Understanding Diffusion LEDs: Characteristics for Uniform Light Distribution
Tosiek_123 38314 4
  • #1 1794848
    Tosiek_123
    Help: 7
    Rate: 16
    What are the characteristics of a diffusion LED? I need a diode that shines in such a way that the light can be seen from every viewing angle. I don`t care about the diode shining in spots (like super-strong diodes for flashlights). I would also like it to not show any darker or brighter points when looking at the diode light, I need it to shine uniformly over its entire front surface. I hope someone will help me. Thanks in advance.
    żarówka rtęciowa
    Help: 364
    Rate: 394
    The diffusion LED has a frosted lens, unlike a regular diode, which allows it to shine at a larger angle.
    dee jay G
    Help: 71
    Rate: 41
    In a diffusion diode, you cannot see the structure inside (it does not shine "in spots" like a super bright one). You are looking for such a diode.
    Regards
    hace00
    Rate: 8
    I once made something like this using ordinary diodes to illuminate the inside of a computer - I sanded the whole diode a bit with fine sandpaper and it turned out fine.
    Regards
  • #5 1798280
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    Kingbright, or whatever the company is called, produces (I think he was the first one to start)
    super bright red diodes, designation L53SRxy, where x and y indicate the housing
    and brightness - if you need high brightness and diffused light, then L53SRDH.
    x=C (clear - focused beam), x=D (diffused - dispersed),
    y=A,B,C,D,E,F,G,H - the further away, the greater the brightness and price.
