
  2. Press FN+F9 to enable the keyboard backlight.
  3. Stop typing and observe whether it remains on longer than on battery mode. [Elektroda, DriverMSG, post #17715475]
Does this affect other Acer models like Swift 3?
Yes. A Swift 3 owner reported the same behavior and frustration. “I didn’t think it could be so annoying.” Cross‑model reports suggest firmware‑level control. [Elektroda, Narcoser, post #18077127]
What should I do if FN+F9 doesn’t work on my Aspire 5?
Verify your Acer drivers and utilities are installed from the model’s support page. Install Acer Quick Access if missing. Then reboot and retest the FN+F9 toggle. [Elektroda, sosarek, post #17715514]
Are there confirmed third‑party tools or registry tweaks to keep the light on?
No confirmed tools or registry tweaks were shared in this thread. The OP later stated they did not find any solution. Use hardware toggles and BIOS checks instead. [Elektroda, m4xon, post #18843402]
What’s the realistic path to a fix for this backlight behavior?
Contact Acer Support and monitor BIOS releases. A user was told to update BIOS and check for a setting; none existed after updating then. Keep systems updated and recheck occasionally. [Elektroda, Narcoser, post #18128536]
Is there a sensor that disables the keyboard backlight in bright environments?
A responder raised the possibility of a brightness sensor affecting the keyboard. The thread did not confirm such a sensor on the A515‑51G. Treat it as unverified in this context. [Elektroda, DriverMSG, post #17715456]
