[Solved] Comparing 230V LED Strips vs 12V/24V: Performance, Durability, Types & Brightness Options
oun 33249 11
Are 230V LED strips worth choosing over 12V/24V strips in terms of brightness, durability, and overall performance?
12V/24V strips are generally the safer and cheaper choice, while 230V strips mainly make sense when you need long runs with thinner wiring and want to avoid a separate power supply [#17250396][#17250415] The downside of 230V is servicing: if one diode fails, you may have to replace about 1 m of strip instead of about 5 cm on a 12V strip [#17250502] Brightness and durability depend a lot on the strip’s internal construction and price, not just the nominal LED type; some 5050 strips are built better than others, and in better designs damage to one LED structure does not kill the other parts of the diode [#17250837] In the thread, the conclusion was that “there are tapes and tapes,” so the seller’s claims and the exact LED topology matter more than the headline 230V vs 12V/24V label [#17250766][#17250837] For a 20 m installation, 230V was considered attractive because wiring and power-supply sizing become simpler, but the thread still leaned toward 12/24V for safer and easier long-term service [#17250415][#17250766]
  • #1 17250229
    oun
    Help: 39
    Rate: 96
    As I have not dealt with LED strips for 230V so far, I am asking for opinions on them. I am particularly interested in their performance and durability.
    From what I have realized, they are available in such versions:
    Type Amount / m Power / m Brightness (lumen per diode) Price
    3528 60 4.8 5 3.5-6.5
    120 9.6 5 10
    3014 120 12 9-12 11.5
    240 24 9-12 17
    5050 60 4,8 5 5
    60 7.3 5.5
    60 10,5 5.8
    60 14,4 12 12.5
    5630 120 17 11
    5730 60 9.6 18-20 11
    120 19.2 18-20 16,5-18
    180 28 18-20 19
    240 28 22
    2835 60 6 8 5.6
    120 12 8 8.9
    156 6 10
    180 14.4 5-6 15
    276 22 5-6 23.5
    In the list I included the data declared by the sellers and please keep this in mind :)
    In my opinion, the disadvantages of LED strips for 230V include:
    - they can be divided every meter (except for 2835, 276 / m, which we divide every half meter),
    - they are only available in a waterproof version (silicone shirt),
    - installation on special holders (without adhesive tape),
    - rigidity (thickness),
    - and for formalities - dangerous tension.
    The advantages include:
    - power supply for long distances,
    - much smaller cross-section of power cables,
    - no power supply (although you need to buy a rectifier intended for them).
    I am wondering, however, about their durability and efficiency (amount of light), i.e. how is their power compared to LED strips at 12 or 24V?
    I would add that I had the opportunity to watch such tapes and although I did not have a direct comparison with others, I got the impression that less light gave and for example I will say that I have LED strip hereon 2835 diodes, 120 diodes per meter, which consumes 19.2W and it is difficult to look directly at it, because it blinds. However, the 2835 / 230V tapes I saw were not dazzled, although they had more chips on the subway. Which, in a way, can be understood because none of them consumed so much power per chip. No less in the 276 / m tape there are twice as many and in theory it should give more light.
    Oddly enough, I got the impression that the tape on 5050 (14.4W) chips gives more light than 5730 (28W) and also more than 2835 (14.4 and 22W).
    I am asking for an opinion on LED 230V strips, is it worth thinking about them?
  • #2 17250396
    Zbigniew 400
    Help: 283
    Rate: 794
    Service is 12/24 cheaper and safer.
    I reduced the supply voltage by 5%, the tapes have been lit for 5 years / 4 hours a day /.
  • #3 17250415
    oun
    Help: 39
    Rate: 96
    If we take into account the wiring and power supply, which must be efficient at high power consumption, then there will be no significant differences in the price. If the tapes are with a solid PCB, it will come out even more expensive (plus in favor of 230V tapes), and for 230V tapes we do not have to worry about whether the additional power supply segments, or from both sides, and service will be easier.
    I will add that I took up the topic due to the need to install 20 meters of tape.
  • #4 17250502
    Zbigniew 400
    Help: 283
    Rate: 794
    1 diode has failed
    12V exchange 5cm
    230V replacement 1m.
