Building 100W LED Growlight With 5W Diodes: Color Ranges, Angles, and Wiring Advice
387 12
How can I build a 100W LED grow light using 5W LEDs, and how should I wire and drive the different colors and beam angles?
You should build it as several series LED strings, each on its own constant-current driver, and not wire the 5W LEDs in parallel [#21663318][#21663322] For high-power LEDs, a switch-mode constant-current regulator is the best choice; examples mentioned were the LM3404 or a ready-made LED driver module, and the driver supply must be slightly higher than the driver’s maximum output voltage [#21663318][#21663322] Avoid simple resistor drive from mains because it is inefficient, produces a lot of heat, and can blow LEDs; if you do use PWM for efficiency, be aware that flashing light might be an issue for plants [#21663322][#21663326] For grow-light spectrum, one reply suggested blue light for growth and red light for flowering, so your mix should be chosen by experimentation rather than a fixed recipe [#21663322] The thread also notes that your final arrangement will depend on your budget, power source, and how many LEDs you place in each series string [#21663322]
  • Clarifying LED angles and color mix for 100W growlight
    #1 21663317
    Doug Jackson
  • Constant-current driver recommended for 5W LEDs
    #2 21663318
    Steve Lawson
  • #3 21663319
    Richard Comerford
  • #4 21663320
    Doug Jackson
  • #5 21663321
    Doug Jackson
  • Series strings need constant-current drivers
    #6 21663322
    Steve Lawson
  • #7 21663323
    Steve Lawson
  • #8 21663324
    Doug Jackson
  • Recommend starting separate threads for follow-up questions
    #9 21663325
    Steve Lawson
  • #10 21663326
    Steve Lawson
  • #11 21663327
    Doug Jackson
  • Microcontroller PWM phase shifting may cause light direction flicker
    #13 21663329
    Steve Lawson
The discussion focuses on constructing a 100W LED growlight using 5W diodes with beam angles of 60°, 90°, and 120°, arranged as 20 diodes per panel. The desired spectral output includes deep blue (450 nm), blue (470 nm), red (620 nm), deep red (665 nm), and warm white (430-700 nm) LEDs for optimal plant growth. Key technical advice emphasizes that high-power LEDs are current-driven devices requiring constant current (CC) drivers, preferably switch-mode regulators such as buck converters. Suggested driver solutions include ready-made modules and integrated circuits like the Texas Instruments LM3404. Wiring should avoid parallel connections; instead, multiple series strings each powered by individual CC drivers are recommended. Power supplies should be switched-mode power supplies (SMPS) with voltages slightly above the total LED string voltage. Pulse-width modulation (PWM) is noted as an efficient driving method, but potential effects of flicker on plants are uncertain, suggesting possible phase-shifted PWM control via microcontrollers to minimize simultaneous flashing. Commercial LED growlight products exist, such as those from Lighting Science and RhinoGrow, but DIY construction is pursued for cost-effectiveness and experimentation with color combinations. Additional considerations include the impact of LED beam angles on light distribution and the importance of proper electrical design to ensure reliability and plant health.
TL;DR: Use 5 W LEDs with constant‑current drivers; “The #1 rule for LEDs is they are current devices.” Plan series strings and safe power. [Elektroda, Steve Lawson, post #21663318]
Why it matters:** This FAQ helps DIYers wire reliable 100 W LED growlight modules for seed starts without frying diodes.
What is a DIY LED growlight in this thread’s context?
A DIY growlight here is an LED array for starting vegetables indoors, inspired by modular fixtures like RhinoGrow. The use case is early-season seedling growth in colder climates. Spectrum choices target plant stages. Blue supports growth; red drives flowering response. [Elektroda, Steve Lawson, post #21663322]
How many 5 W diodes make a 100 W module?
Twenty 5 W diodes total approximately 100 W (20 × 5 W). This was the target panel size proposed in the thread. Keep electrical headroom in drivers and thermal design when selecting current setpoints to avoid overstress. [Elektroda, Doug Jackson, post #21663317]
Should I wire LEDs in series or parallel for reliability?
