[Solved] Fixing Allegro Headphones: One Non-working Earbud - Causes, Repairs & Troubleshooting Tips
kelvin0909 34041 4
  • #1 17822246
    kelvin0909
    Level 4  
    Hello, I bought headphones for PLN 60 on the Allegro, but unfortunately they came to me with one of the headphones not working, but the company refunded me money for the damaged goods, and I thought that maybe I will repair them I do not know it very well, but I will try what you think it may be in the problem is that one earphone does not work, the earphones are not damaged, the outside is in perfect condition, I unscrewed the earphones, the right and left earphones and all the cables are connected, everything is fine and I have no idea what could be wrong with them, I think someone will help.
  • #2 17822300
    olador
    Level 37  
    Help: 429
    Rate: 1449
    kelvin0909 if you have already unscrewed them, check if the cable from the plug to the handset speaker has a passage.
  • #3 17822502
    kelvin0909
    Level 4  
    tell me how to check it, this is not an ordinary rubber cable, but a material one.
  • #4 17822715
    Aress124
    Help: 152
    Rate: 214
    It would be easiest to use the meter, if you have one, to set the continuity tester and check if there is a transition between the loudspeaker in the handset and the plug.
  • #5 17850593
    kelvin0909
    Level 4  
    The handset is defective