  • #5 17250541
    oun
    Help: 39
    Rate: 96
    Zbigniew 400 wrote:
    1 diode has failed
    12V exchange 5cm
    That's right, and I followed this line of reasoning, but the seller confused me by saying that with 5050 diodes (three-chip) when one chip burns, the diode shines with 66% power. He didn't have such a damaged diode to show it to me, but he had a tape with other chips and I saw a meter section with one diode damaged, which was the only one that was not lit.
    At this point, it will tie to 5050 tapes and how can they shine brighter than 5730 with higher power consumption? I saw two tapes connected at the same time and I had such an impression.
  • #6 17250740
    Zbigniew 400
    Help: 283
    Rate: 794
    But a specialist from this seller.
  • #7 17250754
    oun
    Help: 39
    Rate: 96
    So the case that the diode burned so badly that the current flowed through it?
    It surprised me and information about the 5050 with a burnt-out chip (the other two shine) in three-chip versions also.
  • #8 17250766
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    Not necessarily.
    Have you noticed that there are tapes and tapes? Sometimes the same, and 2x more expensive.
    One diode will burn so that it creates a break, another short circuit.
    In some structures there is such a small mysterious dot, it is responsible for LED conduction in case of its damage (break) What element is it? Look and you will find.
    Besides, it is covered with silicone, and this does not bode well.
    For me, there are only 12 / 24VDC tapes and silicone heat guns.
    Believe me, years of assembly of kilometers of tapes ...
  • #9 17250784
    oun
    Help: 39
    Rate: 96
    I would not dare to flood with silicone because I have seen many a destructive silicone after years but those 230V are not flooded but pressed into the shell, silicone sleeve.
    Justyniunia, and how is it with these three-chip 5050 and does one damaged chip only result in a power reduction of 1/3?
    I am still bothered by whether or not silicone, which absorbs several lumens, is there a noticeable difference in the amount of light emitted between the 230 and 12V tapes?
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    The better yes, damage to one structure in the chip does not extinguish the other two connected in a series of structures in the other two diodes (they are connected three LEDs in series).
    In one strips the diodes are connected chip-chip (that's good) in others all 3 chips in parallel and through the resistor with the other two diodes in series (wrong).
    Unfortunately, it all depends on the tape (price) ...
  • #11 17251080
    oun
    Help: 39
    Rate: 96
    Thank you very much for the explanations, and you can see better quality tapes and now it begins to form a logical whole. Namely, the seller highly praised those from the 5050 series, which I approached critically, i.e. not taking them into account beforehand. Probably their quality could also be seen by the amount of light they emit, because they should give less logic from 5730 and 2835, and here they shone brighter despite it. I would add that the seller indicated that he took them from another manufacturer, which he had been checking for years. And while I am skeptical about this type of assurance, I can only explain why I saw what contradicts logic.
    My favorite were 2835 or 5730, and I left the store dumber than I entered, because 5050 destroyed my plans and instead of confirming my belief, I gained bigger doubts :)
  • #12 17307561
    oun
    Help: 39
    Rate: 96
    Time to close the topic and thank you again to everyone who spoke in the topic.
    Special thanks to the user Justytniunia .
The discussion centers on comparing 230V LED strips with 12V/24V options, focusing on performance, durability, and brightness. Users highlight that 12/24V strips are generally cheaper and safer, with easier serviceability. However, 230V strips may offer advantages in terms of installation efficiency for longer runs, as they do not require additional power supply segments. Concerns are raised about the failure rates of diodes, particularly in 5050 models, where a single chip failure can reduce brightness but not extinguish the entire diode. The quality of LED strips varies significantly, with some users expressing skepticism about the claims made by sellers regarding brightness and longevity. The conversation concludes with a consensus on the importance of selecting high-quality strips, particularly favoring 2835 and 5730 models over 5050 due to their performance characteristics.
TL;DR: 5 years at 4 h/day after a 5% voltage reduction shows DC strips can last; “12/24 is cheaper and safer.” [Elektroda, Zbigniew 400, post #17250396]
Why it matters: This FAQ helps DIYers and installers planning long runs (e.g., 20 m) decide between 230V and 12/24V LED strips for brightness, durability, and serviceability.
What are the real pros and cons of 230V LED strips vs 12V/24V?
