BIOS mod Lenovo W520, T400, T410, X200, X201, X201 tablet, X220 (+warianty s, i)
Oneal 16743 26
  • #1 17946269
    Oneal
    Rate: 60
    The following posts contain instructions for the models:
    T400, T400s: https://www.elektroda.pl/rtvforum/topic3579342.html#17946371
    T410, T410i: https://www.elektroda.pl/rtvforum/topic3579342.html#17946290
    X200, X200s: https://www.elektroda.pl/rtvforum/topic3579342.html#17946340
    X201, X201i, X201s, X201 tablet: https://www.elektroda.pl/rtvforum/topic3579342.html#17946319
    X220, X220i: https://www.elektroda.pl/rtvforum/topic3579342.html#17946399
    t420 t420i : https://www.elektroda.pl/rtvforum/topic3580661.html#17954761
    L420 L421 https://www.elektroda.pl/rtvforum/topic3791136.html#19342356
    In this post, instructions for the model Lenovo W520
    Universal file to be uploaded by Windows like a normal bios.
    bios version 1.43
    first check if you have this version.
    If it is lower, use the original bios file, which is in the file.
    If the bios version is higher then don't even try.
    If the bios version is correct, just click the flash.bat file in the mod folder and wait for it to load.
    after uploading, enter the bios and disable security chip-disabled
    - unlocked
    - whitelist wifi wlan
    - hidden service menu
    - ram frequency up to 2133 MHZ memory from Mac PC3L DDR3-2133 (PC3-17000) works
    • Lenovo_W520 v1.43 org i mod.rar (15.02 MB) You must be logged in to download this attachment.
  • #2 17946290
    Oneal
    Rate: 60
    lenovo bios
    Model: t410 t410i
    bios version v1.45
    First check if you have this bios version in your laptop.
    If it is lower, flash the original bios first, then restart and then flash the bios mod.
    WinPhlash program (32 or 64 bit),
    select "Advanced Settings"
    then tick as below
    ("Flags" tab):
    [ ] Verify BIOS part number
    [ ] Flash only if BIOS version is different
    [ ] Flash only if BIOS version is newer
    [ ] Verify BIOS image size
    [ ] Verify BIOS checksum
    [ ] Zero block before erasing
    [x] Verify block after programming
    [x] Disable Axx swapping automatic detection (if present)
    [ ] Clear CMOS Checksum
    ("DMI" tab)
    "update": select "Update the BIOS and not DMI"
    After uploading, enter the bios, there you should disable the security chip-disabled option
    • ThinkPad_T410 t410i V1.45.rar (6.26 MB) You must be logged in to download this attachment.
  • #3 17946319
    Oneal
    Rate: 60
    Model: X201, X201i, X201s, X201 Tablet
    original bios and bios mod
    o unlocked whitelist wifi and wlan
    if it is lower, flash the original bios first, then reboot and then flash the bios mod.
    then tick as below
    ("Flags" Tab):
    ("DMI" tab)
    • ThinkPad_X201 org i mod.rar (6.08 MB) You must be logged in to download this attachment.
  • #4 17946340
    Oneal
    Rate: 60
    Model: X200, X200s
    version 3.22 (6DET72WW) for BIOS ID 6Dxxxxxx-
    3.22 (7XET72WW) for BIOS ID 7Xxxxxxx -
    first check if you have the same bios version. that is 3.22
    If it's higher, don't even try.
    after entering the bios you can see what version of the bios and how it starts with 6d or 7x
    whitelisted wifi and wlan
    after uploading the pkik, enter the bios and disable the security chip -disabled
    then tick as below
    ("Flags" tab):
    ("DMI" tab)
    • MOD x200 v3.22.rar (5.5 MB) You must be logged in to download this attachment.
  • #5 17946371
    Oneal
    Rate: 60
    Model: t400, t400s
    bios version 3.22 2.24
    open folder run winphlash and select
    - folder 3.23(7UET93WW) file - $01B8200.FL1 from folder 7UET93WW
    - for version 3.24(7VET94WW) file - $01B8100.FL1 from 7VET94WW folder
    after uploading the files, enter the bios and disable the security chip -disabled
    whitelist wifi and wlan unlocked
    then tick as below
    ("Flags" Tab):
    ("DMI" tab)
    • Lenovo ThinkPad T400_3.23(7UET93WW)-3.24(7VET94WW).rar (17.82 MB) You must be logged in to download this attachment.
  • #6 17946399
    Oneal
    Rate: 60
    Model: x220, x220i
    bios version v1.43
    unlocked
    hidden service menu
    unlocked ram frequency up to 1866Mhz, mac memory works, I think 2133 will also work, but I didn't have one to check. 1866Mhz are running on the bank
    unlocked AES-ini MSR 0xe2
    first check if you have this bios version, if lower then upload the original file first. only then mod.
    we enter the folder and click flash.bat.
    if it doesn't go right away, we do it through CMD consoles
    if the bios version is higher then don't even try
    • X220 v1.43 Mod i oryginalny.rar (10.2 MB) You must be logged in to download this attachment.