Use series strings, not parallel branches, and drive each string with its own constant‑current (CC) driver. This improves current sharing and reduces runaway risk. Quote: “drive them in series (NOT parallel).” [Elektroda, Steve Lawson, post #21663322]
What kind of LED driver should I choose?
Pick a switch‑mode constant‑current driver (buck type) sized for your LED string voltage and current. Examples mentioned include TI LM3404 and vendor driver modules; selection tools help match specs quickly. [Elektroda, Steve Lawson, post #21663318]
What power supply should feed the CC drivers?
Use an SMPS from the mains to supply your CC drivers. Provide a voltage slightly above the driver’s maximum LED string voltage. Higher supply voltage lowers current for a given power but increases handling complexity. Include EMI filtering and surge suppression. [Elektroda, Steve Lawson, post #21663322]
Can I run LEDs straight from the mains with resistors?
You can rectify AC and use high‑wattage resistors, but it’s very inefficient, gets hot, and can blow LEDs. It is also dangerous and potentially lethal if wires are exposed. If attempted, derate LED power and enclose all conductors. [Elektroda, Steve Lawson, post #21663322]
Which beam angles are practical: 60°, 90°, or 120°?
Those three angles are common choices in DIY arrays. Narrow beams (60°) increase intensity at distance; wider beams (120°) improve uniform coverage at close range. Select per canopy size and hang height. [Elektroda, Doug Jackson, post #21663317]
What wavelengths did the builder target for plant growth?
The thread’s target mix lists Deep Blue 450 nm, Blue 470 nm, Red 620 nm, Deep Red 665 nm, plus Warm White spanning 430–700 nm. This provides tunable energy around chlorophyll peaks and some full‑spectrum fill. [Elektroda, Doug Jackson, post #21663317]
Why use blue vs. red LEDs for plants?
Blue light supports vegetative growth, while red light encourages flowering. Use more blue for starts and more red later. This spectrum strategy guided the wiring approach and channel grouping in the discussion. [Elektroda, Steve Lawson, post #21663322]
Is PWM dimming OK for growlights?
PWM is efficient for high‑power LEDs, but flashing could be detrimental to plants. Consider whether the duty‑cycle frequency is benign for horticulture before adopting PWM. Test plant response if you add modulation. [Elektroda, Steve Lawson, post #21663326]
How can I reduce visible flicker if I use PWM?
Control each string with a microcontroller and phase‑shift PWM outputs so strings don’t switch simultaneously. This spreads current pulses and reduces perceived flicker and ripple. Watch for directional light shift artifacts on the canopy. [Elektroda, Steve Lawson, post #21663329]
Could I mix PWM channels with steady side lighting?
Yes. The thread suggests adding steady CFL side lights to offset PWM effects. This can stabilize perceived illumination while you experiment with duty cycles and spectra on the main array. [Elektroda, Doug Jackson, post #21663327]
Are there off‑the‑shelf alternatives if I don’t want to DIY?
Yes. Commercial LED growlights were noted as available, with Lighting Science cited as working on such products. Prebuilt fixtures save design time and safety validation. [Elektroda, Richard Comerford, post #21663319]
What is a constant‑current (CC) LED driver?
A CC driver regulates current through the LEDs, which behave as current‑driven devices. This prevents thermal runaway and brightness drift when supply or temperature changes. Quote: “LEDs are current devices.” [Elektroda, Steve Lawson, post #21663318]
Quick how‑to: how do I plan and wire a 100 W, 5 W‑LED panel?
  1. Group LEDs into series strings targeting your current and total forward voltage; avoid parallel LED branches.
  2. Pick one CC buck driver per string; feed them from an SMPS sized above the string voltage.
  3. Add EMI filtering and surge protection; enclose wiring for safety; test current before full power. [Elektroda, Steve Lawson, post #21663322]
