Wind Knocking on Eaves: HTC Hood Turned Off, Possible Causes & Solutions Explored
chris18404 18993 9
Why does the hood knock when it is windy while the hood is switched off, and how can I stop it?
The knocking is most likely caused by wind increasing the chimney draft and making a flap or another part in the hood move [#17768849][#17768985] If the noise is coming from the chimney, clean the chimney; if it is coming from the hood itself, find the part that is knocking and repair it [#17768978] Not every hood has a non-return flap, so check whether yours has one and whether it is moving properly [#17769028][#17769052] A practical fix mentioned is to glue the flap with a piece of self-adhesive sponge to soften the impact [#19696272]
  • #1 17768789
    chris18404
    Level 19  
    Rate: 78
    As in the subject, the hood is turned off and something knocks in it when there is wind, what can HTC be the cause?
  • #2 17768849
    Ture11
    Help: 573
    Rate: 1130
    Increased chimney draft causes something to move.
  • #3 17768896
    chris18404
    Level 19  
    Rate: 78
    What can be done about it
  • #4 17768978
    Rezystor240
    Help: 689
    Rate: 1651
    If it's in the chimney, clean the chimney.
    If it's in the hood, you need to track down what exactly is knocking and repair it.
  • #5 17768985
    płetwa
    Help: 165
    Rate: 551
    The hood has a non-return valve (flap) that prevents cold air from entering from the outside. When it blows properly in the chimney, a negative pressure is created which causes the flap to be lifted.
  • #6 17769028
    Rezystor240
    Help: 689
    Rate: 1651
    płetwa wrote:
    There is a non-return valve in the hood
    This does not happen in every hood.
  • #7 17769038
    chris18404
    Level 19  
    Rate: 78
    In the hood, the hood is new.
  • #8 17769052
    Rezystor240
    Help: 689
    Rate: 1651
    Does it have a flap like described above?
  • #9 19696154
    Zukens v40
    Seriously, what to do with it because I have the same thing and it's crazy
  • #10 19696272
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    Glue the flap with a piece of self-adhesive sponge to cushion the impact.
The discussion revolves around the issue of a hood being turned off while experiencing knocking sounds during windy conditions. Possible causes include increased chimney draft causing movement within the hood or chimney. Solutions suggested include cleaning the chimney if the issue is located there, or identifying and repairing the specific component causing the noise within the hood. A non-return valve (flap) in the hood may be lifting due to negative pressure created by wind, which can lead to knocking sounds. For new hoods, it is recommended to check for the presence of such a flap. A practical solution offered is to cushion the impact of the flap using self-adhesive sponge material.
