AKG K77 – left side very quiet, what should I check?
SeBo232 9330 17
How can I diagnose and fix a left channel that suddenly became very quiet in AKG K77 headphones?
The most likely fault is a damaged left driver/insert, although the cable and jack should be checked first. One reply suggested bending the cable near the plug and moving it to see if the sound cuts in and out, because headphone cables often break there [#12665763] Another suggested jumpering the selected wires to test the effect; if only one side plays after that, the insert itself is damaged [#12665729][#12665838] If the driver is damaged, the practical options are to look for a replacement part on the forum or contact service for the repair price [#12665868]
  • #1 12665444
    SeBo232
    Hello to you!
    Recently, for some unknown reasons, left handset stopped working in AKG K77, the problem is so strange that I can still hear the sounds on the left, but very quietly, I do not know what the problem is, certainly not a software defect, more headphones, you have any tips?
  • #2 12665473
    pp74
    Help: 186
    Rate: 283
    Do you have a meter?
  • #3 12665495
    SeBo232
    Unfortunately, no, even if I had it I would not undress these headphones which is undoubtedly a disadvantage; / .. I will add that I connected them to the M-Audio Fast Track USB interface and after this session somehow the left channel stopped working
  • #4 12665508
    pp74
    Help: 186
    Rate: 283
    All you have to do is check on another device. If they are damaged, it will not work without disassembly.
  • #5 12665664
    SeBo232
    I just got inside and everything is connected as it should - I think the right earphone is still working and the left is still silence, the fault of the cable?
  • #6 12665729
    pp74
    Help: 186
    Rate: 283
    Now replace either inserts or wires between the right and left channels.
    If you do not have soldering equipment, please use the channels to go a step further.
    Upload a photo if you do not know which cables to replace
  • #7 12665757
    SeBo232
    Here's the photo :)
    Conclude - what do you mean?
    tomasz1987
    Help: 11
    Rate: 8
    And politely, you bent the cable around the spigot? grab it there, slightly bend it and wrap it so bent in your fingers that when you start creaking, you're in the jack for exchange.
    All but all headphones have a tendency to break the cable.
  • #9 12665780
    SeBo232
    To no avail, I wrapped myself in the whole cable, the earpiece did not speak for a second
  • #10 12665781
    pp74
    Help: 186
    Rate: 283
    Jumper the selected wires and check the effect.
    The picture is the one that does not play right?
  • #11 12665792
    SeBo232
    she spoke, she started to play
    Yes, exactly the one that does not play, i.e. Left handset with a cord
    Ie, I heard the law as I clenched these wires
    pp74
    Help: 186
    Rate: 283
    SeBo232 wrote:
    That's right, how I connected those wires
    She played the law. I asked if they both play after a melee.
    tomasz1987
    Help: 11
    Rate: 8
    heh jack to hush and new to put on the cable is broken, option 2nd I do so often
    new 2-channel cable for headphones in round insulation, is thicker than standard, but this cable break does not go :D
  • #14 12665828
    SeBo232
    exactly, I checked the tower, on two flaps and the interface.
    In this case, no, only the law spoke, the left remained silent, I was wrong to write - excuse me
    pp74
    Help: 186
    Rate: 283
    SeBo232 wrote:
    only the right was spoken, the left was still silent, I was wrong to write - excuse me
    If so, the insert is damaged.
  • #16 12665844
    SeBo232
    pp74 wrote:
    SeBo232 wrote:
    only the law was spoken, left was still silent , I was wrong to write - excuse me
    I guess it is not worth repairing?
    pp74
    Help: 186
    Rate: 283
    Ask on the forum, maybe some colleagues have such. You can also call the service if it is about the price.
  • #18 12665896
    SeBo232
    Well, more than worth it, I will probably buy new ones, thank you for your help, now I am sure that you listen to the garbage bin :)
The left handset of the AKG K77 headphones has stopped functioning properly, producing sound at a very low volume. Users suggest checking the headphones on different devices to rule out external issues. The author confirmed that the internal connections appear intact, leading to speculation about a possible cable fault. Suggestions include replacing the wires or using a jumper to test the connections. The discussion also highlights the common issue of headphone cables breaking and the potential need for repair or replacement of the headphones. Ultimately, the author considers purchasing new headphones after confirming the left channel's failure.