Pros: long‑distance power, smaller cable cross‑sections, and no traditional PSU (use a rectifier). Cons: 1 m cut lengths (some 2835 276/m cut at 0.5 m), silicone sleeves only, special holders instead of adhesive, rigidity, and hazardous voltage. These impact design, service, and safety. [Elektroda, oun, post #17250229]
Which is better for a 20 m run: 230V or 12V/24V?
230V simplifies a 20 m install. You avoid multiple power injections or feeding both ends. When wiring and a robust PSU are included, total cost can be similar. Service can be easier on 230V segments. This came up when planning a 20 m project. [Elektroda, oun, post #17250415]
Is 12V/24V really safer and cheaper?
A contributor reports, “12/24 is cheaper and safer.” They lowered supply by about 5%, and the strips have run 5 years at 4 hours per day. This supports choosing low‑voltage for cost, safety, and durability in many installs. [Elektroda, Zbigniew 400, post #17250396]
Are 230V LED strips safe to use indoors?
230V strips operate at hazardous voltage, listed as a disadvantage in the thread. They come only in waterproof silicone sleeves and mount in special holders. Treat them with mains‑level caution during design and installation. [Elektroda, oun, post #17250229]
Why did a 5050 strip look brighter than 5730 or 2835?
Build and wiring vary between tapes. Some 5050 packages wire the three chips in series internally; others parallel them with a resistor. That changes current sharing and behavior. “It all depends on the tape (price).” Visual output can differ by construction quality. [Elektroda, Justyniunia, post #17250837]
Do 5050 three‑chip LEDs keep working if one chip burns out?
Often yes on better 5050s. “The better yes, damage to one structure in the chip does not extinguish the other two.” Some designs tie all three chips in parallel, which behaves worse under faults. Internal wiring quality determines the result. [Elektroda, Justyniunia, post #17250837]
If one LED fails, how much of the strip must I replace?
On 12V strips you replace a 5 cm segment. On 230V strips you replace a 1 m segment because of the cut unit. Factor this into maintenance planning. [Elektroda, Zbigniew 400, post #17250502]
Do silicone sleeves reduce performance or complicate service?
A veteran installer warns, “it is covered with silicone, and this does not bode well.” They avoid flooded designs and prefer 12/24 VDC tapes with silicone heat guns for sealing. Encapsulated sleeves can complicate field repairs. [Elektroda, Justyniunia, post #17250766]
How does brightness of 230V strips compare to 12V/24V at similar power?
One user found 230V 2835 strips looked dimmer than a 2835 DC strip at 120 LEDs/m, 19.2 W/m. A 5050 14.4 W/m strip appeared brighter than 5730 28 W/m and 2835 14.4–22 W/m. Perceived brightness varied across samples. [Elektroda, oun, post #17250229]
Do 230V strips need a power supply or rectifier?
They do not use a typical low‑voltage PSU. You need a rectifier designed specifically for 230V LED strips to power them correctly. [Elektroda, oun, post #17250229]
What are the cut increments for 230V strips?
Most 230V strips cut every 1 m. A notable exception is the 2835 version at 276 LEDs/m, which you cut every 0.5 m. Check your tape’s markings. [Elektroda, oun, post #17250229]
How can I extend LED strip lifespan with supply voltage?
Derate slightly. One approach kept strips running 5 years at 4 h/day with about a 5% supply reduction. How‑To:
  1. Set supply roughly 5% below nominal.
  2. Verify brightness remains acceptable.
  3. Monitor for stable operation and temperature. This simple derating improved longevity. [Elektroda, Zbigniew 400, post #17250396]
Why do some failed LEDs still pass current?
Failure mode varies by design. “One diode will burn so that it creates a break, another short circuit.” Some packages include a tiny bypass feature (a “dot”) to conduct when an LED opens. Expect inconsistent behavior across tapes. [Elektroda, Justyniunia, post #17250766]
How much does quality vary between seemingly identical tapes?
A lot. “There are tapes and tapes. Sometimes the same, and 2x more expensive.” Experienced assemblers report major differences in wiring, reliability, and failure behavior across suppliers. Price and build quality correlate. [Elektroda, Justyniunia, post #17250766]