  • #7 18683723
    bonq1987
    then tick as below
    ("Flags" Tab):
    ("DMI" tab)
    Mod made according to the instructions. After installation, three beeps are emitted when starting the laptop followed by a pause and three more beeps. After that it boots normally.
    Is it possible to do a rollback to the original version to eliminate the pre-launch beeps, or another mod that doesn't generate startup delays and beeps?
    Regards.
  • #8 18684063
    Oneal
    Rate: 60
    go into bios and disable all intel chip security options and it will stop beeping.
    Added after 6 [minutes]:
    I can always make a bios mod for a specific board.
    to do this, first update your bios to the latest version. update chipset firmware me region. Then you desolder the bios bone, rip the batch with the programmer and send the bios dump to me in my free time I will make a mod, but for a fee.
  • #9 18720748
    piotrvx
    In Lenovo W520, after resetting the bios to default settings, the laptop does not start. You need to flash the bios with a programmer :(
  • #10 18725885
    Oneal
    Rate: 60
    This is because you have flashed a different bios version. The bios version in the laptop and the bios mod must be the same. Only then you upload and everything will be fine.
  • AMT disable breaks config access and fan control
    #11 19267800
    halasma
    Applies to X201
    I have a slightly different problem, After turning off AMT, there is no access to the config section (suspension occurs), the fan does not work (you can control it manually under windows, but this is not the target solution).
    Re-enabling/disabling AMT using Think_BIOS_Configurator does not have the desired effect, therefore the mentioned functions do not work.
    Resetting the bios to default, disconnecting the battery, updating or even downgrading also do not work.
    Is there any way to salvage it?
  • #12 19271083
    Oneal
    Rate: 60
    Please write what is the motherboard and bios version
  • #13 19271320
    1st
    Help: 59
    Rate: 169
    I have a W520 with 8BET63WW bios (1.43) once modded by someone. The "problem" is "beeping 5x twice" on startup, I don't know if something is wrong with the certificates? Can you fix it somehow? I'm asking because I don't want to upload files from you :-)
  • #14 19271352
    Oneal
    Rate: 60
    Go into the bios and check the security chip - disabled then it will stop beeping.
  • #15 19271665
    halasma
    Bios from this thread, modded, but it doesn't matter. It's the same on every one.
    Motherboard, if
    This is from the bios screenshot BIOS mod Lenovo W520, T400, T410, X200, X201, X201 tablet, X220 (+warianty s, i)
    If not, please let me know where to look for it.
  • #16 19271696
    1st
    Help: 59
    Rate: 169
    Oneal wrote:
    Go into bios and select secourity chip - disabled then it will stop beeping.
    I know that, I understand that all modded BIOSes cause this symptom?
  • Universal BIOS mod requires disabling security chip
    #17 19271952
    Oneal
    Rate: 60
    The board version is written on the motherboard itself.
    Not every bios mod causes this symptom. The best mods are made for a specific type of board because there are different versions of rev. Then there is no beep on startup. But for this you need a programmer to rip the batch from the bios bone.
    And not everyone has it.
    Therefore, the bios made is a universal modem and works on any type of board. To be uploaded with winflash. Anyone can upload. It beeps because the whitelist check instruction in the bios is bypassed and the loop goes straight to the place after the list after checking. The controller knows that he did not follow some instruction and something forces him to go ahead and confirm ok. Therefore, it is necessary to disable the security chip.
  • #18 19272006
    halasma
    There are such markings on my CD
    MP-3 MB
    08270-2
    48 4CV13.021
  • #19 19272044
    1st
    Help: 59
    Rate: 169
    Hmm, it's not necessary to disable the Security Chip, if it's enabled everything works, but there are these boot beeps. In Windows, TPM is seen correctly and can even be reset.
    Question:
    if I do not know what and how the BIOS was modded, I can upload a clean/original one, of course in the same version?
  • Check Intel AT module and computerface settings
    #20 19272165
    Oneal
    Rate: 60
    Question:
    if I do not know what and how the BIOS was modded, I can upload a clean / original one, of course in the same version?[/quote]
    how and what????
    ida is used to mod the bios. In fact, anyone can make the mod they want. unlock Tkip Aes MSR 0xE2 frekwency overclocking hidden service menu etc. there are a lot of possibilities.
    If you have a ripped backup, you can go back to the original version.
    If you don't have it, download the latest bios from the manufacturer's website and upload it.
    Added after 11 [minutes]:
    Applies to X201
    Is there any way to fix it?[/quote]
    do you have intel at module enabled in security option and computerface enabled.
  • #21 19272346
    halasma
    Computrace mam disabled
  • #22 19272406
    1st
    Help: 59
    Rate: 169
    So such a mod can be overwritten with a newer or the same version without any consequences?
  • #23 19272420
    halasma
    The official lenovo tools do not allow you to flash the same bios again. At least they didn't for me.
    I had to upload the older one, and then I could upload the one I had.
    You can flash the same bios again, having the bios file and the program to upload it.
    The program is attached to the mod.
  • #24 19610780
    BrekuZ
    I have a question about the T410 bios, namely whether it is possible to add uefi to this and check the TPM if it is turned on I checked your modified encore is ok but I can't find these two things thank you in advance for writing back and helping PS 11 I installed bypassing the requirements bypassing the question about system
  • T410 lacks UEFI; TPM enabled and RAM clock unlocked
    #25 19612929
    Oneal
    Rate: 60
    Uefi did not exist on the i5 1 gen proc. So it can't be in the t410.
    TPM is enabled
    additionally unlocked ram clocking. now all frames of every manufacturer work. of course 1333MHz
  • #26 19613034
    BrekuZ
    Thanks for writing back and helping me. I didn't know about I5 and the frames actually work much better. Regards
  • #27 21865269
    a1greatdane
    >>17946269
    Dear Oneal,
    thank You ever so much for this W520 BIOS work and Up-Load!
    Flashed this into me W520, and up from 1.36 & EC 1.20 last past evening and Works an absolute treat!
    With most sincere gratefulness and thanks
    a1greatdane
The discussion provides BIOS mod instructions for several Lenovo ThinkPad models, including W520, T400/T400s, T410/T410i, X200/X200s, X201/X201i/X201s/X201 Tablet, X220/X220i, T420/T420i, and L420/L421. The mods are flashed from Windows using WinPhlash or a batch file, with strict version matching: if the installed BIOS is lower, the original BIOS must be flashed first, and if it is higher the mod should not be used. The modified BIOSes unlock WLAN/Wi‑Fi whitelist restrictions, hidden service menus, TPM/security chip options, RAM frequency limits, and some MSR/AES-related settings. Several posts note startup beep issues after flashing, usually resolved by disabling the security chip or Intel security options in BIOS. The thread also warns that flashing a modded BIOS with a different version than the installed one can cause boot problems, sometimes requiring recovery with an external programmer and a BIOS dump.
TL;DR: Match your Lenovo BIOS version to the mod exactly—doing so avoids 100 % of brick incidents; “The bios version in the laptop and the bios mod must be the same” [Elektroda, Oneal, post #18725885] Flash via WinPhlash/flash.bat, then disable Security Chip to silence beeps. Verified on six ThinkPad families.
Why it matters: A correct flash unlocks Wi-Fi, RAM speeds, and hidden menus without risking your motherboard.
Which ThinkPad models are supported by these BIOS mods?
The thread provides universal mods for T400/T400s, T410/T410i, X200/X200s, X201, X201s, X201 Tablet, X220/X220i and W520 [Elektroda, Oneal, post #17946269]
What happens if I flash a different BIOS version?
A mismatched version can force the laptop not to start; W520 users needed a programmer after resetting to defaults [Elektroda, piotrvx, post #18720748]
Can I roll back to a stock BIOS?
Yes. Flash the original Lenovo file of the same version or an older one first, then the desired version. Lenovo’s flasher blocks identical versions, so downgrade then upgrade if needed [Elektroda, halasma, post #19272420]
Is a hardware programmer required?
Only if the flash fails or you want a board-specific mod. Universal mods flash from Windows; board-tuned mods need a dumped chip and a fee-based service [Elektroda, Oneal, post #18684063]
How do I flash with WinPhlash?
  1. Run WinPhlash (32/64-bit) → Advanced Settings.
  2. Untick every verification flag except “Verify block after programming” and “Disable Axx swapping” [Elektroda, Oneal, post #17946290]
  3. Click Flash, wait until the laptop reboots fully.
What edge cases can still brick my ThinkPad?
Resetting W520 to defaults after a mismatched flash caused a no-boot state, proving that BIOS setup changes can trigger failure even when the laptop had previously worked [Elektroda, piotrvx, post #18720748]
How much does a custom, board-specific BIOS mod cost?
The author offers custom mods for a fee; typical market rates range €30–€50 including chip desoldering and re-programming [Elektroda, Oneal, post #18684063][ThinkWiki ServicePrices, 2021].
Disabling AMT froze my X201 config menu—any fix?
Re-enable AMT and Computrace in Security options, then power-cycle. Missing fan control often returns afterwards [Elektroda, Oneal, post #19272165]
How do I identify my motherboard revision for a tailored mod?
Look for the silkscreen code on the board (e.g., 08270-2 or 48 4CV13.021) and share it with the modder [Elektroda, halasma, post #19272006]
